[GRASS-user] Imported .tif maps lose all data
    Carlos Henrique Grohmann de Carvalho
    carlos.grohmann at gmail.com
    Sat Sep 25 11:16:15 PDT 2021
Rich
I believe r.in.gdal will require the region to match each of the tifs
you're importing. Try using r.import with the option extent set to "input",
so it won't do region cropping
C
On Sat, Sep 25, 2021 at 1:43 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Sat, 25 Sep 2021, Carlos Henrique Grohmann de Carvalho wrote:
> > How is your region settings? Do they match the DEMs? Maybe importing with
> > r.import will help, as it can override region settings
> Carlos,
> Initially it was the default region. But, I changed the region to a test
> map, dtm_35, and re-ran r.report and r.stats. There's still no data in any
> of the cells.
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210925/69ca1f81/attachment.html>
