[GRASS-user] gui not working in 7.9 after debian uprade to bullseye
Frank David frank.david at geophom.fr
Thu Nov 18 05:54:53 PST 2021
Hi Vero,
Thanks for your reply.
Shall I do "Make distclean" from the folder where I have built grass7.9 ?
I get :
/sudo make distclean//
//include/Make/Vars.make:1: include/Make/Platform.make: Aucun fichier ou
dossier de ce type//
//make: *** Aucune règle pour fabriquer la cible
« include/Make/Platform.make ». Arrêt./
Something seems wrong ??
For the moment I prefer to keep on 7.9, but if I can't manage to repair
7.9 I will go to 8.0.
Cheers,
Frank
Le 18/11/2021 à 13:22, Veronica Andreo a écrit :
> Hi Frank,
> Did you `make distclean`, configure and recompile your grass79 after
> the system upgrade?
> Also, maybe update your local copy as there have been changes.
> So, if you only did a simple git clone to get the source code and
> compile, then:
> make distclean
> git fetch --all --prune && git checkout main && git pull && sh
> conf_grass_dev.sh && make
> ## Note we now also have a releasebranch_8_0 :)
> ## conf_grass_dev.sh is my configuration script
> my 0.2 cents
> Vero
> El jue, 18 nov 2021 a las 9:56, Frank David (<frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>>) escribió:
>     Hello,
>     I have upgraded my distro from debian buster to bullseye. I had
>     two grass release installed installed : 1- grass 7.8.5 from
>     repository, still works fine. 2- a grass 7.9 compiled. When I run
>     this one I get this message :
>     Lancement de l'interface graphique <wxpython> en tâche de fond,
>     merci de patienter ...
>     GRASS 7.9.dev <http://7.9.dev> (France_L93):~ > free(): double
>     free detected in tcache 2
>     Impossible de déterminer la version de GRASS
>     free(): double free detected in tcache 2
>     Traceback (most recent call last):
>       File "/usr/local/grass79/scripts/g.extension", line 2177, in
>     <module>
>         version = grass_version['version'].split('.')
>     KeyError: 'version'
>       File "/usr/local/grass79/gui/wxpython/wxgui.py", line 106, in OnInit
>         mainframe = GMFrame(parent=None, id=wx.ID_ANY,
>       File "/usr/local/grass79/gui/wxpython/lmgr/frame.py", line 143,
>     in __init__
>         self.notebook = self._createNoteBook()
>       File "/usr/local/grass79/gui/wxpython/lmgr/frame.py", line 337,
>     in _createNoteBook
>         self.goutput = GConsoleWindow(
>       File "/usr/local/grass79/gui/wxpython/gui_core/goutput.py", line
>     118, in __init__
>         self.cmdPrompt = GPromptSTC(parent=self,
>     menuModel=self._menuModel)
>       File "/usr/local/grass79/gui/wxpython/gui_core/prompt.py", line
>     138, in __init__
>         GPrompt.__init__(self, parent=parent, menuModel=menuModel)
>     56, in __init__
>         self.mapList = self._getListOfMaps()
>     100, in _getListOfMaps
>         result['raster'] = grass.list_strings('raster')
>       File "/usr/local/grass79/etc/python/grass/script/core.py", line
>     1347, in list_strings
>         for line in read_command("g.list",
>     565, in read_command
>         return handle_errors(returncode, stdout, args, kwargs)
>     392, in handle_errors
>         raise CalledModuleError(module=module, code=code,
>     grass.exceptions.CalledModuleError: Module run g.list g.list --q
>     -m type=raster ended with error
>     Process ended with non-zero return code -6. See errors in the
>     (error) output.
>     OnInit returned false, exiting...
>     Error in atexit._run_exitfuncs:
>     wx._core.wxAssertionError: C++ assertion "GetEventHandler() ==
>     this" failed at ../src/common/wincmn.cpp(477) in ~wxWindowBase():
>     any pushed event handlers must have been removed
>     Do you have an idea to solve this problem ?
>     Thank you
>     Frank
>     _______________________________________________
>     grass-user mailing list
>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/grass-user
>     <https://lists.osgeo.org/mailman/listinfo/grass-user>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211118/ff05f683/attachment-0001.html>
