[GRASS-user] Create location fails in docker
Margherita Di Leo
diregola at gmail.com
Wed Sep 29 12:32:26 PDT 2021
I need to run GRASS in a docker image but I have issues apparently about
permissions.
My docker image is built on a dockerfile:
FROM ubuntu:20.04
ENV DEBIAN_FRONTEND noninteractive
ENV DATA_DIR /data
RUN apt-get update \
&& apt-get install -y --no-install-recommends --no-install-suggests \
build-essential \
libblas-dev \
libbz2-dev \
libcairo2-dev \
libfftw3-dev \
libfreetype6-dev \
libgdal-dev \
libgeos-dev \
libglu1-mesa-dev \
libgsl0-dev \
libjpeg-dev \
liblapack-dev \
libncurses5-dev \
libnetcdf-dev \
libopenjp2-7 \
libopenjp2-7-dev \
libpdal-dev pdal \
libpdal-plugin-python \
libpng-dev \
libpq-dev \
libproj-dev \
libreadline-dev \
libsqlite3-dev \
libtiff-dev \
libxmu-dev \
libzstd-dev \
bison \
flex \
g++ \
gettext \
gdal-bin \
grass \
grass-core \
grass-dev \
libfftw3-bin \
make \
ncurses-bin \
netcdf-bin \
proj-bin \
proj-data \
python3 \
python3-dev \
python3-geopandas \
python3-numpy \
python3-pandas \
python3-pil \
python3-ply \
python3-six \
sqlite3 \
subversion \
unixodbc-dev \
zlib1g-dev \
&& apt-get autoremove \
&& apt-get clean && \
mkdir -p $DATA_DIR
ENV SHELL /bin/bash
# permissions
RUN chmod -R a+rwx $DATA_DIR
# create user
RUN useradd -m -U digitranscope
VOLUME $DATA_DIR
WORKDIR $DATA_DIR
# switch user
USER digitranscope
CMD ["grass", "--version"]
Then, from a bash script I try to create a location and exit, but it seems
to fail on this:
grass --text -c EPSG:4326 $GRASSDATA\/france -e
The error message:
File "/usr/bin/grass", line 390, in get_grass_config_dir
os.mkdir(directory)
PermissionError: [Errno 13] Permission denied: '/.grass7'
During handling of the above exception, another exception occurred:
File "/usr/bin/grass", line 2218, in <module>
main()
File "/usr/bin/grass", line 2001, in main
grass_config_dir = get_grass_config_dir()
File "/usr/bin/grass", line 395, in get_grass_config_dir
_("Failed to create configuration directory '%s' with error: %s")
NameError: name '_' is not defined
os.mkdir(directory)
What could be the problem?
Thanks in advance
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210929/7de65aa5/attachment.html>
