[GRASS-user] Building grass version grass-7.8.5
Veronica Andreo veroandreo at gmail.com
Fri Mar 26 11:25:00 PDT 2021
Hi Steve,
I'm no expert in compiling at all, but I always run configure in the source
code directory. Have you tried?
Once configure runs without errors, just run make, if no errors at the end,
you are good to go
Here's a wiki with instructions for diverse linux platforms:
https://grasswiki.osgeo.org/wiki/Compile_and_Install
hth,
Vero
El vie, 26 mar 2021 a las 18:07, Stephen Kirby (<thinjogger at gmail.com>)
escribió:
> Hi,
> I am trying to build the version of GRASS listed in the subject line.
> However, when I run configure, it does not produce a "Makefile" even though
> configure appears to complete without error.  The closest thing I see to a
> Makefile is this file:  include/Make/Platform.make.  I am not running
> configure in the source code directory as one is always told this is a bad
> idea (for ex., when building gcc).  I am running configure in a separate
> directory ("/build-grass").  Let me know what I should try next as I am
> excited to get GRASS running!
> Best regards,
> Steve
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210326/9e4f2153/attachment.html>
