[GRASS-user] Trouble calling R from GRASS on Mac
Nicklas Larsson n_larsson at yahoo.com
Mon Jan 17 00:18:58 PST 2022
Tom,
There is a limitation presently in the GRASS-X.X.app startup script, i.e. forcing the user into a bash session and resetting of PATH. I hope to fix this in future releases. However, that doesn't place us in a helpless situation.
Assuming you start GRASS in Finder: (1) start GRASS session, (2) in Terminal enter
"open /Applications/R.app" for R GUI version or
"/usr/local/bin/R" for R command line version.
If you wish to stay in zsh, then start GRASS in Terminal with: "/Applications/GRASS-7.8.app/Contents/Resources/bin/grass78". Then open R in the same way as above
If the second alternative is the more appealing, you may wish to simplify by making a GRASS link to /usr/local/bin:
"sudo ln -s /Applications/GRASS-7.8.app/Contents/Resources/bin/grass78 /usr/local/bin/ grass78".
Assuming you have /usr/local/bin/ in your path, then entering "grass78" alternatively "grass78 --gui" in Terminal is all you need to start GRASS.
Best,
Nicklas
On Monday, 17 January 2022, 02:29:59 CET, Veronica Andreo <veroandreo at gmail.com> wrote:
Any Mac user that can assist here, please?
Thomas, maybe you can also subscribe and write to grass-stats mailing list: https://lists.osgeo.org/mailman/listinfo/grass-stats
Sorry for not being of much help with this
Best
Vero
El dom, 16 ene 2022 a las 2:28, Thomas Adams (<tea3rd at gmail.com>) escribió:
> Hi all!
> I have R (latest) and GRASS 7.8.6 installed on my Mac. Both R and GRASS launch fine from the GUIs. I can launch R from the default Mac zsh terminal window, but R will not launch from the GRASS bash shell… however, at a zsh prompt, I can startup bash, and R launches as expected fmo the bash prompt.
> So, how do I get the settings right to be able to launch R from the GRASS bash terminal — this has never been a problem for me with my Ubuntu installations
> Suggestions are appreciated… thank you.
> Tom
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
