[GRASS-user] GUI/Addons
Cyril Gainon
Gainon.Cyril at hotmail.fr
Thu May 6 00:51:53 PDT 2021
Hello everyone,
This is my first time using a mailing list so i hope it would be a great experience.
Since my second day using grass evrything is a nightmare to use ... There is always something wrong.
I/Grass -gui
So i cant use the gui interface because i don't have wxPython:
Démarrage du SIG GRASS ...
ERROR: wxGUI requires wxPython. No module named 'wx'
You can still use GRASS GIS modules in the command line or in Python.
ERREUR: Erreur lors du lancement de l'interface graphique. Lire les messages ci-dessous (s'il y en a), et si nécessaire merci de rapporter cette erreur aux dévelopeurs GRASS. Sur un système avec un gestionnaire de paquets, assurez-vous d'avoir le bon paquet d'interface graphique installé, probablement nommé grass-gui.
Pour lancer GRASS en mode texte utilisez l'option --text.
Utilisez '--help' pour plus d'options
And when i try to install it via sudo apt-get install wxPython
'python-wxWidgets-3_0' fournissant 'wxPython' est déjà installé.
Résolution des dépendances des paquets...
Rien à faire.
So it says i have already wxPython. With that i just dont know what to do.
II/Addons
Since i can't get the graphical interface working i was resolved to use the text interface.
when i try to use g.extension extension=r.neighboorhoodmatrix i get:
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld : /usr/lib64/libgdal.so.28 : référence indéfinie vers « opj_encoder_set_extra_options »
collect2: error: ld returned 1 exit status
make: *** [/usr/lib64/grass78/include/Make/Module.make:18: /tmp/grass7-cyril.gainon-15457/tmp8hn9bx9x/r.neighborhoodmatrix/bin/r.neighborhoodmatrix] Error 1
ERREUR : Compilation failed, sorry. Please check above error messages.
For information when i still had the interface i had the svn pb when trying to install an addon. i did resolve it by installing grass-dev and make an update since then it's note working.
Also i'm working on Opensuse 15.2 and grass 7.8
Hope i gave you sufficient info, either way ask me and i can give you more.
thanks for reading and hope you can help me
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/ca874498/attachment.html>
