[GRASS-user] Create location fails in docker
Moritz Lennert mlennert at club.worldonline.be
Thu Sep 30 01:49:26 PDT 2021
Hi Madi,
Am 30.09.2021 09:46 schrieb Margherita Di Leo:
> Hi again,
> I try to reformulate my question:
> On Wed, Sep 29, 2021 at 9:32 PM Margherita Di Leo <diregola at gmail.com>
> wrote:
>> grass --text -c EPSG:4326 $GRASSDATA/france -e
>> The error message:
>> Traceback (most recent call last):
>> File "/usr/bin/grass", line 390, in get_grass_config_dir
>> os.mkdir(directory)
>> PermissionError: [Errno 13] Permission denied: '/.grass7'
>> During handling of the above exception, another exception occurred:
>> File "/usr/bin/grass", line 2218, in <module>
>> main()
>> File "/usr/bin/grass", line 2001, in main
>> grass_config_dir = get_grass_config_dir()
>> File "/usr/bin/grass", line 395, in get_grass_config_dir
>> _("Failed to create configuration directory '%s' with error:
>> %s")
>> NameError: name '_' is not defined
>> os.mkdir(directory)
> What does this error message mean? Why is it trying to write in the
> /.grass7 folder ?
Whenever you launch GRASS GIS with the grass startup script, it writes
the chosen Gisdbase/Location/Mapset info into .grass7/rc. If you launch
GRASS GIS for the first time, it first creates the directory .grass7
which is the part that fails with a permission error.
I'm no Docker expert at all, but I think you have to explicitly run the
container with parameters indicating the devices one can access from
within.
> And what does the name '_' refer to?
This seems to be linked to the translation handling:
>> %s")
Note the '_' in front of the string which marks it as a translatable
string.
There was a bug related to this a while ago, but it was fixed
(https://trac.osgeo.org/grass/ticket/3875). Maybe a locale issue ?
Moritz
