[GRASS-user] r.mapcalc.tiled and mapset
Anna Petrášová
kratochanna at gmail.com
Wed Aug 24 14:31:25 PDT 2022
That is probably a bug in GridModule, please open an issue,
Thanks, Anna
On Fri, Aug 19, 2022, 12:45 PM Frank David <frank.david at geophom.fr> wrote:
> Hello,
> When I use r.mapcalc.tiled, all the mapsets become available from the
> working mapset.
> example : r.mapcalc.tiled expression="test=1" process=8
> Is there any reason ?
> I'm using grass 7.8
> Thank you for your help.
> Frank
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220824/b24e4992/attachment.htm>
