[GRASS-user] else if in GRASS GIS
mega saputra
megasaputra8 at gmail.com
Fri Jan 1 14:37:02 PST 2021
It succeed with no error. I add a little syntax :
r.mapcalc --overwrite expression=awan = if( "rgb.1 at PERMANENT" > 1810.877778
&& "rgb.1 at PERMANENT" < 23442.122222 && "rgb.3 at PERMANENT" > 673.148594
&& "rgb.3 at PERMANENT" < 22729.389558 , 0, if("rgb.1 at PERMANENT" == 0, 255,
100))
Thank you
On Fri, Jan 1, 2021 at 9:32 PM Micha Silver <tsvibar at gmail.com> wrote:
> On 1/1/21 3:25 PM, mega saputra wrote:
> Hello guys,
> I try to create conditional statement. When I running the formula in
> GRASS, there is error. Can someone help me to convert in GRASS formula
> format. The formula is something like :
> if ( rgb.1 > 1810.877778) and ( rgb.1 < 23442.122222 ) and (rgb.2 >
> 673.148594) and (rgb.2 < 22729.389558) then 0 else if rgb.1 = 0 then 255
> else 100
> I have try, but with error. My false formula :
> r.mapcalc --overwrite expression=awan = if ( rgb.1 > 1810.877778 & rgb.1
> < 23442.122222 & rgb.2 > 673.148594 & rgb.2 < 22729.389558 , 0) else if
> ( rgb.1 = 0, 255, 100)
> There is no "else" in mapcalc. You put the else expression after the
> second comma.
> Should be:
> r.mapcalc --o "awan = if(rgb.1 > 1810.877778 && rgb.1 < 23442.122222
> && rgb.2 > 673.148594 & rgb.2 < 22729.389558 , 0, if(rgb.1 = 0, 255,
> 100))
> syntax error, unexpected NAME, expecting $end
> Parse error
> ERROR: parse error
> Any suggestion?
> Regards,
> mega
> grass-user mailing listgrass-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210102/28e0424b/attachment.html>
