[GRASS-user] gui not working in 7.9 after debian uprade to bullseye
    Frank David
    frank.david at geophom.fr
    Thu Nov 18 00:45:51 PST 2021
Hello,
I have upgraded my distro from debian buster to bullseye. I had two
grass release installed installed : 1- grass 7.8.5 from repository,
still works fine. 2- a grass 7.9 compiled. When I run this one I get
this message :
Lancement de l'interface graphique <wxpython> en tâche de fond, merci de
patienter ...
GRASS 7.9.dev (France_L93):~ > free(): double free detected in tcache 2
Impossible de déterminer la version de GRASS
   File "/usr/local/grass79/scripts/g.extension", line 2177, in <module>
     version = grass_version['version'].split('.')
KeyError: 'version'
   File "/usr/local/grass79/gui/wxpython/wxgui.py", line 106, in OnInit
     mainframe = GMFrame(parent=None, id=wx.ID_ANY,
   File "/usr/local/grass79/gui/wxpython/lmgr/frame.py", line 143, in
__init__
     self.notebook = self._createNoteBook()
   File "/usr/local/grass79/gui/wxpython/lmgr/frame.py", line 337, in
_createNoteBook
     self.goutput = GConsoleWindow(
   File "/usr/local/grass79/gui/wxpython/gui_core/goutput.py", line 118,
in __init__
     self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
   File "/usr/local/grass79/gui/wxpython/gui_core/prompt.py", line 138,
in __init__
     GPrompt.__init__(self, parent=parent, menuModel=menuModel)
   File "/usr/local/grass79/gui/wxpython/gui_core/prompt.py", line 56,
in __init__
     self.mapList = self._getListOfMaps()
   File "/usr/local/grass79/gui/wxpython/gui_core/prompt.py", line 100,
in _getListOfMaps
     result['raster'] = grass.list_strings('raster')
   File "/usr/local/grass79/etc/python/grass/script/core.py", line 1347,
in list_strings
     for line in read_command("g.list",
   File "/usr/local/grass79/etc/python/grass/script/core.py", line 565,
in read_command
     return handle_errors(returncode, stdout, args, kwargs)
   File "/usr/local/grass79/etc/python/grass/script/core.py", line 392,
in handle_errors
     raise CalledModuleError(module=module, code=code,
grass.exceptions.CalledModuleError: Module run g.list g.list --q -m
type=raster ended with error
Process ended with non-zero return code -6. See errors in the (error)
output.
OnInit returned false, exiting...
Error in atexit._run_exitfuncs:
wx._core.wxAssertionError: C++ assertion "GetEventHandler() == this"
failed at ../src/common/wincmn.cpp(477) in ~wxWindowBase(): any pushed
event handlers must have been removed
Do you have an idea to solve this problem ?
Thank you
Frank
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211118/d2d71b73/attachment.html>
