[GRASS-user] GRASS 8.0.dev not reading .shp file
Maris Nartiss
maris.gis at gmail.com
Thu Sep 30 05:08:22 PDT 2021
Check the file with ogr: ogrinfo -ro -so path/to/file_name.shp file_name
Māris.
2021-09-29 22:32 GMT+03:00, Rich Shepard <rshepard at appl-ecosys.com>:
> I created a new location using the .prj file for cross-section contour
> lines
> and successfully input CL_33_LDYX_20210712_CS_contour_lines.shp. When I
> tried to input the sounding points file
> (CL_33_LDYX_20210712_CS_sounding_points.shp)
> GRASS responded:
> ERROR: Unable to open data source
> <projects/washington/project/data/bathymetry/coe/cross-line/CL_33_LDYX_20210712_CS_sounding_points.shp>
> The sounding points .shp file is an ESRI Shapefile version 1000 length 19168
> type
> PointZ and 38336 bytes in lengh.
> What might cause GRASS to read one .shp file in a directory but not another
> .shp file in the same directory?
> I am seeing this 'unable to read file' error frequently these past few
> days.
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
