[GRASS-user] GRASS GIS 7.8.5 r.water.outlet
Stefan Blumentrath Stefan.Blumentrath at nina.no
Wed May 19 12:24:53 PDT 2021
Hi Kelesy,
In addition to Michas very good suggestions you can try the table module in pygrass: https://grass.osgeo.org/grass78/manuals/libpython/pygrass.vector.html?highlight=table#module-pygrass.vector.table
Or the db_select module from the scripting library: https://grass.osgeo.org/grass78/manuals/libpython/script.html?highlight=select#script.db.db_select for all kind of tables
Or the vector_db_select module: https://grass.osgeo.org/grass78/manuals/libpython/script.html?highlight=select#script.vector.vector_db_select for tables connected to vector maps
To get the coordinates in Python...
Cheers
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Kelsey Wong
Sent: onsdag 19. mai 2021 20:52
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] GRASS GIS 7.8.5 r.water.outlet
I am trying to use the r.water.outlet function in a python script in GRASS. For the 'coordinates' parameter my x,y coordinate values are stored in two columns in the attribute table of another layer. Is there a way to access these values from the attribute table directly?
Thanks,
Kelsey
grass-user mailing list
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user&data=04%7C01%7C%7Cd2729cbc538a4733864908d91af73bb6%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637570471438665050%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=OrVazRa4Mkas0DxUkYtb8i0lfHwFul06zoYFzxO0Dhs%3D&reserved=0
