[GRASS-user] single window gui in main branch
Veronica Andreo veroandreo at gmail.com
Tue Jan 11 16:31:09 PST 2022
Hi Anna,
It was indeed not there but I now know why. I updated and compiled today
but in this laptop I have not set remotes properly, so the code revision I
got (563797cd3) is older than when you merged the single window option.
Apologies for the noise 🙆
I have set the remotes correctly, updated, re-compiled and there it is!!!
yay!! I love it! 😍
Vero
ps: Indeed, maybe a tab Single-window would be much more visible and would
highlight the feature more.
El mar, 11 ene 2022 a las 20:56, Anna Petrášová (<kratochanna at gmail.com>)
escribió:
> Hi Vero,
> I added the screenshot to the original PR:
> https://github.com/OSGeo/grass/pull/1810
> Maybe you overlooked it? The place may not be ideal for it...
> On Tue, Jan 11, 2022 at 1:16 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hello everyone,
>> Now that single window is merged into main branch I'd like to test :)
>> Where's the switch? I just updated and compiled main branch and went
>> through all tabs and options in the settings?preferences menu from the GUI,
>> but I could not find anything saying single window something. What am I
>> doing wrong here?
>> Can this be related to
>> https://github.com/OSGeo/grass/blob/f57940e8a096c593f23b2ce3f9653547f24b8e92/gui/wxpython/core/settings.py#L156
>> been set to False? Shall I change that to True to make it appear/work?
>> Build info
>> GRASS version: 8.0.dev
>> Code revision: 563797cd3
>> Build date: 2022-01-11
>> Thanks much,
>> Vero
>> Dra. Verónica Andreo
>> Investigadora Asistente de CONICET
>> Instituto Gulich (CONAE - UNC)
>> Centro Espacial Teófilo Tabanera (CETT)
>> Falda del Cañete - Córdoba, Argentina
>> +54 3547 400000 int. 1153
>> https://veroandreo.gitlab.io/
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220112/421e8699/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220112/421e8699/attachment-0001.png>
