[GRASS-user] Creating a png file with multiple vector maps
    Moritz Lennert
    mlennert at club.worldonline.be
    Tue Mar  2 06:53:02 PST 2021
Sorry, Chris, I lost this out of my sight.
I don't see anything immediately wrong. Maybe it is a specific MS
Windows issue I cannot reproduce here in GNU/Linux.
@Helmut any ideas ?
Moritz
On 17/02/21 19:17, Chris Bartolomei wrote:
> Good afternoon Moritz - thank you for the feedback :)
> I've been able to get GRASS 7.8 running with msys on my pc so I can send
> images etc. now... I tried repeating what I had done at work and I have
> the same results ... I also downloaded the Spearfish dataset as you
> suggested and brought in the boundary_county vector. I can go into
> Properties and fill color orange and outline gray, but I go to the
> console and do the d.vect map=boundary_county color=red
> fill_color=orange and all I get is the red boundaries.I attached an
> image of everything ... the Layer Manager, the Display window, the msys
> console window with my commands run and all my exported GRASS variables,
> and the resultant png image.
> I've tried this with several other polygon vector files and I get the
> same darn thing.  Can you see anything wrong with my variable settings ?
> GRASS 7.8.4> v.info -t boundary_county at WarningPoints #from the Spearfish
> dataset
> nodes=1114
> points=0
> lines=0
> boundaries=1910
> centroids=926
> areas=926
> islands=130
> primitives=2836
> map3d=0
> GRASS 7.8.4> env | grep GRASS
> MANPATH=C:\OSGEO4~1\apps\grass\grass78\docs\man;C:\Users\Chris\AppData\Roaming\GRASS7\addons\docs\man
> GRASS_PYTHON=C:\OSGEO4~1\bin\python3.exe
> GRASS_RENDER_TRANSPARENCY=true
> GRASS_PAGER=more
> GRASS_GNUPLOT=gnuplot -persist
> GRASS_RENDER_PNG_COMPRESSION=0
> GRASS_RENDER_FILE_COMPRESSION=0
> GRASSBIN=C:\OSGEO4~1\apps\grass\grass78\bin
> GRASS_SH=C:\OSGEO4~1\apps\msys\bin\sh.exe
> GRASS_RENDER_HEIGHT=480
> PATH=/c/OSGEO4~1/apps/grass/grass78/lib:/c/OSGEO4~1/apps/grass/grass78/bin:/c/Users/Chris/AppData/Roaming/GRASS7/addons/bin:/c/OSGEO4~1/apps/Python37:/c/OSGEO4~1/apps/Python37/Scripts:/c/OSGEO4~1/apps/Python27/Scripts:/c/OSGEO4~1/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/system32/WBem:/usr/bin:/c/Program
> Files/RStudio/bin:/c/OSGEO4~1/apps/grass/grass78/bin:/c/OSGEO4~1/apps/grass/grass78/scripts:/c/OSGEO4~1/apps/grass/grass78/lib:.:/c/OSGEO4~1/apps/Python37/lib/site-packages/pywin32_system32
> GRASS_MESSAGE_FORMAT=plain
> GRASS_PROJSHARE=C:\OSGEO4~1\share\proj
> PS1=GRASS 7.8.4>
> GRASS_VERSION=7.8.4
> GRASS_HTML_BROWSER=start
> GRASS_RENDER_WIDTH=640
> GRASS_RENDER_TRUECOLOR=true
> GRASS_RENDER_IMMEDIATE=png
> GRASS_ADDON_BASE=C:\Users\Chris\AppData\Roaming\GRASS7\addons
> GRASS_RENDER_FILE_READ=true
> GRASS 7.8.4> d.vect map=boundary_county at WarningPoints color=red
> fill_color=orange
> d.vect complete.
> GRASS 7.8.4>
> Thanks again ... and sorry to bother you so much!
> Chris
> On Wednesday, February 17, 2021, 7:57:08 AM EST, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
> Hi Chris,
> On 17/02/21 02:30, Chris Bartolomei wrote:
>  > Ohhhhh !! Sooooooo close ! I can get the two vector maps to overlay and
>  > display but no matter what I do I cannot get them to do a color fill ...
>  > ugh ... fill_color does nothing. I can use "d.vect map=admin_area
>  > color=red" and the boundaries change to red, but "d.vect map=admin_area
>  > color=black fill_color=red" and i do not get any filled color. So
>  > frustrating. I thought maybe my shapefile imported as just a boundary
>  > but when I do a "v.category input=admin_area option=report" I get:
>  > Layer/table 1/admin_area
>  > type             count    min    max
>  > point                    0        0         0
>  > line                      0        0         0
>  > boundary            0        0         0
>  > centroid             59       1        25
>  > area                     0        0         0
>  > face                     0        0         0
>  > kernel                  0        0         0
>  > all                       59        1        25
>  > Should I have areas in there too ??
> I'm not really sure what 'area' in the output of v.category actually
> refers to, as areas cannot have categories in GRASS GIS.
> In order to see if you have areas in your file, check with v.info:
>  > I wonder if the import went wonky.... what is strange is that the ps.map
>  > tool fills the polygons just fine.
>  > Moritz - could please I ask you to do a v.category on one of your vector
>  > maps (v.category input=censuslbk_wwake at PERMANENT
> <mailto:censuslbk_wwake at PERMANENT> option=report) and see
>  > if it has areas in it or just centroids like I have?
> GRASS 7.8.5 (nc_spm_08_grass7):~ > v.info -t boundary_county
> nodes=1114
> points=0
> lines=0
> boundaries=1910
> centroids=926
> areas=926
> islands=130
> primitives=2836
> map3d=0
> but
>  >v.category boundary_county op=report
> Layer/table: 1/boundary_county
> type      count        min        max
> point          0          0          0
> line          0          0          0
> boundary      0          0          0
> centroid    926          1        926
> area          0          0          0
> face          0          0          0
> kernel        0          0          0
> all          926          1        926
> In order to find out if the issue comes from your data or from your
> installation of GRASS GIS, you can also download the NC demo data set
> from https://grass.osgeo.org/download/data/#NorthCarolinaDataset
> <https://grass.osgeo.org/download/data/#NorthCarolinaDataset >and try
> to reproduce what I did in order to see if it works.
> Moritz
>  > On Tuesday, February 16, 2021, 11:20:31 AM EST, Chris Bartolomei
>  > <surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>> wrote:
>  > Well - that does indeed work for you.  I'll try your settings when I get
>  > into the office - we're running GRASS on a RHEL 7 cluster - and see what
>  > I can come up with.
>  > It would be sooo much better if it worked like yours did!
>  > Thank you so much for taking the time and testing this out
>  > v/r
>  > Chris
>  > On Tuesday, February 16, 2021, 11:07:10 AM EST, Moritz Lennert
>  > <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
> wrote:
>  > On 16/02/21 15:54, Chris Bartolomei wrote:
>  >  > Mortiz - are those vector layers areas ? I'm guessing the census is an
>  >  > area, the roads are lines and the schools are points, yes?  I'm having
>  >  > an issue overlaying two area maps (polygons). i can only get one
> to show
>  >  > ... I have tried your method with all the export GRASS_RENDER*
> variables
>  >  > but I have a country polygon map as the bottom later and a
> selection of
>  >  > a few administrative areas (provinces/states) as the top map and I can
>  >  > only get one or the other to show up. It almost seems as if the
>  >  > transparency doesn't work and what should be transparent in the admin
>  >  > map is actually the background color and blocks the country from
>  > being seen.
>  >  > Could you please try your method with a couple area (polygon) vector
>  >  > maps overlaying each other?
>  > export GRASS_RENDER_IMMEDIATE=png
>  > export GRASS_RENDER_WIDTH=640
>  > export GRASS_RENDER_HEIGHT=480
>  > export GRASS_RENDER_TRUECOLOR=true
>  > export GRASS_RENDER_FILE_COMPRESSION=0
>  > export GRASS_MESSAGE_FORMAT=plain
>  > export GRASS_RENDER_FILE_READ=TRUE
>  > export GRASS_RENDER_FILE=$HOME/test.png
>  > g.region vect=census_wake2000
>  > d.vect map=census_wake2000 at PERMANENT
> <mailto:census_wake2000 at PERMANENT> <mailto:census_wake2000 at PERMANENT
> <mailto:census_wake2000 at PERMANENT>>
>  > fill_color=grey
>  > d.vect map=censusblk_swwake at PERMANENT
> <mailto:censusblk_swwake at PERMANENT>
> <mailto:censusblk_swwake at PERMANENT>> fill_color=red
>  > I've tried with
>  > export GRASS_RENDER_TRANSPARENT=TRUE
>  > and
>  > export GRASS_RENDER_TRANSPARENT=FALSE
>  > As you can see in the attached images, the overlay seems to work without
>  > any issues (or I don't understand what you are looking for exactly) and
>  > setting GRASS_RENDER_TRANSPARENT decides on whether the background
>  > should be transparent or not.
>  > A second test in the same data set, but with different layers:
>  > export GRASS_RENDER_FILE=$HOME/test_NC_TRUE.png
>  > g.region vect=boundary_county
>  > d.vect map=boundary_county at PERMANENT
> <mailto:boundary_county at PERMANENT> <mailto:boundary_county at PERMANENT
> <mailto:boundary_county at PERMANENT>>
>  > d.vect map=boundary_municp at PERMANENT
> <mailto:boundary_municp at PERMANENT> <mailto:boundary_municp at PERMANENT
> <mailto:boundary_municp at PERMANENT>>
>  > fill_color=255:255:0:255
>  > export GRASS_RENDER_FILE=$HOME/test_NC_FALSE.png
>  > Again, the overlay works, at least as I would have expected.
>  > Moritz
>  >  > On Tuesday, February 16, 2021, 4:19:16 AM EST, Moritz Lennert
>  >  > <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>>
>  > wrote:
>  >  > Hi Chris,
>  >  > For me, the following works with the current stable GRASS GIS (7.8.5)
>  >  > and using maps from the NC demo data set:
>  >  > export GRASS_RENDER_IMMEDIATE=png
>  >  > export GRASS_RENDER_WIDTH=640
>  >  > export GRASS_RENDER_HEIGHT=480
>  >  > export GRASS_RENDER_TRANSPARENT=true
>  >  > export GRASS_RENDER_TRUECOLOR=true
>  >  > export GRASS_RENDER_FILE_COMPRESSION=0
>  >  > export GRASS_MESSAGE_FORMAT=plain
>  >  > export GRASS_RENDER_FILE_READ=TRUE
>  >  > g.region vect=census_wake2000
>  >  > d.vect map=census_wake2000 at PERMANENT
>  > <mailto:census_wake2000 at PERMANENT <mailto:census_wake2000 at PERMANENT>>
>  > <mailto:census_wake2000 at PERMANENT <mailto:census_wake2000 at PERMANENT>>>
>  >  > fill_color=none
>  >  > d.vect map=roadsmajor at PERMANENT <mailto:roadsmajor at PERMANENT>
> <mailto:roadsmajor at PERMANENT <mailto:roadsmajor at PERMANENT>>
> <mailto:roadsmajor at PERMANENT <mailto:roadsmajor at PERMANENT>>>
>  >  > color=255:0:0:255
>  >  > d.vect map=schools_wake at PERMANENT <mailto:schools_wake at PERMANENT>
> <mailto:schools_wake at PERMANENT <mailto:schools_wake at PERMANENT>>
> <mailto:schools_wake at PERMANENT <mailto:schools_wake at PERMANENT>>>
>  >  > fill_color=0:128:0:255
>  >  > icon=basic/circle size=10
>  >  > I attach a small thumbnail of the resulting PNG file.
>  >  > Moritz
>  >  > On 11/02/21 18:54, Chris Bartolomei via grass-user wrote:
>  >  >  > Good morning Anna,
>  >  >  > It took quite a while of trial and error but I worked out a method
>  > that
>  >  >  > kindof works:
>  >  >  > First off - unless someone says otherwise, you can't use the PNG
>  > driver
>  >  >  > (d.mon) method to overlay more than one polygon vector. Sorry - it
>  > just
>  >  >  > doesn't work. You CAN use the ps.map method - that works really
> well
>  >  >  > generating the image however it by default assumes you are
> printing on
>  >  >  > an A4 piece of paper so there's all sorts of white space.  The
>  > image is
>  >  >  > centered at the top of this fictional piece of paper. In your
>  > postscript
>  >  >  > rules file you can use the "maploc" command to position the image
>  >  >  > elsewhere on the page. This is necessary because the next trick
>  > changes
>  >  >  > the paper dimensions but it assumes the origin is the lower left
>  > corner
>  >  >  > and therefore clips anything that is above the new dimensions.
> Back to
>  >  >  > postscript commands in the rules file first though ... the ps.map
>  > maploc
>  >  >  > command uses inches (why?? it should be points) so an A4 page is
>  > 8.27" x
>  >  >  > 11.69" points are 1/72 of an inch thus 595p x 842p - it also has a
>  >  >  > default 36p margin (0.5 inch). You'll need those numbers later.
> maploc
>  >  >  > also lets you set the size of your image box:  maploc {x offset
> from
>  >  >  > left edge} {y offset from top} {width of box} {height of box}
>  > Note: this
>  >  >  > is all done via a BASH script with GRASS 7.4 on Linux (RHEL 7), not
>  >  >  > python. This is my postscript rules file:
>  >  >  > maploc 0.1 6.815 6.5 4.875 #468p x 351p map box moved down
> towards the
>  >  >  > bottom of the page
>  >  >  > # note that if you push it too far down to where the box would
> run off
>  >  >  > the bottom, the image is
>  >  >  > # resized to fit on the page so do some testing to come up with the
>  >  >  > correct values
>  >  >  > # also I found the computational region controls the aspect
> ratio so
>  >  >  > although I say
>  >  >  > # 6.5 x 4.875 with the above maploc command, I got a 6.5 x 3.8
>  > inch box.
>  >  >  > border y # add a border to the map frame (box)
>  >  >  >    color 81:81:81 # shade of gray
>  >  >  >    end # end the border controls
>  >  >  > vareas admin_area # top vector layer to display
>  >  >  >    layer 1 # attribute table to use
>  >  >  >    rgbcolumn area_color # name of column holding R:G:B values
> to fill
>  >  >  > the polygons
>  >  >  >    color 153:153:153 #boundary color
>  >  >  >    end # end the admin_area controls
>  >  >  > vareas Country # this is the bottom vectors to display
>  >  >  >    color 210:210:210 #boundary color
>  >  >  >    fcolor 153:153:153 #fill color for all polygons
>  >  >  >    end # end the Country controls
>  >  >  > Here's the command to run to generate the postscript file:
>  >  >  > ps.map input=$HOME/ps_rules.txt out=$HOME/color_admin.ps
> --overwrite
>  >  >  > To convert the postscript to PNG I had to use ghostscript -
> there are
>  >  >  > other tools you can use though.
>  >  >  > gs -dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m -r300
> -dTextAlphaBits=4
>  >  >  > -dGraphicsAlphaBits=4 -dDEVICEWIDTHPOINTS=473
> -dDEVICEHEIGHTPOINTS=276
>  >  >  > -dFIXEDMEDIA -dPSFitPage -sOutputFile=$HOME/color_admin.png -c
>  >  >  > "<</PageOffset [-34 78]>> setpagedevice" -f $HOME/color_admin.ps
>  >  >  > So the above line needs some explaining
>  >  >  > (http://www.ghostscript.com/doc/9.27/Use.htm
> <http://www.ghostscript.com/doc/9.27/Use.htm >
> <http://www.ghostscript.com/doc/9.27/Use.htm >>
>  >  > <http://www.ghostscript.com/doc/9.27/Use.htm
> <http://www.ghostscript.com/doc/9.27/Use.htm>>>) but in a nutshell, the
>  >  >  > parameters to play with are first the Pageoffset [x y] values.
>  > They are
>  >  >  > in points not inches ... 1/72 inch = 1 point ... remember the 1/2"
>  >  >  > margins? the -34 gives me 2 points of white space to the left
> edge of
>  >  >  > the map frame, the 78 I had to play with to push the map frame
> down to
>  >  >  > the right spot.
>  >  >  > Next is the DEVICEWIDTHPOINTS and DEVICEHEIGHTPOINTS ... again in
>  > points
>  >  >  > ... this "trims" the paper to height and width ... set
> something then
>  >  >  > run it and view the results. Adjust and run again until you get it
>  >  > correct.
>  >  >  > It's a royal pain but it seems to work this way. It would sure
> be nice
>  >  >  > to create a GRASS workspace file and just say "convert this
>  > workspace to
>  >  >  > an image" with everything all laid out nicely - like Arc does
>  > exporting
>  >  >  > their mxd map files...
>  >  >  > I hope this helps someone !
>  >  >  > Chris
>  >  >  > On Wednesday, February 10, 2021, 11:08:00 PM EST, Anna Petrášová
>  >  >  > <kratochanna at gmail.com <mailto:kratochanna at gmail.com>
> <mailto:kratochanna at gmail.com <mailto:kratochanna at gmail.com>>
> <mailto:kratochanna at gmail.com <mailto:kratochanna at gmail.com>>>> wrote:
>  >  >  > On Tue, Feb 9, 2021 at 4:41 PM Chris Bartolomei
>  > <mailto:surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>>
>  >  > <mailto:surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>
> <mailto:surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>>>
>  >  >  > <mailto:surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>
> <mailto:surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>>>>> wrote:
>  >  >  >    Hi Anna - thank you for the suggestion - I tried it but
> alas, still
>  >  >  >    it only outputs a single vector map (layer). I can get
> either the
>  >  >  >    Country vector or the admin_areas vector, but not both overlaid.
>  >  >  >    Chris
>  >  >  > I realized you are using both environmental variables and
> d.mon, that
>  >  >  > might cause some issues, you use one or the other. So try to
>  > remove the
>  >  >  > lines starting with d.mon.
>  >  >  > Hope that helps,
>  >  >  > Anna
>  >  >  >    On Tuesday, February 9, 2021, 1:20:52 PM EST, Anna Petrášová
>  >  > <mailto:kratochanna at gmail.com <mailto:kratochanna at gmail.com>
> <mailto:kratochanna at gmail.com <mailto:kratochanna at gmail.com>>>>> wrote:
>  >  >  >    Hi,
>  >  >  >    On Tue, Feb 9, 2021 at 10:25 AM Chris Bartolomei via grass-user
>  >  >  >    <grass-user at lists.osgeo.org
> <mailto:grass-user at lists.osgeo.org> <mailto:grass-user at lists.osgeo.org
> <mailto:grass-user at lists.osgeo.org>>
> <mailto:grass-user at lists.osgeo.org>>>
> <mailto:grass-user at lists.osgeo.org>> <mailto:grass-user at lists.osgeo.org
> <mailto:grass-user at lists.osgeo.org>>>>>
>  >  > wrote:
>  >  >  >        Good morning :)
>  >  >  >        I'm using GRASS 7.4.1 on a Linux cluster so I only have
>  >  >  >        command-line capability. I have two vector layers (a country
>  >  >  >        boundary polygon and part of an administrative area map
> - also
>  >  >  >        polygons). I am trying to automate creating a PNG file
> of the
>  >  >  >        admin areas overlaying the country boundary therefore
> all work
>  >  >  >        has to be command-line (in a bash script). I've tried
> this two
>  >  >  >        ways - using the d.mon start=png method and also the ps.map
>  >  >  >        method as described below. The d.mon method appears to
> generate
>  >  >  >        the image with only one vector map (not both) and only
> colors
>  >  >  >        the borders - it won't use the fill_color setting. The
> ps.map
>  >  >  >        method seems to work but assumes the image is on a sheet of
>  >  >  >        paper so there's a ton of extra white-space. I'd like to use
>  >  >  >        d.mon but I can use ps.map if someone could please let
> me know
>  >  >  >        how to export only the computational region without all the
>  >  >  >        extra 'paper' in the image. Here's my code:
>  >  >  >        g.region vector='Country'
>  >  >  >        export GRASS_RENDER_IMMEDIATE=png
>  >  >  >        export GRASS_RENDER_WIDTH=640
>  >  >  >        export GRASS_RENDER_HEIGHT=480
>  >  >  >        export GRASS_RENDER_TRANSPARENT=true
>  >  >  >        export GRASS_RENDER_TRUECOLOR=true
>  >  >  >        export GRASS_RENDER_FILE=$HOME/country_admin.png
>  >  >  >        export GRASS_RENDER_FILE_COMPRESSION=0
>  >  >  >        export GRASS_MESSAGE_FORMAT=plain
>  >  >  >        d.mon start=png
>  >  >  >        d.vect map=Country color=210:210:210 fill_color=153:153:153
>  >  >  >        display=shape type=area
>  >  >  >        d.vect map=admin_area color=153:153:153
> rgb_column=area_color
>  >  >  >        d.mon stop=png
>  >  >  >        This only produces a png with the last vector listed and
> only
>  >  >  >        the borders are colored with the rgb_column values.
>  >  >  >    I think you are missing  GRASS_RENDER_FILE_READ=TRUE:
>  >  >  > https://grass.osgeo.org/grass78/manuals/pngdriver.html
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html >
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html >>
>  >  > <https://grass.osgeo.org/grass78/manuals/pngdriver.html
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html>>>
>  >  >  >    <https://grass.osgeo.org/grass78/manuals/pngdriver.html
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html>>>>
>  >  >  >    Regarding rgb_column, I am not sure, didn't have time to test.
>  >  >  >    Anna
>  >  >  >        If I do this without the d.mon start/stop lines ... i.e.
>  > relying
>  >  >  >        on the GRASS_RENDER_IMMEDIATE=png only, then only one
>  > vector map
>  >  >  >        is converted to png however it DOES do the color fill
> properly.
>  >  >  >        With either above method the png is the correct size.
>  >  >  >        Now using ps.map (same env variable set as above):
>  >  >  >        ps.map input=$HOME/ps_rules.txt out=$HOME/country_admin.ps
>  >  >  >        --overwrite
>  >  >  >            where ps_rules.txt is:
>  >  >  >        border y
>  >  >  >            color 81:81:81
>  >  >  >            end
>  >  >  >            layer 1
>  >  >  >            end
>  >  >  >        vareas Country
>  >  >  >            end
>  >  >  >        We don't have pstopng but we do have ghostscript:
>  >  >  >        gs-dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m
> -dTextAlphaBits=4
>  >  >  >        -dGraphicsAlphaBits=4 -r300
>  > -sOutputFile=$HOME/country_admin.png
>  >  >  >        $HOME/country_admin.ps
>  >  >  >        This creates the correct image (color fills, etc) but
> has white
>  >  >  >        margins and a lot of white space below the image likeit is
>  >  >  >        printed at the top of a piece of paper.
>  >  >  >        does anyone have any idea how to create a png with multiple
>  >  >  >        vector maps overlaying each other (and not have the extra
>  >  >  >        whitespace too)?
>  >  >  >        v/r
>  >  >  >        Chris
>  >  >  >        _______________________________________________
>  >  >  >        grass-user mailing list
>  >  >  > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> <mailto:grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>>
>  > <mailto:grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>>>>
>  >  >  > https://lists.osgeo.org/mailman/listinfo/grass-user
> <https://lists.osgeo.org/mailman/listinfo/grass-user >
> <https://lists.osgeo.org/mailman/listinfo/grass-user >>
>  >  > <https://lists.osgeo.org/mailman/listinfo/grass-user
> <https://lists.osgeo.org/mailman/listinfo/grass-user>>>
>  >  >  >        <https://lists.osgeo.org/mailman/listinfo/grass-user
> <https://lists.osgeo.org/mailman/listinfo/grass-user>>>>
