[GRASS-user] i.histo.match
    Giuseppe Amatulli
    giuseppe.amatulli at gmail.com
    Tue Sep 27 06:37:59 PDT 2022
Dear Grass team
I'm trying to use the add on i.histo.match in grass 7.8.2 but something is
not going well.
GRASS 7.8.2 (tmploc):/tmp > i.histo.match
input=570-0000000000-0000023296.1,570-0000000000-0000023296.1
 output=mosaic max=4000 --overwrite --verbose
WARNING: Bug in UI description. Missing module description
Usage:
 i.histo.match [--help] [--verbose] [--quiet] [--ui]
ERROR: i.histo.match: Sorry, <input> is not a valid parameter
ERROR: i.histo.match: Sorry, <output> is not a valid parameter
ERROR: i.histo.match: Sorry, <max> is not a valid parameter
The warning also appears during the i.histo.match installation.
Seams that the full command options are not accepted.
Could please suggest the best solution for the problem?
Thanks
Giuseppe
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220927/d0f629d6/attachment.htm>
