[GRASS-user] Single GUI window in 8.0.0RC2?
Veronica Andreo veroandreo at gmail.com
Fri Jan 21 12:54:57 PST 2022
Oh, sorry that I wasn't explicit enough.
I meant the appearance in your operative system. In my fedora box is under
Applications or Start  --> settings --> appearance, and there, in the Style
tab, I see adwaita, adwaita dark and such... Once you pick one of the dark
themes among the options, grass will get it too :)
[image: image.png]
El vie., 21 ene. 2022 17:20, Eric Patton <eric.r.patton at protonmail.com>
escribió:
> Hi Vero,
> Did you mean the Appearance tab under GUI settings? There is nothing
> controlling color in this tab that I see, but under the Map Display tab,
> there is the background color selector. Changing that only changes the
> background of the map display window, not the GUI toolbar background.
> Eric
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On Friday, January 21st, 2022 at 08:03, Veronica Andreo <
> veroandreo at gmail.com> wrote:
> Hi Eric,
> You need to change the `appeareance` settings to a dark one, and grass
> will get it. At least, that's how it worked for me.
> HTH,
> Vero
> El vie, 21 ene 2022 a las 4:59, Eric Patton via grass-user (<
> grass-user at lists.osgeo.org>) escribió:
>> Nevermind, I see that I had to git clone the main branch. The
>> single-window GUI looks great! I really look forward to using this.
>> I still don't see any options for dark mode, though - where do I find
>> this?
>> Eric
>> On Thursday, January 20th, 2022 at 23:23, Eric Patton via grass-user <
>> grass-user at lists.osgeo.org> wrote:
>> Hi All,
>> I just downloaded 8.0.0.RC2 source code for Linux from
>> https://github.com/OSGeo/grass/releases/tag/8.0.0RC2 to try it out
>> today, everything compiled and built fine.
>> I'm not seeing any single-window GUI or options to enable it; did I
>> install the wrong branch?
>> Eric
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220121/8047be38/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220121/8047be38/attachment-0001.png>
