[GRASS-user] GRASS GIS 7.8.5 v.distance
    Kelsey Wong
    kelsey.wong at shaw.ca
    Thu May 13 13:33:34 PDT 2021
Hi Stefan,
Thank you so much - that solved my entire problem!
Cheers,
Kelsey
> On May 13, 2021, at 1:04 PM, Stefan Blumentrath <Stefan.Blumentrath at nina.no> wrote:
> Hi Kelsey,
> Try: "from_"
> So,
> gs.run_command('v.distance',
>    from_ = 'buildings',
>    to = 'mappedStreams',
> The problem is indeed that from is a keyword...
> Cheers
> Stefan
> -----Original Message-----
> From: grass-user <grass-user-bounces at lists.osgeo.org <mailto:grass-user-bounces at lists.osgeo.org>> On Behalf Of Kelsey Wong
> Sent: torsdag 13. mai 2021 21:32
> To: grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> Subject: [GRASS-user] GRASS GIS 7.8.5 v.distance
> Hi,
> I am trying to use the v.distance function in GRASS GIS 7.8.5, however, it won't accept 'from' as a parameter as it's a python keyword (I think). When I use 'FROM' I get an error saying:
> WARNING: Illegal filename <FROM=buildings>. Character <=> not allowed.
> ERROR: Vector map <FROM=buildings> not found
> This is the code I'm trying to run:
>    FROM = 'buildings',
>    upload = 'to_attr',
>    column = 'stream_id',
>    to_column = 'OBJECTID',
>    output = 'distanceLines',
>    overwrite = True)
> Any help would be greatly appreciated.
> Thanks!
> grass-user mailing list
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user&data=04%7C01%7C%7C8d24cded0189434d8cc708d91646e043%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637565316357978059%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=Wi6V%2FnzJQvTKzyUf0oK6q18d0MOMI%2FPOrLbNms2BfZQ%3D&reserved=0 <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user&data=04%7C01%7C%7C8d24cded0189434d8cc708d91646e043%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637565316357978059%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=Wi6V%2FnzJQvTKzyUf0oK6q18d0MOMI%2FPOrLbNms2BfZQ%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210513/b1c89c41/attachment-0001.html>
