[GRASS-user] GUI/Addons
    Cyril Gainon
    gainon.cyril at hotmail.fr
    Thu May  6 06:20:05 PDT 2021
Oh yeah sorry abour that.
you're right i totally forgot about it, i mainly used apt-get (in my studies i was mostly on mint) so i guess we go back to your theory conflit with unbuntu library.
Here are all the wx i got with zypper pa | grep wx
   | openSUSE-Leap-15.2-1        | plplotwxwidgets-devel                                             | 5.15.0-lp152.2.4                                                 | x86_64
   | Dépôt principal        | plplotwxwidgets-devel                                             | 5.15.0-lp152.2.4                                                 | x86_64
i+ | openSUSE-Leap-15.2-1        | python-wxWidgets-3_0                                              | 3.0.2.0-lp152.4.8                                                | x86_64
i+ | Dépôt principal        | python-wxWidgets-3_0                                              | 3.0.2.0-lp152.4.8                                                | x86_64
   | openSUSE-Leap-15.2-1        | python-wxWidgets-3_0-devel                                        | 3.0.2.0-lp152.4.8                                                | x86_64
   | Dépôt principal        | python-wxWidgets-3_0-devel                                        | 3.0.2.0-lp152.4.8                                                | x86_64
i+ | openSUSE-Leap-15.2-1        | python-wxWidgets-3_0-lang                                         | 3.0.2.0-lp152.4.8                                                | x86_64
i+ | Dépôt principal        | python-wxWidgets-3_0-lang                                         | 3.0.2.0-lp152.4.8
btw does any package from pip influence on the behavior of grass ?
Here is the full error message
GRASS 7.8.4 (nc_spm_08_grass7):~ > g.extension extension=r.neighborhoodmatrix
Fetching <r.neighborhoodmatrix> from GRASS GIS Addons repository (be
patient)...
Compiling...
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld : /usr/lib64/libgdal.so.28 : référence indéfinie vers « opj_encoder_set_extra_options »
collect2: error: ld returned 1 exit status
make: *** [/usr/lib64/grass78/include/Make/Module.make:18: /tmp/grass7-cyril.gainon-13653/tmpsqayrj_1/r.neighborhoodmatrix/bin/r.neighborhoodmatrix] Error 1
ERREUR : Compilation failed, sorry. Please check above error messages.
(please keep the list in CC so that all can contribute/benefit)
On Thu, May 6, 2021 at 11:27 AM Cyril Gainon <gainon.cyril at hotmail.fr> wrote:
> Hello Markus,
> First thanks for your reactivity.
> I thought i mentioned it at the end of my mail. I'm currently using OpenSuse Leap 15.2, both error are on the same computer.
I see. I was just confused about
> And when i try to install it via sudo apt-get install wxPython
Isn't it zypper on OpenSuse?
> I checked the wiki page you linked, and it seems that i already have the package, maybe as you said lower i have some conflict.
Please send the list of wxpython related packages which are installed.
Now to your separate g.extension problem:
> GDAL work fines, i just used gdalwarp 2 min ago.
OK, good.
> So now, how can i see there is a conflict and how can i fix it ?
No idea. I just tried here:
GRASS nc_spm_08_grass7/user1:~ > g.extension extension=r.neighborhoodmatrix
patient)...
Compiling...
main.c: In function ‘main’:
main.c:83:28: warning: unused variable ‘nbp_search’ [-Wunused-variable]
   83 |     struct nbp *nbp_found, nbp_search, *nbp_new;
main.c:66:9: warning: unused variable ‘i’ [-Wunused-variable]
   66 |     int i;
At top level:
main.c:47:13: warning: ‘free_pavl_item’ defined but not used [-Wunused-function]
   47 | static void free_pavl_item(void *p)
Installing...
Updating extensions metadata file...
Updating extension modules metadata file...
Installation of <r.neighborhoodmatrix> successfully finished
The compile warnings are not dramatic and unrelated. Perhaps you can
send the entire error message to better understand.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/c1866483/attachment-0001.html>
