[GRASS-user] Export raster to PostGIS
Maris Nartiss maris.gis at gmail.com
Fri Aug 26 12:22:25 PDT 2022
As r.out.gdal uses GDAL library, it is bound to GDAL limitations.
According to the GDAL PG documentation, PG rasters are read-only:
https://gdal.org/drivers/raster/postgisraster.html#raster-postgisraster
Thus you can read but can not write PG rasters with GDAL.
Māris.
piektd., 2022. g. 26. aug., plkst. 10:48 — lietotājs Asim via
grass-user (<grass-user at lists.osgeo.org>) rakstīja:
> Hello
> Is it possible to export a raster map created using r.water.outlet to PostGIS in GRASS 78?  The documentation indicates using r.out.gdal with PostGISRaster as format.  The command I'm trying is the following:
>    r.out.gdal input=mywatershed format=PostGISRaster output=mywatershed createopt="PG:dbname='mydb'"
> The postgresql server is running with locally and the database "mydb" can be accessed without having to enter a password using psql client.  However, this command fails with the error:
>    ERROR 6: PostGISRasterDataset::CreateCopy() only works on source datasets that are PostGISRaster
> Is something wrong in the command?  The error message seems to suggest that it is impossible to export the raster map created with r.water.outlet to PostGIS because it is not sourced from PostGIS.  Can someone please confirm?
> Asim
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
