[GRASS-user] Raster null values unchanged by r.null
Eric Patton
eric.r.patton at protonmail.com
Fri Oct 29 05:45:24 PDT 2021
Hi Vero,
Where you have a properly working system, would you be able to file that bug report? I've installed Grass 8.0 and I'm still having the rendering issue of null values in the gui.
Eric Sent with [ProtonMail](https://protonmail.com/) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Friday, October 22nd, 2021 at 08:25, Veronica Andreo <veroandreo at gmail.com> wrote:
> Hi Eric,
> I've tested with GRASS 7.8.5, NC location, setting null values with the GUI, refreshing the map display and all works just fine, values set to null are no longer visible.
> What doesn't work for me is removing the null bitmap neither from the GUI nor the terminal (and it does not work in GRASS 7.8.6 nor in 8.0 - this one deserves a bug report).
> My system:
> GRASS version: 7.8.5
> Build date: 2021-02-08
> Build platform: x86_64-redhat-linux-gnu
> GDAL: 3.2.1
> PROJ: 7.2.1
> GEOS: 3.9.0
> SQLite: 3.34.1
> Python: 3.9.7
> wxPython: 4.0.7
> Vero
> El jue, 21 oct 2021 a las 22:00, Eric Patton via grass-user (<grass-user at lists.osgeo.org>) escribió:
>> Hi Ken,
>> This is on a native Grass raster, not through a file linked by r.external. It seems to be some problem with the rendering/refreshing in the WXGUI.
>> ~ Eric.
>> Sent from ProtonMail for iOS
>> On Wed, Oct 20, 2021 at 6:43 PM, Ken Mankoff <mankoff at gmail.com> wrote:
>>> I think r.null does not work on external (r.external) files. Make sure this is not the issue.
>>> Please excuse brevity. Sent from tiny pocket computer with non-haptic feedback keyboard.
>>> On Wed, Oct 20, 2021, 07:02 Eric Patton via grass-user <grass-user at lists.osgeo.org> wrote:
>>>> I'm encountering some strange behaviour from r.null - when I use the setnull parameter to assign a particular value to be null in a raster, the raster areas just set to null are still visible and coloured according to their previous values when I refresh the display in the gui map window. Querying these values shows they haven't been set to null.
>>>> Using version 7.8.5 on Linux Mint. Can anyone confirm?
>>>> Eric
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211029/13e8723a/attachment.html>
