[GRASS-user] Possible issue with ps.map
Timothy Glyn Southern tim.southern at talktalk.net
Tue Jun 1 13:01:20 PDT 2021
The page is https://giscan.com/sig/pkg/x86_64/
Scroll down and you will see the version of Grass 7.8.5-4
You will also need the xypthon code from the same repository,
I do have 2 .ps files for the grid 100 and grid 50 outputs if needed.
Tim
Dr Timothy Glyn Southern
0155 941 8432
0791 076 6814
> On 1 Jun 2021, at 18:06, grass-user-request at lists.osgeo.org wrote:
> Send grass-user mailing list submissions to
> 	grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>   1. Possible issue with ps.map (Timothy Glyn Southern)
>   2. Re: Possible issue with ps.map (Dave Roberts)
> Message: 1
> Date: Tue, 1 Jun 2021 16:28:40 +0100
> From: Timothy Glyn Southern <tim.southern at talktalk.net>
> To: grass-user at lists.osgeo.org
> Subject: [GRASS-user] Possible issue with ps.map
> Message-ID: <2C253083-05E7-41F2-9D05-F94F012947E0 at talktalk.net>
> Content-Type: text/plain; charset="utf-8"
> Good afternoon all,
> I am using ps.map to create an OS map for an archaeological site and want to add the OS grid lines with their appropriate coordinates.
> If I use
> grid 100
> It produces the lines as desired but only puts the leading 4 digits of the coordinates  and omits the 2 trailing zeros.
> if however I use
> grid 50
> it again produces the grid but this time with the correct coordinates, all 6 digits.
> I am running Grass 7.8 downloaded from Giscan.com as it is a a ?working version? overcoming the as yet un resolved wxpython issue for AUR based versions.
> Am I doing something wrong or is this a possible bug, either from using newer versions of wxpython (4.1.1) or in Grass?
> While I am writing is the north arrow option no longer available in Grass 7.8 within ps.map? It is no longer listed in the manual for the ps.map.
> Thanks for
> 0155 941 8432
> 0791 076 6814
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210601/a96a0040/attachment-0001.html>
> Message: 2
> Date: Tue, 1 Jun 2021 11:06:11 -0600
> From: Dave Roberts <droberts at montana.edu>
> Subject: Re: [GRASS-user] Possible issue with ps.map
> Message-ID: <a7f5e2f1-e7ce-4dd3-a3bd-ec2c680298ab at montana.edu>
> Content-Type: text/plain; charset=utf-8; format=flowed
> Dr. Southern,
>    Can you provide a link for the code you downloaded?  I didn't find
> it at GISCAN.
> Thanks, Dave
> David W. Roberts                                     office 406-994-5670
> Professor                                               FAX 406-994-3190
> Department of Ecology                         email droberts at montana.edu
> 117 AJM Johnson Hall
> Montana State University
> Bozeman, MT 59717-3460
> On 6/1/21 9:28 AM, Timothy Glyn Southern via grass-user wrote:
>> Good afternoon all,
>> If I use
>> grid 100
>> the coordinates ?and omits the 2 trailing zeros.
>> if however I use
>> grid 50
>> all 6 digits.
>> <https://nam10.safelinks.protection.outlook.com/?url=http%3A%2F%2Fgiscan.com%2F&data=04%7C01%7Cdroberts%40montana.edu%7C0338516d34bd45225aac08d925131646%7C324aa97a03a644fc91e43846fbced113%7C0%7C0%7C637581586173695968%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=%2BrjIqwTllq22E5nzuZbhZGyzYcVGYi4skrmVqsXlNG0%3D&reserved=0>
>> ps.map.
>> Thanks for
>> 0155 941 8432
>> 0791 076 6814
>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>> Today's Topics:
>>> ??1. Re: bayesian belief network analysis (was r.binfer) (Saulteau Don)
>>> Message: 1
>>> Date: Sat, 29 May 2021 12:12:45 -0700
>>> From: Saulteau Don <sault.don at gmail.com>
>>> To: GRASS user list <grass-user at lists.osgeo.org>
>>> Subject: Re: [GRASS-user] bayesian belief network analysis (was
>>> r.binfer)
>>> Message-ID:
>>> <CAJo0jfPdyfY3xxPfC4hrSNhsJ4kXtgdQj9wXtzqrr9XBrZ0gFw at mail.gmail.com>
>>> OK thanks! I'll see if I can find an old grass executable, compile in a VM
>>> with r.binfer in it or fallback to QGIS and OpenBugs. I thought I'd poke
>>> around cause I prefer analysis in GRASS over any other platform out
>>> there :)
>>> I've started to assist indigenous nations with assertion and
>>> protection/preservation of their rights with GIS. Some of these analytical
>>> methods like fuzzy/boolean patch modelling, weighted overlays, bayesian
>>> belief networks (BBN) allow them to translate their oral history and
>>> ecological knowledge into tools that help them engage effectively and
>>> meaningfully with other parties such as other nations/governments and
>>> industries who have expressed interest in their lands and resources.
>>> I SO wish I could code or even knew what to ask for in procurement for
>>> these things cause I would.
>>> Been a lowly user, bug reporter, package maintainer and crowd funder.
>>> Continuing to find ways to feed back and wholly contribute into these FOSS
>>> communities any way I can.
>>> Donovan
>>> On Sat., May 29, 2021, 03:12 Markus Neteler, <neteler at osgeo.org> wrote:
>>>> On Sat, May 29, 2021 at 4:20 AM Donovan Cameron <sault.don at gmail.com>
>>>> wrote:
>>>>> Evening,
>>>>> I'm attempting to analyze a set of layers (slope, aspect, vegetation,
>>>>> soil, etc) that have been coded/scored based on expert opinion to output
>>>>> a probability/suitability map.
>>>>> I'm looking to apply a bayesian belief network [1] and i've got the
>>>>> raster layers ready for the inputs and coded like seen in this figure
>>>> [2].
>>>>> There was a grass4 module called r.binfer [3] that did this and I can't
>>>>> seem to find it with GRASS 78 - deprecated or replaced?
>>>> The latest code trace which I could find is this one:
>>>> GRASS GIS 5.5:
>>>> https://github.com/OSGeo/grass-legacy/tree/releasebranch_5_5/src/raster/r.binfer
>>>> I do not recall why the module has been abandoned in GRASS GIS 6
>>>> (maybe no particular reason and a volunteer could update it...?).
>>>> Another option might be to rely on R and use "rgrass7" to exchange
>>>> data between GRASS GIS and R.
>>>> Best,
>>>> Markus
>>>>> Searches lead me to either r.regression.multi [4] or r.learn.ml [5] but
>>>>> i'm not sure where to start with these to get a BBN processed thru them.
>>>>> SaultDon
>>>>> [1] https://www.gislounge.com/gis-bayesian-belief-networks/
>>>>> [2]
>>>> https://www.sciencedirect.com/science/article/pii/S0169204618307497#f0010
>>>>> [3]
>>>> https://grass.osgeo.org/grass43/manuals/html_grass4/html/r.binfer.html
>>>>> [4] https://grass.osgeo.org/grass78/manuals/r.regression.multi.html
>>>>> [5] https://grass.osgeo.org/grass78/manuals/addons/r.learn.ml.html
>>>>> _______________________________________________
>>>> Markus Neteler, PhD
>>>> https://www.mundialis.de - free data with free software
>>>> https://courses.neteler.org/blog
>>> URL:
>>> <http://lists.osgeo.org/pipermail/grass-user/attachments/20210529/5cd28ccb/attachment-0001.html>
>>> Subject: Digest Footer
>>> End of grass-user Digest, Vol 181, Issue 21
> End of grass-user Digest, Vol 182, Issue 1
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210601/3262add1/attachment-0001.html>
