[GRASS-user] i.smap can't find signature file
Maris Nartiss
maris.gis at gmail.com
Thu Sep 22 12:51:05 PDT 2022
It worked? Strange, as i.smap requires signature generated by
i.gensigset and should not work with one generated by i.gensig (this
fact is even present in the documentation).
i.maxlik can work with signature file from i.gensig or i.cluster as
both programs generate signature file with same structure.
Māris.
P.S. GRASS 8.2 is much better as a lot of bugs have been fixed.
ceturtd., 2022. g. 22. sept., plkst. 15:55 — lietotājs Klaus Mithöfer
(<mithoefer at gbd-consult.de>) rakstīja:
> Hello,
> it seems it is a problem of the module GUI. I was able to run the
> process in the terminal.
> I use GRASS GIS 7.2.9 uon Ubuntu 20.04..5 LTS.
> Cheers, Klaus
> > Dear all,
> > I have created a group and subgroup for an image and created a signature
> > file with i.gensig. I can use the group, subgroup and signature file in
> > i.maxlik to get a result. But in i.smap the signature file cannot be
> > found. What might be the problem?
> > Kind regards, Klaus
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
