[GRASS-user] GRASS GIS 8.0.0 Stand Alone
Martin Bittens
martin.bittens at gmx.de
Tue Feb 8 02:56:37 PST 2022
Hello Anna,
thanks a lot for your fast reply.
I got the GRASS GIS stand alone installer from "
https://grass.osgeo.org/download/windows/#standalone-installers ". The
provided file there is "
https://grass.osgeo.org/grass80/binary/mswindows/native/WinGRASS-8.0.0-1-Setup.exe
" which installs " GRASS GIS 8.0.0dev (04e3de8fa)". I did not see any
installation file for " GRASS GIS 8.0.0 ". From where I can get tat one?
Regards
Martin
Am 2/8/2022 um 2:35 AM schrieb Anna Petrášová:
> Hi Martin,
> please create an issue:
> https://github.com/OSGeo/grass/issues/new/choose
> Indeed, looks like the URL on the server doesn't match the url
> g.extension expects. Note that you are using a daily build, you may
> want to consider using released GRASS 8.0.0.
> Anna
> On Mon, Feb 7, 2022 at 2:57 PM Martin Bittens <martin.bittens at gmx.de>
> wrote:
> Hello GRASS User,
> here comes an update concerning the installation of GRASS GIS addons:
> In the meantime I could change the addon-download link provided by
> GRASS. Using some of the 'recipes' I found in the internet I
> manipulated
> the g.extension.py <http://g.extension.py> file in line 1442 by
> adding " patch='dev' " and
> deactivating " patch=version[2] ". As a result, GRASS GIS is now
> calling
> '/grass80/addons/grass-8.0.dev <http://grass-8.0.dev>' for the
> download of addons. It´s not a
> very professional solution because each time when the addon's web site
> changing its address (what happens as far as I know with each GRASS
> update) I have to made the respective adjustment in g.extension.py
> <http://g.extension.py>. But
> for know it is working.
> But...! The addon installation is obviously working only for addons
> which are based on python scripts (e.g., v.centerline.py
> <http://v.centerline.py>). Addons which
> come with an exe-file are being installed with error messages and
> don´t
> work:
> g.extension extension=v.centerpoint operation=add
> Downloading precompiled GRASS Addons <v.centerpoint>...
> Fetching <v.centerpoint> from
> <http://wingrass.fsv.cvut.cz/grass80/addons/grass-8.0.dev/v.centerpoint.zip>
> (be patient)...
> Updating extensions metadata file...
> Updating extension modules metadata file...
> WARNING: No metadata available for module 'v.centerpoint': Unable to
> fetch interface description for command '<v.centerpoint>'.
> Details: <C:\Program Files\GRASS GIS 8.0\extrabin\python3.exe: can't
> find '__main__' module in
> 'C:\\Users\\Martin\\AppData\\Local\\Temp\\grass8-Martin-25356\\tmpc6exzl8p\\v.centerpoint'
> Installation of <v.centerpoint> successfully finished
> (Mon Feb 7 16:49:42 2022) Command finished (19 sec)
> So, what is the correct way for installing the GRASS GIS addons?
> Regards
> Martin
> Am 2/7/2022 um 11:45 AM schrieb Martin Bittens:
> > Hello GRASS User,
> > I just installed the latest GRASS GIS Stand Alone version
> (8.0.0). When
> > I tried installing some addons I always received an error message:
> > ERROR: Cannot open URL:
> http://wingrass.fsv.cvut.cz/grass80/addons/grass-8.0.0dev/v.centerpoint.zip
> > I checked the web site and could the that there only exist 2
> versions:
> > - /grass80/addons/grass-8.0.dev <http://grass-8.0.dev>
> > - /grass80/addons/grass-8.0.0
> > How I can change the web address GRASS GIS is calling to the
> ones which
> > are providing the addons?
> > Thank you very much for a suggestion.
> > Regards
> > Martin
> > This email has been checked for viruses by Avast antivirus software.
> > https://www.avast.com/antivirus
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220208/73e3295e/attachment-0001.html>
