[GRASS-user] Startup issue: defaults to one mapset [RESOLVED]
Micha Silver tsvibar at gmail.com
Wed Sep 22 12:17:23 PDT 2021
On 9/22/21 8:57 PM, Rich Shepard wrote:
> On Wed, 22 Sep 2021, Rich Shepard wrote:
>> Where do I look to find what's going on so I can fix it?
I don't think there is anything to fix:
At startup GRASS does not care about current working directory.
The default LOCATION/MAPSET is read from the ~/.grass7/rc file. Here on
my system:
micha at RMS:~$ cat ~/.grass7/rc
GISDBASE: /home/micha/GIS/grass
LOCATION_NAME: ITM
MAPSET: Arava
GUI: wxpython
DEBUG: 0
If you want to start GRASS from some other LOCATION/MAPSET you just add
the full path to the different MAPSET on the command line, as you showed
below.
Never hurts to review:
https://grass.osgeo.org/grass78/manuals/grass7.html
especially:
    EXAMPLES
The following are some examples of how you could start GRASS
*grass78*
    Start GRASS using the default user interface. The user will be
    prompted to choose the appropriate location and mapset.
*grass78 --gui*
    Start GRASS using the graphical user interface. The user will be
*grass78 --text*
    Start GRASS using the text-based user interface. Appropriate
    location and mapset must be set by environmental variables (see
    examples below) otherwise taken from the last GRASS session.
*grass78 --gtext*
    Start GRASS using the text-based user interface. The user will be
*grass78 $HOME/grassdata/spearfish70/user1*
> What I'm now doing to start grass from /data/grassdata is:
> grass /data/grassdata/<location>/<mapset>
> It works.
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
