[GRASS-user] stvds
Ivan Marchesini
ivan.marchesini at gmail.com
Sun Jul 24 07:48:45 PDT 2022
Thank you for your answer Veronica,
in the meantime I found an addons that does exactly what I need: sample
a strds at specific point in space and time defined by means of a point
vector layer having an attribute column with dates (tool prepared by
@Luca Delucchi: thank you)
I put the link here for anyone that in the future may have a similar
problem:
https://grass.osgeo.org/grass82/manuals/addons/t.rast.what.aggr.html
thank you again
Ivan
On 24/07/22 13:07, Veronica Andreo wrote:
> Hello Ivan,
> Space-time datasets in GRASS are map based, so, you either need to
> create one vector map per date and then create the time series and
> register the maps there, or in the case of STVDS, you could also add a
> different layer per date to the same vector map and register those as
> in:
> https://grass.osgeo.org/grass80/manuals/t.register.html#north-carolina-dataset
> (see the "Register a vector map with layers representing time steps"
> example)
> HTH,
> Vero
> El vie, 22 jul 2022 a las 14:34, Ivan Marchesini
> (<ivan.marchesini at gmail.com>) escribió:
> Dear GRASS users,
> I have a question about the creation of a spatio-temporal vector
> datasets
> I have a vector points map representing sample sites and it
> includes a
> field of the attribute table describing the sampling date (a
> different
> day, not sequential, for each point).
> I would like to transform the vector point map into a stvds in
> order to
> use it with t.vect.what.strds.
> My question is: is it possible to register the vector point map as
> a stvds?
> thank you
> Ivan
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220724/44371d70/attachment.htm>
