[GRASS-user] Grass Graphic Model v.net.distance Not Accepting point layer in From or To fields
    Joshua Geoghegan
    joshua.geoghegan at mornpen.vic.gov.au
    Sun Nov 21 13:12:42 PST 2021
Hi there,
I have been stuck on a problem and I was hoping you could help, as I had no luck on GIS Stack Exchange.
I have a point and network layer connected in Grass GIS via the graphic modeler. I am trying to find the shortest path between the first point (ROUND=0) and every other point (ROUND != 0) on the same point layer. For some reason I can select this layer (layer 2) in both From and To tabs and add category 1-500 (which is more than the number of points), but when I try the where clause and test for values in the ROUND field on the SQL Builder the results show up as '', even though the imported shp file has values. When I hit OK and come back into the form it has reverted back to layer 1 in the From and To tabs, which is road network layer.
What could be the issue here?
[enter image description here]<https://i.stack.imgur.com/QV5Lz.jpg>
[enter image description here]<https://i.stack.imgur.com/ecfs6.jpg>
I've tried a number of things without luck. Hopefully you can help.
Regards,
[MPS]
JOSHUA GEOGHEGAN | GIS Specialist
Email: joshua.geoghegan at mornpen.vic.gov.au<mailto:joshua.geoghegan at mornpen.vic.gov.au>
Phone: 03 5950 1321
Private Bag 1000, Rosebud VIC 3939 | 90 Besgrove Street, Rosebud VIC 3939
Follow us on social media!
[mornpen.vic.gov.au]<https://www.mornpen.vic.gov.au/>[Facebook]<https://www.facebook.com/mornpenshire>[Instagram]<https://www.instagram.com/ourpeninsula/>[Twitter]<http://twitter.com/MornPenShire>
[Latest News]<https://www.mornpen.vic.gov.au/emailcampaign>
Mornington Peninsula Shire acknowledges and pays respect to the Bunurong/Boon Wurrung people,
the Traditional Custodians of these lands and waters.
We are committed to carbon neutrality.
DISCLAIMER: This email (and attachments) is for the intended recipient only and may contain privileged, confidential or copyright information. If received in error, please notify sender immediately and delete. Any other use is prohibited. Shire accepts no liability for damage caused by this email (and attachments) due to viruses, corruption, delay, interruption, unauthorised access or use. Views expressed are those of the individual and not necessarily Shire. Shire will only collect personal information from you with your prior consent, use it for the purpose collected or as reasonably expected and not disclose without consent, except if required by law/regulation. For further information see our privacy policy:
[Arrow] mornpen.vic.gov.au/privacystatement<https://www.mornpen.vic.gov.au/privacystatement>
[Consider the Environment]
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0003.jpg>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0004.jpg>
Type: image/gif
Desc: image003.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0005.gif>
Type: image/gif
Desc: image004.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0006.gif>
Type: image/gif
Desc: image005.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0007.gif>
Type: image/gif
Desc: image006.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0008.gif>
Type: image/gif
Desc: image007.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0009.gif>
Type: image/jpeg
Desc: image008.jpg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211121/2b75df47/attachment-0005.jpg>
