[GRASS-user] imported .tif maps lose all data
Helmut Kudrnovsky
hellik at web.de
Sat Sep 25 11:19:07 PDT 2021
>>The data file sizes are all in the low 100Ks. I could upload an example to
>>fileconvoy.com if that's helpful.
>could you make one of the data files available?
>Helmut
for me it works
Driver: GTiff/GeoTIFF
Files: columbia_2010_e_dtm_35.tif
Size is 10745, 15264
Coordinate System is:
PROJCRS["NAD_1983_HARN_StatePlane_Washington_South_FIPS_4602_Feet",
BASEGEOGCRS["GCS_North_American_1983_HARN",
DATUM["North_American_1983_HARN",
ELLIPSOID["GRS_1980",6378137,298.257222101,
LENGTHUNIT["metre",1,
ID["EPSG",9001]]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433,
ID["EPSG",9122]]]],
CONVERSION["Lambert Conic Conformal (2SP)",
METHOD["Lambert Conic Conformal (2SP)",
ID["EPSG",9802]],
PARAMETER["Latitude of false origin",45.3333333333333,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8821]],
PARAMETER["Longitude of false origin",-120.5,
ID["EPSG",8822]],
PARAMETER["Latitude of 1st standard parallel",45.8333333333333,
ID["EPSG",8823]],
PARAMETER["Latitude of 2nd standard parallel",47.3333333333333,
ID["EPSG",8824]],
PARAMETER["Easting at false origin",500000,
LENGTHUNIT["metre",1],
ID["EPSG",8826]],
PARAMETER["Northing at false origin",0,
ID["EPSG",8827]]],
CS[Cartesian,2],
AXIS["easting",east,
ORDER[1],
LENGTHUNIT["US survey foot",0.304800609601219,
ID["EPSG",9003]]],
AXIS["northing",north,
ORDER[2],
ID["EPSG",9003]]]]
Data axis to CRS axis mapping: 1,2
Origin = (1512164.000000000000000,152311.000000000000000)
Pixel Size = (3.000000000000000,-3.000000000000000)
Metadata:
AREA_OR_POINT=Area
DataType=Generic
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 1512164.000, 152311.000) (121d 0' 8.57"W, 45d44'59.58"N)
Lower Left ( 1512164.000, 106519.000) (121d 0' 4.46"W, 45d37'27.52"N)
Upper Right ( 1544399.000, 152311.000) (120d52'34.01"W, 45d45' 1.35"N)
Lower Right ( 1544399.000, 106519.000) (120d52'30.94"W, 45d37'29.29"N)
Center ( 1528281.500, 129415.000) (120d56'19.49"W, 45d41'14.50"N)
Band 1 Block=512x256 Type=Float32, ColorInterp=Gray
Min=159.316 Max=1037.520
Minimum=159.316, Maximum=1037.520, Mean=262.041, StdDev=157.494
NoData Value=-3.40282306073709653e+38
Overviews: 5373x7632, 2687x3816, 1344x1908, 672x954, 336x477, 168x239
Metadata:
BandName=Band_1
RepresentationType=ATHEMATIC
STATISTICS_COVARIANCES=24804.31297971113
STATISTICS_MAXIMUM=1037.5201416016
STATISTICS_MEAN=262.04051816209
STATISTICS_MINIMUM=159.31565856934
STATISTICS_SKIPFACTORX=1
STATISTICS_SKIPFACTORY=1
STATISTICS_STDDEV=157.49385060919
D:\wd\testgpkg>grass78 -e -c columbia_2010_e_dtm_35.tif D:\grassdata\rastertest
Starting GRASS GIS...
Creating new GRASS GIS location <rastertest>...
WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
nicht möglich.
Cleaning up temporary files...
g.region -p
projection: 99 (NAD83(HARN) / Washington South (ftUS))
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: grs80
north: 152311
south: 106519
west: 1512164
east: 1544399
nsres: 3
ewres: 3
rows: 15264
cols: 10745
cells: 164011680
r.in.gdal input=D:\wd\testgpkg\columbia_2010_e_dtm_35.tif output=columbia_2010_e_dtm_35
WARNING: Datum <North_American_1983_HARN> von GRASS nicht erkannt und keine Parameter gefunden.
Importing raster map <columbia_2010_e_dtm_35>...
g.region -p -a raster=columbia_2010_e_dtm_35 at data align=columbia_2010_e_dtm_35 at data
zone: 0
ellipsoid: grs80
north: 152311
south: 106519
west: 1512164
east: 1544399
nsres: 3
ewres: 3
rows: 15264
cols: 10745
cells: 164011680
r.stats -l input=columbia_2010_e_dtm_35 at data
159.315659-162.759598 from to
162.759598-166.203537 from to
166.203537-169.647476 from to
169.647476-173.091415 from to
173.091415-176.535354 from to
176.535354-179.979293 from to
179.979293-183.423233 from to
183.423233-186.867172 from to
r.report map=columbia_2010_e_dtm_35 at data
| RASTER MAP CATEGORY REPORT |
| north: 152311 east: 1544399 |
|REGION south: 106519 west: 1512164 |
| res: 3 res: 3 |
|MASK: none |
|MAP: (untitled) (columbia_2010_e_dtm_35 at data in data) |
| Category Information |
| #|description |
| 159.315659-162.759598|from to |
| 162.759598-166.203537|from to |
| 166.203537-169.647476|from to |
| 169.647476-173.091415|from to |
| 173.091415-176.535354|from to |
| 176.535354-179.979293|from to |
| 179.979293-183.423233|from to |
| 183.423233-186.867172|from to |
| 186.867172-190.311111|from to |
| 190.311111-193.75505|from to |
| 193.75505-197.198989|from to |
| 197.198989-200.642928|from to
Helmut
