[GRASS-user] r.terrain.geom
Vaclav Petras wenzeslaus at gmail.com
Tue Nov 1 07:48:49 PDT 2022
Dear Maria Cecilia,
A common procedure would be to open a pull request on GitHub for that repo,
but a much better solution would be to have that in the grass-addons repo
where all of us can help maintain it. In any case, a PR is needed which is
a strange thing when you do it the first time around:
https://github.com/OSGeo/grass-addons/blob/grass8/CONTRIBUTING.md
...but it gets better and people here or on GitHub can help.
Maybe you can contact some of the authors (of the paper or of the code) and
see if you or them can submit that to the grass-addons repo.
There might be further considerations on why this should or should not be
in the grass-addons repo, but putting it there is a good default unless
someone comes up with other suggestions.
Best,
Vaclav
On Thu, 27 Oct 2022 at 18:38, Maria Cecilia Zalazar <
zalazarmariacecilia at gmail.com> wrote:
>  data.zip
> <https://drive.google.com/file/d/1IMj2GeM5QPPfix2LwvSuZ1tPonzKeW3x/view?usp=drive_web>
> Dear Grass community, there is a very interesting grass add-on
> (r.terrain.geom) that extracts fluvial terrace-like surfaces from digital
> elevation models and also creates a pdf plot with graphs showing the
> terrain characteristics and logic of process (R interface).
> https://github.com/edinaj0zs4/terrace_extraction_grassgis
> (Józsa, E., 2019. Geomorphometric application of quasi-global DEMs for
> semi-automated geomorphological mapping. University of Pécs)
> My winGrass version is 8.2 and I had to modify the TERRACE_jozsa
> (R-script) in order to update the interface required package
> (rgrass instead of spgrass6). Also the ggplot2 version was necessary to
> update. I'm sending the new R script.
> Actually, this is not an available add-on script via g.extension in
> oficial repositories. I'm not sure which are the requirements to do this
> (some improvements or check?), or if it is possible to make it accessible
> via a public repository.
> I´m sending data for easy checking.
> Thanks very much in advance!
> Regards!
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221101/f994ddde/attachment.htm>
