[GRASS-user] Start grass, create new mapset
Micha Silver tsvibar at gmail.com
Wed Sep 22 09:21:20 PDT 2021
Hi Moritz:
On 9/22/21 4:20 PM, Moritz Lennert wrote:
> Le 22 septembre 2021 14:40:45 GMT+02:00, Rich Shepard
> <rshepard at appl-ecosys.com> a écrit :
>> On Wed, 22 Sep 2021, Moritz Lennert wrote:
> I also see that the description of the -c flag itself only speaks
> about locations, not mapsets. This should also be changed. Something
> in the direction of:
> "-c
> Creates new GRASS unprojected location in specified GISDBASE"
> [no idea why it says 'unprojected' must be long-term legacy]
I think the reason here stems from the un-desirable case of creating a
location without specifying any projection details (neither EPSG code
nor a georeferenced file) then you'll get a more or less unusable
Location. You will have to start manually to setup the Location's
projection. What's more, I think that using the -c option to create a
location and mapset in one go does not work. You will always get a
Location with only the PERMANENT mapset:
grass -text -c EPSG:32632 /home/micha/GIS/grass/UTM33/micha
micha at RMS:Downloads$ g.mapsets -p
Accessible mapsets:
PERMANENT
(No mapset "micha")
The best approach is to do it in two stages:
 1. Create the Location (using an EPSG code or georeferenced file) . You
    can add the -e option to exit immediately
 2. Then restart grass with -c again to create the mapset, with the full
    path.
> should become
> "-c
> Creates new GRASS location or mapset respectively in specified
> GISDBASE or location"
> [if this is not too long]
> Moritz
>> Regards,
>> Rich
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
