[GRASS-user] How to create a GRASS addon that returns something when using read_command()
Cam Morlus cam.morlus at gmail.com
Fri Jan 15 01:52:34 PST 2021
Hi Stefan,
Thank you very much for your answer and the documentation! I was able to
write my addon thanks to it :)
Have a nice day,
Camille
Le jeu. 14 janv. 2021 à 21:39, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> a écrit :
> Hi Camille,
> Great resources to start with are:
> wenzeslaus/python-grass-addon: How to write a Python GRASS GIS 7 addon
> (github.com) <https://github.com/wenzeslaus/python-grass-addon>
> and
> wenzeslaus/r.example.plus: An example of a GRASS GIS module for processing
> rasters (github.com) <https://github.com/wenzeslaus/r.example.plus>
> If you want your module to return not maps or tables but output on stdout
> (what read_command() captures), just use the print() function in python.
> Hope that helps to get started!?
> If there is a module that has a UI that could be a good template for what
> you want to do, you can use e.g. “r.info –script” to get a script
> template for the UI and general content.
> Cheers
> Stefan
> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of *Cam
> Morlus
> *Sent:* torsdag 14. januar 2021 21:23
> *To:* grass-user at lists.osgeo.org
> *Subject:* [GRASS-user] How to create a GRASS addon that returns
> Dear All,
> I am using grass 7.8.4. I'm calling commands externally using the Grass
> Python Scripting Library in Python. I wanted to know when you create an
> addon in python how to end the addon script so that when you call that
> addon with read_command() it returns something. I would like to have
> something similar to what happens when calling read_command(g.gisenv) which
> returns the grass variables settings so that you can store them into a
> variable.
> Thank you in advance for your answer.
> Best,
> Camille Morlighem
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210115/90ec11da/attachment-0001.html>
