[GRASS-user] GRASS 8.0.dev not reading .shp file
Rich Shepard
rshepard at appl-ecosys.com
Wed Sep 29 12:32:29 PDT 2021
I created a new location using the .prj file for cross-section contour lines
and successfully input CL_33_LDYX_20210712_CS_contour_lines.shp. When I
tried to input the sounding points file (CL_33_LDYX_20210712_CS_sounding_points.shp)
GRASS responded:
ERROR: Unable to open data source
<projects/washington/project/data/bathymetry/coe/cross-line/CL_33_LDYX_20210712_CS_sounding_points.shp>
The sounding points .shp file is an ESRI Shapefile version 1000 length 19168 type
PointZ and 38336 bytes in lengh.
What might cause GRASS to read one .shp file in a directory but not another
.shp file in the same directory?
I am seeing this 'unable to read file' error frequently these past few days.
TIA,
Rich
