[GRASS-user] error in g.extension while installing i.fusion.hpf in windows
Markus Neteler
neteler at osgeo.org
Thu Mar 18 06:58:21 PDT 2021
On Thu, Mar 18, 2021 at 1:35 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Hello list,
> A student is getting the following error when trying to install i.fusion.hpf
> C:\>g.extension extension=i.fusion.hpf
> Downloading precompiled GRASS Addons <i.fusion.hpf>...
> Fetching <i.fusion.hpf> from
> <http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.5/i.fusion.hpf.zip>
> (be patient)...
> Traceback (most recent call last):
> File "C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py", line 2350, in <module>
> sys.exit(main())
> File "C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py", line 2330, in main
> install_extension(source=source, url=url, xmlurl=xmlurl, branch=branch)
> File "C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py", line 871, in install_extension
> ret1, new_modules_ext, new_files_ext = install_extension_win(extension)
> File "C:\OSGEO4~1\apps\grass\grass78/scripts/g.extension.py", line 1259, in install_extension_win
> for line in file:
> File "C:\OSGEO4~1\apps\Python37\lib\fileinput.py", line 252, in __next__
> line = self._readline()
> File "C:\OSGEO4~1\apps\Python37\lib\fileinput.py", line 366, in _readline
> return self._readline()
> File "C:\OSGEO4~1\apps\Python37\lib\encodings\cp1252.py", line 23, in decode
> return codecs.charmap_decode(input,self.errors,decoding_table)[0]
> UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d in position 401: character maps to <undefined>
What surprises me a bit:
file *
constants.py: Python script, UTF-8 Unicode text executable
high_pass_filter.py: Python script, ASCII text executable
i.fusion.hpf.html: HTML document, ASCII text
i_fusion_hpf_lsat7_hpf_rgb.png: PNG image data, 1327 x 840,
8-bit/color RGB, non-interlaced
i_fusion_hpf_lsat7_orig_rgb.png: PNG image data, 1327 x 840,
i.fusion.hpf.py: Python script, ASCII text executable
licenses: directory
Makefile: ASCII text
README.md: UTF-8 Unicode text
test_high_pass_filter.py: Python script, ASCII text executable
--> some .py files are UTF-8, some are not.... shall this be streamlined?
Markus
PS: perhaps more a question for grass-dev
