[GRASS-user] can't install and execute python script
Frank David
frank.david at geophom.fr
Tue Mar 16 11:37:26 PDT 2021
Hi Markus,
Le 16/03/2021 à 18:56, Markus Neteler a écrit :
> On Tue, Mar 16, 2021 at 3:02 PM Frank David <frank.david at geophom.fr> wrote:
>> Hi Markus,
>> Thank you for your reply and correction. But no thing has changed on my Grass 7.8.3 / Ubuntu 20.10, and it's still working on may Grass 7.69 / Debian Buster (see console below)
> Yes:
> - GRASS GIS 7.6 uses Python 2
> - GRASS GIS 7.8 uses Python 3
I wrote 7.69 but it's 7.9...
>> (Tue Mar 16 14:50:05 2021)
>> g.extension extension=r.wtg url=/media/zephyr/ress/informatique/scripts/grass/scripts/r.wtg
>> Fetching <r.wtg> from </media/zephyr/ress/informatique/scripts/grass/scripts/r.wtg> (be patient)...
>> Compiling...
>> Installing...
>> Updating extensions metadata file...
>> Updating extension modules metadata file...
>> WARNING: No metadata available for module 'r.wtg'.
>> Installation of <r.wtg> successfully finished
>> (Tue Mar 16 14:50:14 2021) La commande s'est terminée (9 sec)
>> It's curious that Grass say "...not found" on every script, while copying the file in addons/ ?
> Here I didn't get that error but mainly the one with the wrong
> formatting. The "... not found" might be a secondary error while the
> original error message isn't visible (for whatever reason).
> Let me suggest that you update all Python script to Python 3 (there is
> the "2to3" script as well as "autopep8" and others for that purpose).
> Once done, perhaps the errors you get are gone?
Ok I will update at least one script, and remove the other for testing
(I know I must update all). But I'm surprised because scripts could be
executed with File>Launch script...
I wil tell you soon.
Thank you for your help.
Cheers,
Frank
> Markus
>> Frank DAVID
>> Le 16/03/2021 à 13:24, Markus Neteler a écrit :
>> Hi,
>> On Mon, Mar 15, 2021 at 11:31 PM Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Mar 15, 2021 at 11:07 AM Frank David <frank.david at geophom.fr> wrote:
>> Hello,
>> I've installed GRASS 7.8.3 on Ubuntu 20.10 (groovy) and when I try to install my own python script, the message is :
>> Compiling...
>> /bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.visibility.threshold: not found
>> /bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.visibility.conv: not found
>> Do you have any idea that problem ?
>> This is somehow hard to say - is the addon available for testing?
>> For posterity:
>> I received the addon offlist. Some files showed Python 3 syntax
>> errors, fixed with "autopep8" and now the installation works (for me).
>> cheers,
>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210316/4f9ea1b8/attachment.html>
