[GRASS-user] Building 8.2.1: not finding OpenBLASS
Rich Shepard rshepard at appl-ecosys.com
Tue Apr 25 16:06:45 PDT 2023
On Wed, 26 Apr 2023, Markus Neteler wrote:
> Please check "config.log" for the error message.
Markus,
My apologies. I've not had a project needing grass over the past few years
so I forgot about it.
The file's attached. It shows the usual errors and warnings I've seen when I
was grabbing the development builds (can't find those now), and BLAS begins
on line 3347. I don't see why configure can't find lblas, but I don't know
the code.
Thanks,
Rich
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure --enable-64bit --with-libs=/usr/lib64 --with-postgres --with-postgres-includes=/usr/include/postgresql/server/ --with-postgres-libs=/usr/lib64/postgresql/14/lib/ --with-sqlite --with-sqlite-includes=/usr/include/ --with-sqlite-libs=/usr/lib/ --with-cairo --with-blas --with-lapack --with-freetype --with-freetype-includes=/usr/include/freetype2 --with-cxx --with-geos --with-gdal --with-nls --with-python3 --with-pthread --with-proj-share=/usr/share/proj --with-wxwidgets --enable-largefile --with-openmp --with-x --with-pdal=/usr/bin/pdal --with-libLAS
## Platform. ##
hostname = caddis.appl-ecosys.com
uname -m = x86_64
uname -r = 5.15.94
uname -s = Linux
uname -v = #1 SMP PREEMPT Fri Feb 17 18:59:35 CST 2023
/usr/bin/uname -p = Intel(R) Core(TM) i5-3320M CPU @ 2.60GHz
/bin/uname -X     = unknown
/bin/arch              = x86_64
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /home/rshepard/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/games
PATH: /usr/lib64/libexec/kf5
PATH: /usr/lib64/qt5/bin
## Core tests. ##
configure:2718: checking build system type
configure:2729: result: x86_64-pc-linux-gnu
configure:2749: checking host system type
configure:2759: result: x86_64-pc-linux-gnu
configure:2824: checking for gcc
configure:2838: found /usr/bin/gcc
configure:2848: result: gcc
configure:3065: checking for C compiler version
configure:3074: gcc --version >&5
gcc (GCC) 11.2.0
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3085: $? = 0
configure:3074: gcc -v >&5
Reading specs from /usr/lib64/gcc/x86_64-slackware-linux/11.2.0/specs
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-slackware-linux/11.2.0/lto-wrapper
Target: x86_64-slackware-linux
Configured with: ../configure --prefix=/usr --libdir=/usr/lib64 --mandir=/usr/man --infodir=/usr/info --enable-shared --enable-bootstrap --enable-languages=ada,brig,c,c++,d,fortran,go,lto,objc,obj-c++ --enable-threads=posix --enable-checking=release --enable-objc-gc --with-system-zlib --enable-libstdcxx-dual-abi --with-default-libstdcxx-abi=new --disable-libstdcxx-pch --disable-libunwind-exceptions --enable-__cxa_atexit --disable-libssp --enable-gnu-unique-object --enable-plugin --enable-lto --disable-install-libiberty --disable-werror --with-gnu-ld --with-isl --verbose --with-arch-directory=amd64 --disable-gtktest --enable-clocale=gnu --disable-multilib --target=x86_64-slackware-linux --build=x86_64-slackware-linux --host=x86_64-slackware-linux
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.2.0 (GCC)
configure:3074: gcc -V >&5
gcc: error: unrecognized command-line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:3085: $? = 1
configure:3074: gcc -qversion >&5
gcc: error: unrecognized command-line option '-qversion'; did you mean '--version'?
configure:3105: checking whether the C compiler works
configure:3127: gcc    conftest.c  >&5
configure:3131: $? = 0
configure:3179: result: yes
configure:3182: checking for C compiler default output file name
configure:3184: result: a.out
configure:3190: checking for suffix of executables
configure:3197: gcc -o conftest    conftest.c  >&5
configure:3201: $? = 0
configure:3223: result:
configure:3245: checking whether we are cross compiling
configure:3253: gcc -o conftest    conftest.c  >&5
configure:3257: $? = 0
configure:3264: ./conftest
configure:3268: $? = 0
configure:3283: result: no
configure:3288: checking for suffix of object files
configure:3308: gcc -c   conftest.c >&5
configure:3312: $? = 0
configure:3332: result: o
configure:3336: checking whether we are using the GNU C compiler
configure:3353: gcc -c   conftest.c >&5
configure:3353: $? = 0
configure:3361: result: yes
configure:3370: checking whether gcc accepts -g
configure:3388: gcc -c -g  conftest.c >&5
configure:3388: $? = 0
configure:3428: result: yes
configure:3445: checking for gcc option to accept ISO C89
configure:3506: gcc  -c -g -O2  conftest.c >&5
configure:3506: $? = 0
configure:3518: result: none needed
configure:3548: checking for executable suffix
configure:3559: result: no
configure:3582: checking for full floating-point support
configure:3630: gcc -o conftest -g -O2   conftest.c  >&5
configure:3630: $? = 0
configure:3630: ./conftest
configure:3631: result: yes
configure:3699: checking for pwd
configure:3715: found /usr/bin/pwd
configure:3727: result: /usr/bin/pwd
configure:3742: checking for source directory
configure:3751: result: "/home/rshepard/gis/grass/grass-8.2.1"
configure:3754: checking for build directory
configure:3760: result: "/home/rshepard/gis/grass/grass-8.2.1"
configure:3805: checking for git
configure:3821: found /usr/bin/git
configure:3833: result: /usr/bin/git
configure:3878: checking for MacOSX App
configure:3885: result: "no"
configure:3891: checking for MacOSX architectures
configure:3897: result: no
configure:3922: checking for MacOSX SDK
configure:3928: result: no
configure:3975: checking how to build libraries
configure:3993: result: shared
configure:4896: checking for additional include dirs
configure:4903: result:
configure:4920: checking for additional library dirs
configure:4927: result: /usr/lib64
configure:4958: checking for a BSD-compatible install
configure:5023: result: /usr/bin/ginstall -c
configure:5039: checking for flex
configure:5053: found /usr/bin/flex
configure:5063: result: flex
configure:5101: flex conftest.l
configure:5105: $? = 0
configure:5107: checking lex output file root
configure:5118: result: lex.yy
configure:5123: checking lex library
configure:5135: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c   >&5
/usr/bin/ld: /tmp/ccDyOLXd.o: in function `input':
/home/rshepard/gis/grass/grass-8.2.1/lex.yy.c:1179: undefined reference to `yywrap'
/usr/bin/ld: /tmp/ccDyOLXd.o: in function `yylex':
/home/rshepard/gis/grass/grass-8.2.1/lex.yy.c:870: undefined reference to `yywrap'
/usr/bin/ld: /tmp/ccDyOLXd.o: in function `main':
/home/rshepard/gis/grass/grass-8.2.1/conftest.l:17: undefined reference to `yywrap'
collect2: error: ld returned 1 exit status
configure:5135: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| /* end confdefs.h.  */
| #line 2 "lex.yy.c"
| #define  YY_INT_ALIGNED short int
| /* A lexical scanner generated by flex */
| #define FLEX_SCANNER
| #define YY_FLEX_MAJOR_VERSION 2
| #define YY_FLEX_MINOR_VERSION 6
| #define YY_FLEX_SUBMINOR_VERSION 4
| #if YY_FLEX_SUBMINOR_VERSION > 0
| #define FLEX_BETA
| #endif
| /* First, we deal with  platform-specific or compiler-specific issues. */
| /* begin standard C headers. */
| #include <stdio.h>
| #include <string.h>
| #include <errno.h>
| #include <stdlib.h>
| /* end standard C headers. */
| /* flex integer type definitions */
| #ifndef FLEXINT_H
| #define FLEXINT_H
| /* C99 systems have <inttypes.h>. Non-C99 systems may or may not. */
| #if defined (__STDC_VERSION__) && __STDC_VERSION__ >= 199901L
| /* C99 says to define __STDC_LIMIT_MACROS before including stdint.h,
|  * if you want the limit (max/min) macros for int types.
| #ifndef __STDC_LIMIT_MACROS
| #define __STDC_LIMIT_MACROS 1
| #endif
| #include <inttypes.h>
| typedef int8_t flex_int8_t;
| typedef uint8_t flex_uint8_t;
| typedef int16_t flex_int16_t;
| typedef uint16_t flex_uint16_t;
| typedef int32_t flex_int32_t;
| typedef uint32_t flex_uint32_t;
| #else
| typedef signed char flex_int8_t;
| typedef short int flex_int16_t;
| typedef int flex_int32_t;
| typedef unsigned char flex_uint8_t;
| typedef unsigned short int flex_uint16_t;
| typedef unsigned int flex_uint32_t;
| /* Limits of integral types. */
| #ifndef INT8_MIN
| #define INT8_MIN               (-128)
| #endif
| #ifndef INT16_MIN
| #define INT16_MIN              (-32767-1)
| #endif
| #ifndef INT32_MIN
| #define INT32_MIN              (-2147483647-1)
| #endif
| #ifndef INT8_MAX
| #define INT8_MAX               (127)
| #endif
| #ifndef INT16_MAX
| #define INT16_MAX              (32767)
| #endif
| #ifndef INT32_MAX
| #define INT32_MAX              (2147483647)
| #endif
| #ifndef UINT8_MAX
| #define UINT8_MAX              (255U)
| #endif
| #ifndef UINT16_MAX
| #define UINT16_MAX             (65535U)
| #endif
| #ifndef UINT32_MAX
| #define UINT32_MAX             (4294967295U)
| #endif
| #ifndef SIZE_MAX
| #define SIZE_MAX               (~(size_t)0)
| #endif
| #endif /* ! C99 */
| #endif /* ! FLEXINT_H */
| /* begin standard C++ headers. */
| /* TODO: this is always defined, so inline it */
| #define yyconst const
| #if defined(__GNUC__) && __GNUC__ >= 3
| #define yynoreturn __attribute__((__noreturn__))
| #else
| #define yynoreturn
| #endif
| /* Returned upon end-of-file. */
| #define YY_NULL 0
| /* Promotes a possibly negative, possibly signed char to an
|  *   integer in range [0..255] for use as an array index.
| #define YY_SC_TO_UI(c) ((YY_CHAR) (c))
| /* Enter a start condition.  This macro really ought to take a parameter,
|  * but we do it the disgusting crufty way forced on us by the ()-less
|  * definition of BEGIN.
| #define BEGIN (yy_start) = 1 + 2 *
| /* Translate the current start state into a value that can be later handed
|  * to BEGIN to return to the state.  The YYSTATE alias is for lex
|  * compatibility.
| #define YY_START (((yy_start) - 1) / 2)
| #define YYSTATE YY_START
| /* Action number for EOF rule of a given start state. */
| #define YY_STATE_EOF(state) (YY_END_OF_BUFFER + state + 1)
| /* Special action meaning "start processing a new file". */
| #define YY_NEW_FILE yyrestart( yyin  )
| #define YY_END_OF_BUFFER_CHAR 0
| /* Size of default input buffer. */
| #ifndef YY_BUF_SIZE
| #ifdef __ia64__
| /* On IA-64, the buffer size is 16k, not 8k.
|  * Moreover, YY_BUF_SIZE is 2*YY_READ_BUF_SIZE in the general case.
|  * Ditto for the __ia64__ case accordingly.
| #define YY_BUF_SIZE 32768
| #else
| #define YY_BUF_SIZE 16384
| #endif /* __ia64__ */
| #endif
| /* The state buf must be large enough to hold one state per character in the main buffer.
| #define YY_STATE_BUF_SIZE   ((YY_BUF_SIZE + 2) * sizeof(yy_state_type))
| #ifndef YY_TYPEDEF_YY_BUFFER_STATE
| #define YY_TYPEDEF_YY_BUFFER_STATE
| typedef struct yy_buffer_state *YY_BUFFER_STATE;
| #endif
| #ifndef YY_TYPEDEF_YY_SIZE_T
| #define YY_TYPEDEF_YY_SIZE_T
| typedef size_t yy_size_t;
| #endif
| extern int yyleng;
| extern FILE *yyin, *yyout;
| #define EOB_ACT_CONTINUE_SCAN 0
| #define EOB_ACT_END_OF_FILE 1
| #define EOB_ACT_LAST_MATCH 2
|     #define YY_LESS_LINENO(n)
|     #define YY_LINENO_REWIND_TO(ptr)
| /* Return all but the first "n" matched characters back to the input stream. */
| #define yyless(n) \
| 	do \
| 		/* Undo effects of setting up yytext. */ \
|         int yyless_macro_arg = (n); \
|         YY_LESS_LINENO(yyless_macro_arg);\
| 		*yy_cp = (yy_hold_char); \
| 		YY_RESTORE_YY_MORE_OFFSET \
| 		(yy_c_buf_p) = yy_cp = yy_bp + yyless_macro_arg - YY_MORE_ADJ; \
| 		YY_DO_BEFORE_ACTION; /* set up yytext again */ \
| 	while ( 0 )
| #define unput(c) yyunput( c, (yytext_ptr)  )
| #ifndef YY_STRUCT_YY_BUFFER_STATE
| #define YY_STRUCT_YY_BUFFER_STATE
| 	FILE *yy_input_file;
| 	char *yy_ch_buf;		/* input buffer */
| 	char *yy_buf_pos;		/* current position in input buffer */
| 	/* Size of input buffer in bytes, not including room for EOB
| 	 * characters.
| 	int yy_buf_size;
| 	/* Number of characters read into yy_ch_buf, not including EOB
| 	 * characters.
| 	int yy_n_chars;
| 	/* Whether we "own" the buffer - i.e., we know we created it,
| 	 * and can realloc() it to grow it, and should free() it to
| 	 * delete it.
| 	int yy_is_our_buffer;
| 	/* Whether this is an "interactive" input source; if so, and
| 	 * if we're using stdio for input, then we want to use getc()
| 	 * instead of fread(), to make sure we stop fetching input after
| 	 * each newline.
| 	int yy_is_interactive;
| 	/* Whether we're considered to be at the beginning of a line.
| 	 * If so, '^' rules will be active on the next match, otherwise
| 	 * not.
| 	int yy_at_bol;
|     int yy_bs_lineno; /**< The line count. */
|     int yy_bs_column; /**< The column count. */
| 	/* Whether to try to fill the input buffer when we reach the
| 	 * end of it.
| 	int yy_fill_buffer;
| 	int yy_buffer_status;
| #define YY_BUFFER_NEW 0
| #define YY_BUFFER_NORMAL 1
| 	/* When an EOF's been seen but there's still some text to process
| 	 * then we mark the buffer as YY_EOF_PENDING, to indicate that we
| 	 * shouldn't try reading from the input source any more.  We might
| 	 * still have a bunch of tokens to match, though, because of
| 	 * possible backing-up.
| 	 * When we actually see the EOF, we change the status to "new"
| 	 * (via yyrestart()), so that the user can continue scanning by
| 	 * just pointing yyin at a new input file.
| #define YY_BUFFER_EOF_PENDING 2
| #endif /* !YY_STRUCT_YY_BUFFER_STATE */
| /* Stack of input buffers. */
| static size_t yy_buffer_stack_top = 0; /**< index of top of stack. */
| static size_t yy_buffer_stack_max = 0; /**< capacity of stack. */
| static YY_BUFFER_STATE * yy_buffer_stack = NULL; /**< Stack as an array. */
| /* We provide macros for accessing buffer states in case in the
|  * future we want to put the buffer states in a more general
|  * "scanner state".
|  * Returns the top of the stack, or NULL.
| #define YY_CURRENT_BUFFER ( (yy_buffer_stack) \
|                           ? (yy_buffer_stack)[(yy_buffer_stack_top)] \
|                           : NULL)
| /* Same as previous macro, but useful when we know that the buffer stack is not
|  * NULL or when we need an lvalue. For internal use only.
| #define YY_CURRENT_BUFFER_LVALUE (yy_buffer_stack)[(yy_buffer_stack_top)]
| /* yy_hold_char holds the character lost when yytext is formed. */
| static char yy_hold_char;
| static int yy_n_chars;		/* number of characters read into yy_ch_buf */
| int yyleng;
| /* Points to current character in buffer. */
| static char *yy_c_buf_p = NULL;
| static int yy_init = 0;		/* whether we need to initialize */
| static int yy_start = 0;	/* start state number */
| /* Flag which is used to allow yywrap()'s to do buffer switches
|  * instead of setting up a fresh yyin.  A bit of a hack ...
| static int yy_did_buffer_switch_on_eof;
| void yyrestart ( FILE *input_file  );
| void yy_switch_to_buffer ( YY_BUFFER_STATE new_buffer  );
| YY_BUFFER_STATE yy_create_buffer ( FILE *file, int size  );
| void yy_delete_buffer ( YY_BUFFER_STATE b  );
| void yy_flush_buffer ( YY_BUFFER_STATE b  );
| void yypush_buffer_state ( YY_BUFFER_STATE new_buffer  );
| void yypop_buffer_state ( void );
| static void yyensure_buffer_stack ( void );
| static void yy_load_buffer_state ( void );
| static void yy_init_buffer ( YY_BUFFER_STATE b, FILE *file  );
| #define YY_FLUSH_BUFFER yy_flush_buffer( YY_CURRENT_BUFFER )
| YY_BUFFER_STATE yy_scan_buffer ( char *base, yy_size_t size  );
| YY_BUFFER_STATE yy_scan_string ( const char *yy_str  );
| YY_BUFFER_STATE yy_scan_bytes ( const char *bytes, int len  );
| void *yyalloc ( yy_size_t  );
| void *yyrealloc ( void *, yy_size_t  );
| void yyfree ( void *  );
| #define yy_new_buffer yy_create_buffer
| #define yy_set_interactive(is_interactive) \
| 	if ( ! YY_CURRENT_BUFFER ){ \
|         yyensure_buffer_stack (); \
| 		YY_CURRENT_BUFFER_LVALUE =    \
|             yy_create_buffer( yyin, YY_BUF_SIZE ); \
| 	YY_CURRENT_BUFFER_LVALUE->yy_is_interactive = is_interactive; \
| #define yy_set_bol(at_bol) \
| 	if ( ! YY_CURRENT_BUFFER ){\
| 	YY_CURRENT_BUFFER_LVALUE->yy_at_bol = at_bol; \
| #define YY_AT_BOL() (YY_CURRENT_BUFFER_LVALUE->yy_at_bol)
| /* Begin user sect3 */
| typedef flex_uint8_t YY_CHAR;
| FILE *yyin = NULL, *yyout = NULL;
| typedef int yy_state_type;
| extern int yylineno;
| int yylineno = 1;
| extern char *yytext;
| #ifdef yytext_ptr
| #undef yytext_ptr
| #endif
| #define yytext_ptr yytext
| static yy_state_type yy_get_previous_state ( void );
| static yy_state_type yy_try_NUL_trans ( yy_state_type current_state  );
| static int yy_get_next_buffer ( void );
| static void yynoreturn yy_fatal_error ( const char* msg  );
| /* Done after the current pattern has been matched and before the
|  * corresponding action - sets up yytext.
| #define YY_DO_BEFORE_ACTION \
| 	(yytext_ptr) = yy_bp; \
| 	(yytext_ptr) -= (yy_more_len); \
| 	yyleng = (int) (yy_cp - (yytext_ptr)); \
| 	(yy_hold_char) = *yy_cp; \
| 	*yy_cp = '\0'; \
| 	(yy_c_buf_p) = yy_cp;
| #define YY_NUM_RULES 8
| #define YY_END_OF_BUFFER 9
| /* This struct is not used in this scanner,
|    but its presence is necessary. */
| struct yy_trans_info
| 	flex_int32_t yy_verify;
| 	flex_int32_t yy_nxt;
| static const flex_int16_t yy_acclist[23] =
|     {   0,
|         9,    7,    8,    8,    1,    7,    8,    2,    7,    8,
|         3,    7,    8,    4,    7,    8,    5,    7,    8,    6,
|         7,    8
| static const flex_int16_t yy_accept[14] =
|     {   0,
|         1,    1,    1,    2,    4,    5,    8,   11,   14,   17,
|        20,   23,   23
| static const YY_CHAR yy_ec[256] =
|     {   0,
|         1,    1,    1,    1,    1,    1,    1,    1,    1,    2,
|         1,    1,    1,    1,    1,    1,    1,    1,    1,    1,
|         1,    1,    1,    1,    1,    1,    3,    4,    5,    6,
|         7,    8,    1,    1,    1,    1,    1,    1,    1,    1,
|         1,    1,    1,    1,    1
| static const YY_CHAR yy_meta[9] =
|     {   0,
| static const flex_int16_t yy_base[13] =
|     {   0,
|         0,    0,    9,   10,   10,   10,   10,   10,   10,   10,
|        10,   10
| static const flex_int16_t yy_def[13] =
|     {   0,
|        12,    1,   12,   12,   12,   12,   12,   12,   12,   12,
|        12,    0
| static const flex_int16_t yy_nxt[19] =
|     {   0,
|         4,    5,    6,    7,    8,    9,   10,   11,   12,    3,
| static const flex_int16_t yy_chk[19] =
|     {   0,
|         1,    1,    1,    1,    1,    1,    1,    1,    3,   12,
| extern int yy_flex_debug;
| int yy_flex_debug = 0;
| static yy_state_type *yy_state_buf=0, *yy_state_ptr=0;
| static char *yy_full_match;
| static int yy_lp;
| #define REJECT \
| *yy_cp = (yy_hold_char); /* undo effects of setting up yytext */ \
| yy_cp = (yy_full_match); /* restore poss. backed-over text */ \
| ++(yy_lp); \
| goto find_rule; \
| static int yy_more_flag = 0;
| static int yy_more_len = 0;
| #define yymore() ((yy_more_flag) = 1)
| #define YY_MORE_ADJ (yy_more_len)
| #define YY_RESTORE_YY_MORE_OFFSET
| char *yytext;
| #line 1 "conftest.l"
| #line 459 "lex.yy.c"
| #define INITIAL 0
| #ifndef YY_NO_UNISTD_H
| /* Special case for "unistd.h", since it is non-ANSI. We include it way
|  * down here because we want the user's section 1 to have been scanned first.
|  * The user has a chance to override it with an option.
| #include <unistd.h>
| #endif
| #ifndef YY_EXTRA_TYPE
| #define YY_EXTRA_TYPE void *
| #endif
| static int yy_init_globals ( void );
| /* Accessor methods to globals.
|    These are made visible to non-reentrant scanners for convenience. */
| int yylex_destroy ( void );
| int yyget_debug ( void );
| void yyset_debug ( int debug_flag  );
| YY_EXTRA_TYPE yyget_extra ( void );
| void yyset_extra ( YY_EXTRA_TYPE user_defined  );
| FILE *yyget_in ( void );
| void yyset_in  ( FILE * _in_str  );
| FILE *yyget_out ( void );
| void yyset_out  ( FILE * _out_str  );
| 			int yyget_leng ( void );
| char *yyget_text ( void );
| int yyget_lineno ( void );
| void yyset_lineno ( int _line_number  );
| /* Macros after this point can all be overridden by user definitions in
|  * section 1.
| #ifndef YY_SKIP_YYWRAP
| #ifdef __cplusplus
| extern "C" int yywrap ( void );
| #else
| extern int yywrap ( void );
| #endif
| #endif
| #ifndef YY_NO_UNPUT
|     static void yyunput ( int c, char *buf_ptr  );
| #endif
| #ifndef yytext_ptr
| static void yy_flex_strncpy ( char *, const char *, int );
| #endif
| #ifdef YY_NEED_STRLEN
| static int yy_flex_strlen ( const char * );
| #endif
| #ifndef YY_NO_INPUT
| #ifdef __cplusplus
| static int yyinput ( void );
| #else
| static int input ( void );
| #endif
| #endif
| /* Amount of stuff to slurp up with each read. */
| #ifndef YY_READ_BUF_SIZE
| #ifdef __ia64__
| /* On IA-64, the buffer size is 16k, not 8k */
| #define YY_READ_BUF_SIZE 16384
| #else
| #define YY_READ_BUF_SIZE 8192
| #endif
| /* Copy whatever the last rule matched to the standard output. */
| #ifndef ECHO
| /* This used to be an fputs(), but since the string might contain NUL's,
|  * we now use fwrite().
| #define ECHO do { if (fwrite( yytext, (size_t) yyleng, 1, yyout )) {} } while (0)
| #endif
| /* Gets input and stuffs it into "buf".  number of characters read, or YY_NULL,
|  * is returned in "result".
| #ifndef YY_INPUT
| #define YY_INPUT(buf,result,max_size) \
| 	if ( YY_CURRENT_BUFFER_LVALUE->yy_is_interactive ) \
| 		int c = '*'; \
| 		int n; \
| 		for ( n = 0; n < max_size && \
| 			     (c = getc( yyin )) != EOF && c != '\n'; ++n ) \
| 			buf[n] = (char) c; \
| 		if ( c == '\n' ) \
| 			buf[n++] = (char) c; \
| 		if ( c == EOF && ferror( yyin ) ) \
| 			YY_FATAL_ERROR( "input in flex scanner failed" ); \
| 		result = n; \
| 	else \
| 		errno=0; \
| 		while ( (result = (int) fread(buf, 1, (yy_size_t) max_size, yyin)) == 0 && ferror(yyin)) \
| 			if( errno != EINTR) \
| 				break; \
| 			errno=0; \
| 			clearerr(yyin); \
| #endif
| /* No semi-colon after return; correct usage is to write "yyterminate();" -
|  * we don't want an extra ';' after the "return" because that will cause
|  * some compilers to complain about unreachable statements.
| #ifndef yyterminate
| #define yyterminate() return YY_NULL
| #endif
| /* Number of entries by which start-condition stack grows. */
| #ifndef YY_START_STACK_INCR
| #define YY_START_STACK_INCR 25
| #endif
| /* Report a fatal error. */
| #ifndef YY_FATAL_ERROR
| #define YY_FATAL_ERROR(msg) yy_fatal_error( msg )
| #endif
| /* end tables serialization structures and prototypes */
| /* Default declaration of generated scanner - a define so the user can
|  * easily add parameters.
| #ifndef YY_DECL
| #define YY_DECL_IS_OURS 1
| extern int yylex (void);
| #define YY_DECL int yylex (void)
| #endif /* !YY_DECL */
| /* Code executed at the beginning of each rule, after yytext and yyleng
|  * have been set up.
| #ifndef YY_USER_ACTION
| #define YY_USER_ACTION
| #endif
| /* Code executed at the end of each rule. */
| #ifndef YY_BREAK
| #define YY_BREAK /*LINTED*/break;
| #endif
| #define YY_RULE_SETUP \
| 	YY_USER_ACTION
| /** The main scanner function which does all the work.
| YY_DECL
| 	yy_state_type yy_current_state;
| 	char *yy_cp, *yy_bp;
| 	int yy_act;
| 	if ( !(yy_init) )
| 		(yy_init) = 1;
| #ifdef YY_USER_INIT
| 		YY_USER_INIT;
| #endif
|         /* Create the reject buffer large enough to save one state per allowed character. */
|         if ( ! (yy_state_buf) )
|             (yy_state_buf) = (yy_state_type *)yyalloc(YY_STATE_BUF_SIZE  );
|                 YY_FATAL_ERROR( "out of dynamic memory in yylex()" );
| 		if ( ! (yy_start) )
| 			(yy_start) = 1;	/* first start state */
| 		if ( ! yyin )
| 			yyin = stdin;
| 		if ( ! yyout )
| 			yyout = stdout;
| 		if ( ! YY_CURRENT_BUFFER ) {
| 		yy_load_buffer_state(  );
| #line 684 "lex.yy.c"
| 	while ( /*CONSTCOND*/1 )		/* loops until end-of-file is reached */
| 		(yy_more_len) = 0;
| 		if ( (yy_more_flag) )
| 			(yy_more_len) = (int) ((yy_c_buf_p) - (yytext_ptr));
| 			(yy_more_flag) = 0;
| 		yy_cp = (yy_c_buf_p);
| 		/* Support of yytext. */
| 		/* yy_bp points to the position in yy_ch_buf of the start of
| 		 * the current run.
| 		yy_bp = yy_cp;
| 		yy_current_state = (yy_start);
| 		(yy_state_ptr) = (yy_state_buf);
| 		*(yy_state_ptr)++ = yy_current_state;
| yy_match:
| 		do
| 			YY_CHAR yy_c = yy_ec[YY_SC_TO_UI(*yy_cp)] ;
| 			while ( yy_chk[yy_base[yy_current_state] + yy_c] != yy_current_state )
| 				yy_current_state = (int) yy_def[yy_current_state];
| 				if ( yy_current_state >= 13 )
| 					yy_c = yy_meta[yy_c];
| 			yy_current_state = yy_nxt[yy_base[yy_current_state] + yy_c];
| 			++yy_cp;
| 		while ( yy_base[yy_current_state] != 10 );
| yy_find_action:
| 		yy_current_state = *--(yy_state_ptr);
| 		(yy_lp) = yy_accept[yy_current_state];
| find_rule: /* we branch to this label when backing up */
| 		for ( ; ; ) /* until we find what rule we matched */
| 			if ( (yy_lp) && (yy_lp) < yy_accept[yy_current_state + 1] )
| 				yy_act = yy_acclist[(yy_lp)];
| 					(yy_full_match) = yy_cp;
| 					break;
| 			--yy_cp;
| do_action:	/* This label is used only to access EOF actions. */
| 		switch ( yy_act )
| 	{ /* beginning of action switch */
| case 1:
| YY_RULE_SETUP
| #line 2 "conftest.l"
| { ECHO; }
| 	YY_BREAK
| case 2:
| YY_RULE_SETUP
| #line 3 "conftest.l"
| { REJECT; }
| 	YY_BREAK
| case 3:
| YY_RULE_SETUP
| #line 4 "conftest.l"
| { yymore (); }
| 	YY_BREAK
| case 4:
| YY_RULE_SETUP
| #line 5 "conftest.l"
| { yyless (1); }
| 	YY_BREAK
| case 5:
| YY_RULE_SETUP
| #line 6 "conftest.l"
| { /* IRIX 6.5 flex 2.5.4 underquotes its yyless argument.  */
|     yyless ((input () != 0)); }
| 	YY_BREAK
| case 6:
| YY_RULE_SETUP
| #line 8 "conftest.l"
| { unput (yytext[0]); }
| 	YY_BREAK
| case 7:
| YY_RULE_SETUP
| #line 9 "conftest.l"
| { BEGIN INITIAL; }
| 	YY_BREAK
| case 8:
| YY_RULE_SETUP
| #line 10 "conftest.l"
| ECHO;
| 	YY_BREAK
| #line 793 "lex.yy.c"
| 			case YY_STATE_EOF(INITIAL):
| 				yyterminate();
| 	case YY_END_OF_BUFFER:
| 		/* Amount of text matched not including the EOB char. */
| 		int yy_amount_of_matched_text = (int) (yy_cp - (yytext_ptr)) - 1;
| 		/* Undo the effects of YY_DO_BEFORE_ACTION. */
| 		if ( YY_CURRENT_BUFFER_LVALUE->yy_buffer_status == YY_BUFFER_NEW )
| 			/* We're scanning a new file or input source.  It's
| 			 * possible that this happened because the user
| 			 * just pointed yyin at a new source and called
| 			 * yylex().  If so, then we have to assure
| 			 * consistency between YY_CURRENT_BUFFER and our
| 			 * globals.  Here is the right place to do so, because
| 			 * this is the first action (other than possibly a
| 			 * back-up) that will match for the new input source.
| 			(yy_n_chars) = YY_CURRENT_BUFFER_LVALUE->yy_n_chars;
| 			YY_CURRENT_BUFFER_LVALUE->yy_input_file = yyin;
| 			YY_CURRENT_BUFFER_LVALUE->yy_buffer_status = YY_BUFFER_NORMAL;
| 		/* Note that here we test for yy_c_buf_p "<=" to the position
| 		 * of the first EOB in the buffer, since yy_c_buf_p will
| 		 * already have been incremented past the NUL character
| 		 * (since all states make transitions on EOB to the
| 		 * end-of-buffer state).  Contrast this with the test
| 		 * in input().
| 		if ( (yy_c_buf_p) <= &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars)] )
| 			{ /* This was really a NUL. */
| 			yy_state_type yy_next_state;
| 			(yy_c_buf_p) = (yytext_ptr) + yy_amount_of_matched_text;
| 			yy_current_state = yy_get_previous_state(  );
| 			/* Okay, we're now positioned to make the NUL
| 			 * transition.  We couldn't have
| 			 * yy_get_previous_state() go ahead and do it
| 			 * for us because it doesn't know how to deal
| 			 * with the possibility of jamming (and we don't
| 			 * want to build jamming into it because then it
| 			 * will run more slowly).
| 			yy_next_state = yy_try_NUL_trans( yy_current_state );
| 			yy_bp = (yytext_ptr) + YY_MORE_ADJ;
| 			if ( yy_next_state )
| 				/* Consume the NUL. */
| 				yy_cp = ++(yy_c_buf_p);
| 				yy_current_state = yy_next_state;
| 				goto yy_match;
| 			else
| 				goto yy_find_action;
| 		else switch ( yy_get_next_buffer(  ) )
| 			case EOB_ACT_END_OF_FILE:
| 				(yy_did_buffer_switch_on_eof) = 0;
| 				if ( yywrap(  ) )
| 					/* Note: because we've taken care in
| 					 * yy_get_next_buffer() to have set up
| 					 * yytext, we can now set up
| 					 * yy_c_buf_p so that if some total
| 					 * hoser (like flex itself) wants to
| 					 * call the scanner after we return the
| 					 * YY_NULL, it'll still work - another
| 					 * YY_NULL will get returned.
| 					(yy_c_buf_p) = (yytext_ptr) + YY_MORE_ADJ;
| 					yy_act = YY_STATE_EOF(YY_START);
| 					goto do_action;
| 				else
| 					if ( ! (yy_did_buffer_switch_on_eof) )
| 						YY_NEW_FILE;
| 				break;
| 			case EOB_ACT_CONTINUE_SCAN:
| 				(yy_c_buf_p) =
| 				goto yy_match;
| 			case EOB_ACT_LAST_MATCH:
| 				(yy_c_buf_p) =
| 				&YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars)];
| 		break;
| 	default:
| 		YY_FATAL_ERROR(
| 			"fatal flex scanner internal error--no action found" );
| 	} /* end of action switch */
| 		} /* end of scanning one token */
| 	} /* end of user's declarations */
| } /* end of yylex */
| /* yy_get_next_buffer - try to read in a new buffer
|  * Returns a code representing an action:
|  *	EOB_ACT_LAST_MATCH -
|  *	EOB_ACT_CONTINUE_SCAN - continue scanning from current position
|  *	EOB_ACT_END_OF_FILE - end of file
| static int yy_get_next_buffer (void)
|     	char *dest = YY_CURRENT_BUFFER_LVALUE->yy_ch_buf;
| 	char *source = (yytext_ptr);
| 	int number_to_move, i;
| 	int ret_val;
| 	if ( (yy_c_buf_p) > &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars) + 1] )
| 		YY_FATAL_ERROR(
| 		"fatal flex scanner internal error--end of buffer missed" );
| 	if ( YY_CURRENT_BUFFER_LVALUE->yy_fill_buffer == 0 )
| 		{ /* Don't try to fill the buffer, so this is an EOF. */
| 		if ( (yy_c_buf_p) - (yytext_ptr) - YY_MORE_ADJ == 1 )
| 			/* We matched a single character, the EOB, so
| 			 * treat this as a final EOF.
| 			return EOB_ACT_END_OF_FILE;
| 		else
| 			/* We matched some text prior to the EOB, first
| 			 * process it.
| 			return EOB_ACT_LAST_MATCH;
| 	/* Try to read more data. */
| 	/* First move last chars to start of buffer. */
| 	number_to_move = (int) ((yy_c_buf_p) - (yytext_ptr) - 1);
| 	for ( i = 0; i < number_to_move; ++i )
| 		*(dest++) = *(source++);
| 	if ( YY_CURRENT_BUFFER_LVALUE->yy_buffer_status == YY_BUFFER_EOF_PENDING )
| 		/* don't do the read, it's not guaranteed to return an EOF,
| 		 * just force an EOF
| 		YY_CURRENT_BUFFER_LVALUE->yy_n_chars = (yy_n_chars) = 0;
| 	else
| 			int num_to_read =
| 			YY_CURRENT_BUFFER_LVALUE->yy_buf_size - number_to_move - 1;
| 		while ( num_to_read <= 0 )
| 			{ /* Not enough room in the buffer - grow it. */
| 			YY_FATAL_ERROR(
| "input buffer overflow, can't enlarge buffer because scanner uses REJECT" );
| 		if ( num_to_read > YY_READ_BUF_SIZE )
| 			num_to_read = YY_READ_BUF_SIZE;
| 		/* Read in more data. */
| 		YY_INPUT( (&YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[number_to_move]),
| 			(yy_n_chars), num_to_read );
| 		YY_CURRENT_BUFFER_LVALUE->yy_n_chars = (yy_n_chars);
| 	if ( (yy_n_chars) == 0 )
| 		if ( number_to_move == YY_MORE_ADJ )
| 			ret_val = EOB_ACT_END_OF_FILE;
| 			yyrestart( yyin  );
| 		else
| 			ret_val = EOB_ACT_LAST_MATCH;
| 				YY_BUFFER_EOF_PENDING;
| 	else
| 		ret_val = EOB_ACT_CONTINUE_SCAN;
| 	if (((yy_n_chars) + number_to_move) > YY_CURRENT_BUFFER_LVALUE->yy_buf_size) {
| 		/* Extend the array by 50%, plus the number we really need. */
| 		int new_size = (yy_n_chars) + number_to_move + ((yy_n_chars) >> 1);
| 		YY_CURRENT_BUFFER_LVALUE->yy_ch_buf = (char *) yyrealloc(
| 			(void *) YY_CURRENT_BUFFER_LVALUE->yy_ch_buf, (yy_size_t) new_size  );
| 		if ( ! YY_CURRENT_BUFFER_LVALUE->yy_ch_buf )
| 			YY_FATAL_ERROR( "out of dynamic memory in yy_get_next_buffer()" );
| 		/* "- 2" to take care of EOB's */
| 		YY_CURRENT_BUFFER_LVALUE->yy_buf_size = (int) (new_size - 2);
| 	(yy_n_chars) += number_to_move;
| 	YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars)] = YY_END_OF_BUFFER_CHAR;
| 	YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars) + 1] = YY_END_OF_BUFFER_CHAR;
| 	(yytext_ptr) = &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[0];
| 	return ret_val;
| /* yy_get_previous_state - get the state just before the EOB char was reached */
|     static yy_state_type yy_get_previous_state (void)
| 	char *yy_cp;
| 	for ( yy_cp = (yytext_ptr) + YY_MORE_ADJ; yy_cp < (yy_c_buf_p); ++yy_cp )
| 		YY_CHAR yy_c = (*yy_cp ? yy_ec[YY_SC_TO_UI(*yy_cp)] : 1);
| 	return yy_current_state;
| /* yy_try_NUL_trans - try to make a transition on the NUL character
|  * synopsis
|  *	next_state = yy_try_NUL_trans( current_state );
|     static yy_state_type yy_try_NUL_trans  (yy_state_type yy_current_state )
| 	int yy_is_jam;
| 	YY_CHAR yy_c = 1;
| 	yy_is_jam = (yy_current_state == 12);
| 	if ( ! yy_is_jam )
| 		return yy_is_jam ? 0 : yy_current_state;
| #ifndef YY_NO_UNPUT
|     static void yyunput (int c, char * yy_bp )
| 	char *yy_cp;
| 	if ( yy_cp < YY_CURRENT_BUFFER_LVALUE->yy_ch_buf + 2 )
| 		{ /* need to shift things up to make room */
| 		/* +2 for EOB chars. */
| 		int number_to_move = (yy_n_chars) + 2;
| 		char *dest = &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[
| 					YY_CURRENT_BUFFER_LVALUE->yy_buf_size + 2];
| 		char *source =
| 				&YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[number_to_move];
| 		while ( source > YY_CURRENT_BUFFER_LVALUE->yy_ch_buf )
| 			*--dest = *--source;
| 		yy_cp += (int) (dest - source);
| 		yy_bp += (int) (dest - source);
| 			(yy_n_chars) = (int) YY_CURRENT_BUFFER_LVALUE->yy_buf_size;
| 			YY_FATAL_ERROR( "flex scanner push-back overflow" );
| 	*--yy_cp = (char) c;
| #endif
| #ifndef YY_NO_INPUT
| #ifdef __cplusplus
|     static int yyinput (void)
| #else
|     static int input  (void)
| #endif
| 	int c;
| 	*(yy_c_buf_p) = (yy_hold_char);
| 	if ( *(yy_c_buf_p) == YY_END_OF_BUFFER_CHAR )
| 		/* yy_c_buf_p now points to the character we want to return.
| 		 * If this occurs *before* the EOB characters, then it's a
| 		 * valid NUL; if not, then we've hit the end of the buffer.
| 		if ( (yy_c_buf_p) < &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars)] )
| 			*(yy_c_buf_p) = '\0';
| 		else
| 			{ /* need more input */
| 			int offset = (int) ((yy_c_buf_p) - (yytext_ptr));
| 			++(yy_c_buf_p);
| 					/* This happens because yy_g_n_b()
| 					 * sees that we've accumulated a
| 					 * token and flags that we need to
| 					 * try matching the token before
| 					 * proceeding.  But for input(),
| 					 * there's no matching to consider.
| 					 * So convert the EOB_ACT_LAST_MATCH
| 					 * to EOB_ACT_END_OF_FILE.
| 					/* Reset buffer status. */
| 					yyrestart( yyin );
| 					/*FALLTHROUGH*/
| 					if ( yywrap(  ) )
| 						return 0;
| 						YY_NEW_FILE;
| #ifdef __cplusplus
| 					return yyinput();
| #else
| 					return input();
| #endif
| 					(yy_c_buf_p) = (yytext_ptr) + offset;
| 					break;
| 	c = *(unsigned char *) (yy_c_buf_p);	/* cast for 8-bit char's */
| 	*(yy_c_buf_p) = '\0';	/* preserve yytext */
| 	(yy_hold_char) = *++(yy_c_buf_p);
| 	return c;
| #endif	/* ifndef YY_NO_INPUT */
| /** Immediately switch to a different input stream.
|  * @param input_file A readable stream.
|  * @note This function does not reset the start condition to @c INITIAL .
|     void yyrestart  (FILE * input_file )
| 	yy_init_buffer( YY_CURRENT_BUFFER, input_file );
| /** Switch to a different input buffer.
|  * @param new_buffer The new input buffer.
|     void yy_switch_to_buffer  (YY_BUFFER_STATE  new_buffer )
| 	/* TODO. We should be able to replace this entire function body
| 	 * with
| 	 *		yypop_buffer_state();
| 	 *		yypush_buffer_state(new_buffer);
| 	if ( YY_CURRENT_BUFFER == new_buffer )
| 		return;
| 	if ( YY_CURRENT_BUFFER )
| 		/* Flush out information for old buffer. */
| 		YY_CURRENT_BUFFER_LVALUE->yy_buf_pos = (yy_c_buf_p);
| 	YY_CURRENT_BUFFER_LVALUE = new_buffer;
| 	/* We don't actually know whether we did this switch during
| 	 * EOF (yywrap()) processing, but the only time this flag
| 	 * is looked at is after yywrap() is called, so it's safe
| 	 * to go ahead and always set it.
| 	(yy_did_buffer_switch_on_eof) = 1;
| static void yy_load_buffer_state  (void)
| 	(yytext_ptr) = (yy_c_buf_p) = YY_CURRENT_BUFFER_LVALUE->yy_buf_pos;
| 	yyin = YY_CURRENT_BUFFER_LVALUE->yy_input_file;
| 	(yy_hold_char) = *(yy_c_buf_p);
| /** Allocate and initialize an input buffer state.
|  * @param file A readable stream.
|  * @param size The character buffer size in bytes. When in doubt, use @c YY_BUF_SIZE.
|  * @return the allocated buffer state.
|     YY_BUFFER_STATE yy_create_buffer  (FILE * file, int  size )
| 	YY_BUFFER_STATE b;
| 	b = (YY_BUFFER_STATE) yyalloc( sizeof( struct yy_buffer_state )  );
| 	if ( ! b )
| 		YY_FATAL_ERROR( "out of dynamic memory in yy_create_buffer()" );
| 	b->yy_buf_size = size;
| 	/* yy_ch_buf has to be 2 characters longer than the size given because
| 	 * we need to put in 2 end-of-buffer characters.
| 	b->yy_ch_buf = (char *) yyalloc( (yy_size_t) (b->yy_buf_size + 2)  );
| 	if ( ! b->yy_ch_buf )
| 	b->yy_is_our_buffer = 1;
| 	yy_init_buffer( b, file );
| 	return b;
| /** Destroy the buffer.
|  * @param b a buffer created with yy_create_buffer()
|     void yy_delete_buffer (YY_BUFFER_STATE  b )
| 	if ( ! b )
| 		return;
| 	if ( b == YY_CURRENT_BUFFER ) /* Not sure if we should pop here. */
| 		YY_CURRENT_BUFFER_LVALUE = (YY_BUFFER_STATE) 0;
| 	if ( b->yy_is_our_buffer )
| 		yyfree( (void *) b->yy_ch_buf  );
| 	yyfree( (void *) b  );
| /* Initializes or reinitializes a buffer.
|  * This function is sometimes called more than once on the same buffer,
|  * such as during a yyrestart() or at EOF.
|     static void yy_init_buffer  (YY_BUFFER_STATE  b, FILE * file )
| 	int oerrno = errno;
| 	yy_flush_buffer( b );
| 	b->yy_input_file = file;
| 	b->yy_fill_buffer = 1;
|     /* If b is the current buffer, then yy_init_buffer was _probably_
|      * called from yyrestart() or through yy_get_next_buffer.
|      * In that case, we don't want to reset the lineno or column.
|     if (b != YY_CURRENT_BUFFER){
|         b->yy_bs_lineno = 1;
|         b->yy_bs_column = 0;
|         b->yy_is_interactive = file ? (isatty( fileno(file) ) > 0) : 0;
| 	errno = oerrno;
| /** Discard all buffered characters. On the next scan, YY_INPUT will be called.
|  * @param b the buffer state to be flushed, usually @c YY_CURRENT_BUFFER.
|     void yy_flush_buffer (YY_BUFFER_STATE  b )
|     	if ( ! b )
| 		return;
| 	b->yy_n_chars = 0;
| 	/* We always need two end-of-buffer characters.  The first causes
| 	 * a transition to the end-of-buffer state.  The second causes
| 	 * a jam in that state.
| 	b->yy_ch_buf[0] = YY_END_OF_BUFFER_CHAR;
| 	b->yy_ch_buf[1] = YY_END_OF_BUFFER_CHAR;
| 	b->yy_buf_pos = &b->yy_ch_buf[0];
| 	b->yy_at_bol = 1;
| 	b->yy_buffer_status = YY_BUFFER_NEW;
| /** Pushes the new state onto the stack. The new state becomes
|  *  the current state. This function will allocate the stack
|  *  if necessary.
|  *  @param new_buffer The new state.
| void yypush_buffer_state (YY_BUFFER_STATE new_buffer )
|     	if (new_buffer == NULL)
| 		return;
| 	yyensure_buffer_stack();
| 	/* This block is copied from yy_switch_to_buffer. */
| 	/* Only push if top exists. Otherwise, replace top. */
| 	if (YY_CURRENT_BUFFER)
| 		(yy_buffer_stack_top)++;
| 	/* copied from yy_switch_to_buffer. */
| /** Removes and deletes the top of the stack, if present.
|  *  The next element becomes the new top.
| void yypop_buffer_state (void)
|     	if (!YY_CURRENT_BUFFER)
| 		return;
| 	yy_delete_buffer(YY_CURRENT_BUFFER );
| 	YY_CURRENT_BUFFER_LVALUE = NULL;
| 	if ((yy_buffer_stack_top) > 0)
| 		--(yy_buffer_stack_top);
| 	if (YY_CURRENT_BUFFER) {
| /* Allocates the stack if it does not exist.
|  *  Guarantees space for at least one push.
| static void yyensure_buffer_stack (void)
| 	yy_size_t num_to_alloc;
| 	if (!(yy_buffer_stack)) {
| 		/* First allocation is just for 2 elements, since we don't know if this
| 		 * scanner will even need a stack. We use 2 instead of 1 to avoid an
| 		 * immediate realloc on the next call.
|       num_to_alloc = 1; /* After all that talk, this was set to 1 anyways... */
| 		(yy_buffer_stack) = (struct yy_buffer_state**)yyalloc
| 								(num_to_alloc * sizeof(struct yy_buffer_state*)
| 		if ( ! (yy_buffer_stack) )
| 			YY_FATAL_ERROR( "out of dynamic memory in yyensure_buffer_stack()" );
| 		memset((yy_buffer_stack), 0, num_to_alloc * sizeof(struct yy_buffer_state*));
| 		(yy_buffer_stack_max) = num_to_alloc;
| 		(yy_buffer_stack_top) = 0;
| 		return;
| 	if ((yy_buffer_stack_top) >= ((yy_buffer_stack_max)) - 1){
| 		/* Increase the buffer to prepare for a possible push. */
| 		yy_size_t grow_size = 8 /* arbitrary grow size */;
| 		num_to_alloc = (yy_buffer_stack_max) + grow_size;
| 		(yy_buffer_stack) = (struct yy_buffer_state**)yyrealloc
| 								((yy_buffer_stack),
| 		/* zero only the new slots.*/
| 		memset((yy_buffer_stack) + (yy_buffer_stack_max), 0, grow_size * sizeof(struct yy_buffer_state*));
| /** Setup the input buffer state to scan directly from a user-specified character buffer.
|  * @param base the character buffer
|  * @param size the size in bytes of the character buffer
|  * @return the newly allocated buffer state object.
| YY_BUFFER_STATE yy_scan_buffer  (char * base, yy_size_t  size )
| 	YY_BUFFER_STATE b;
| 	if ( size < 2 ||
| 	     base[size-2] != YY_END_OF_BUFFER_CHAR ||
| 	     base[size-1] != YY_END_OF_BUFFER_CHAR )
| 		/* They forgot to leave room for the EOB's. */
| 		return NULL;
| 	if ( ! b )
| 		YY_FATAL_ERROR( "out of dynamic memory in yy_scan_buffer()" );
| 	b->yy_buf_size = (int) (size - 2);	/* "- 2" to take care of EOB's */
| 	b->yy_buf_pos = b->yy_ch_buf = base;
| 	b->yy_is_our_buffer = 0;
| 	b->yy_input_file = NULL;
| 	b->yy_n_chars = b->yy_buf_size;
| 	b->yy_is_interactive = 0;
| 	b->yy_at_bol = 1;
| 	b->yy_fill_buffer = 0;
| 	yy_switch_to_buffer( b  );
| 	return b;
| /** Setup the input buffer state to scan a string. The next call to yylex() will
|  * scan from a @e copy of @a str.
|  * @param yystr a NUL-terminated string to scan
|  * @note If you want to scan bytes that may contain NUL values, then use
|  *       yy_scan_bytes() instead.
| YY_BUFFER_STATE yy_scan_string (const char * yystr )
| 	return yy_scan_bytes( yystr, (int) strlen(yystr) );
| /** Setup the input buffer state to scan the given bytes. The next call to yylex() will
|  * scan from a @e copy of @a bytes.
|  * @param yybytes the byte buffer to scan
|  * @param _yybytes_len the number of bytes in the buffer pointed to by @a bytes.
| YY_BUFFER_STATE yy_scan_bytes  (const char * yybytes, int  _yybytes_len )
| 	YY_BUFFER_STATE b;
| 	char *buf;
| 	yy_size_t n;
| 	int i;
| 	/* Get memory for full buffer, including space for trailing EOB's. */
| 	n = (yy_size_t) (_yybytes_len + 2);
| 	buf = (char *) yyalloc( n  );
| 	if ( ! buf )
| 		YY_FATAL_ERROR( "out of dynamic memory in yy_scan_bytes()" );
| 	for ( i = 0; i < _yybytes_len; ++i )
| 		buf[i] = yybytes[i];
| 	buf[_yybytes_len] = buf[_yybytes_len+1] = YY_END_OF_BUFFER_CHAR;
| 	b = yy_scan_buffer( buf, n );
| 	if ( ! b )
| 		YY_FATAL_ERROR( "bad buffer in yy_scan_bytes()" );
| 	/* It's okay to grow etc. this buffer, and we should throw it
| 	 * away when we're done.
| 	return b;
| #ifndef YY_EXIT_FAILURE
| #define YY_EXIT_FAILURE 2
| #endif
| static void yynoreturn yy_fatal_error (const char* msg )
| 			fprintf( stderr, "%s\n", msg );
| 	exit( YY_EXIT_FAILURE );
| /* Redefine yyless() so it works in section 3 code. */
| #undef yyless
| #define yyless(n) \
| 	do \
| 		yytext[yyleng] = (yy_hold_char); \
| 		(yy_c_buf_p) = yytext + yyless_macro_arg; \
| 		(yy_hold_char) = *(yy_c_buf_p); \
| 		*(yy_c_buf_p) = '\0'; \
| 		yyleng = yyless_macro_arg; \
| 	while ( 0 )
| /* Accessor  methods (get/set functions) to struct members. */
| /** Get the current line number.
| int yyget_lineno  (void)
|     return yylineno;
| /** Get the input stream.
| FILE *yyget_in  (void)
|         return yyin;
| /** Get the output stream.
| FILE *yyget_out  (void)
|         return yyout;
| /** Get the length of the current token.
| int yyget_leng  (void)
|         return yyleng;
| /** Get the current token.
| char *yyget_text  (void)
|         return yytext;
| /** Set the current line number.
|  * @param _line_number line number
| void yyset_lineno (int  _line_number )
|     yylineno = _line_number;
| /** Set the input stream. This does not discard the current
|  * input buffer.
|  * @param _in_str A readable stream.
|  * @see yy_switch_to_buffer
| void yyset_in (FILE *  _in_str )
|         yyin = _in_str ;
| void yyset_out (FILE *  _out_str )
|         yyout = _out_str ;
| int yyget_debug  (void)
|         return yy_flex_debug;
| void yyset_debug (int  _bdebug )
|         yy_flex_debug = _bdebug ;
| static int yy_init_globals (void)
|         /* Initialization is the same as for the non-reentrant scanner.
|      * This function is called from yylex_destroy(), so don't allocate here.
|     (yy_buffer_stack) = NULL;
|     (yy_buffer_stack_max) = 0;
|     (yy_c_buf_p) = NULL;
|     (yy_init) = 0;
|     (yy_start) = 0;
|     (yy_state_buf) = 0;
|     (yy_state_ptr) = 0;
|     (yy_full_match) = 0;
|     (yy_lp) = 0;
| /* Defined in main.c */
| #ifdef YY_STDINIT
|     yyin = stdin;
|     yyout = stdout;
| #else
|     yyin = NULL;
|     yyout = NULL;
| #endif
|     /* For future reference: Set errno on error, since we are called by
|      * yylex_init()
|     return 0;
| /* yylex_destroy is for both reentrant and non-reentrant scanners. */
| int yylex_destroy  (void)
|     /* Pop the buffer stack, destroying each element. */
| 	while(YY_CURRENT_BUFFER){
| 		yy_delete_buffer( YY_CURRENT_BUFFER  );
| 	/* Destroy the stack itself. */
| 	yyfree((yy_buffer_stack) );
|     yyfree ( (yy_state_buf) );
|     (yy_state_buf)  = NULL;
|     /* Reset the globals. This is important in a non-reentrant scanner so the next time
|      * yylex() is called, initialization will occur. */
|     yy_init_globals( );
|     return 0;
|  * Internal utility routines.
| #ifndef yytext_ptr
| static void yy_flex_strncpy (char* s1, const char * s2, int n )
| 	int i;
| 	for ( i = 0; i < n; ++i )
| 		s1[i] = s2[i];
| #endif
| static int yy_flex_strlen (const char * s )
| 	int n;
| 	for ( n = 0; s[n]; ++n )
| 	return n;
| #endif
| void *yyalloc (yy_size_t  size )
| 			return malloc(size);
| void *yyrealloc  (void * ptr, yy_size_t  size )
| 	/* The cast to (char *) in the following accommodates both
| 	 * implementations that use char* generic pointers, and those
| 	 * that use void* generic pointers.  It works with the latter
| 	 * because both ANSI C and C++ allow castless assignment from
| 	 * any pointer type to void*, and deal with argument conversions
| 	 * as though doing an assignment.
| 	return realloc(ptr, size);
| void yyfree (void * ptr )
| 			free( (char *) ptr );	/* see yyrealloc() for (char *) cast */
| #define YYTABLES_NAME "yytables"
| #ifdef YYTEXT_POINTER
| #endif
| int
| main (void)
|   return ! yylex () + ! yywrap ();
configure:5135: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lfl  >&5
configure:5135: $? = 0
configure:5144: result: -lfl
configure:5150: checking whether yytext is a pointer
configure:5165: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lfl  >&5
configure:5165: $? = 0
configure:5172: result: yes
configure:5230: checking for bison
configure:5244: found /usr/bin/bison
configure:5254: result: bison -y
configure:5350: checking for ranlib
configure:5364: found /usr/bin/ranlib
configure:5374: result: ranlib
configure:5400: checking for ar
configure:5414: found /usr/bin/ar
configure:5424: result: ar
configure:5439: checking for env
configure:5453: found /usr/bin/env
configure:5463: result: env
configure:5476: checking for perl
configure:5492: found /usr/bin/perl
configure:5504: result: /usr/bin/perl
configure:5517: checking how to run the C preprocessor
configure:5546: gcc -E  conftest.c
configure:5546: $? = 0
configure:5560: gcc -E  conftest.c
conftest.c:10:10: fatal error: ac_nonexistent.h: No such file or directory
   10 | #include <ac_nonexistent.h>
configure:5560: $? = 1
| /* confdefs.h */
| #define YYTEXT_POINTER 1
configure:5584: result: gcc -E
configure:5604: gcc -E  conftest.c
configure:5604: $? = 0
configure:5618: gcc -E  conftest.c
configure:5618: $? = 1
| /* confdefs.h */
configure:5647: checking for grep that handles long lines and -e
configure:5702: result: /usr/bin/grep
configure:5707: checking for egrep
configure:5766: result: /usr/bin/grep -E
configure:5771: checking for ANSI C header files
configure:5789: gcc -c -g -O2   conftest.c >&5
configure:5789: $? = 0
configure:5862: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:5862: $? = 0
configure:5862: ./conftest
configure:5872: result: yes
configure:5886: checking for sys/types.h
configure:5886: gcc -c -g -O2   conftest.c >&5
configure:5886: $? = 0
configure:5886: result: yes
configure:5886: checking for sys/stat.h
configure:5886: checking for stdlib.h
configure:5886: checking for string.h
configure:5886: checking for memory.h
configure:5886: checking for strings.h
configure:5886: checking for inttypes.h
configure:5886: checking for stdint.h
configure:5886: checking for unistd.h
configure:5901: checking limits.h usability
configure:5901: gcc -c -g -O2   conftest.c >&5
configure:5901: $? = 0
configure:5901: result: yes
configure:5901: checking limits.h presence
configure:5901: gcc -E  conftest.c
configure:5901: checking for limits.h
configure:5901: checking termio.h usability
configure:5901: checking termio.h presence
configure:5901: checking for termio.h
configure:5901: checking termios.h usability
configure:5901: checking termios.h presence
configure:5901: checking for termios.h
configure:5901: checking for unistd.h
configure:5901: checking values.h usability
configure:5901: checking values.h presence
configure:5901: checking for values.h
configure:5901: checking f2c.h usability
conftest.c:58:10: fatal error: f2c.h: No such file or directory
   58 | #include <f2c.h>
configure:5901: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_LIMITS_H 1
| #define HAVE_TERMIO_H 1
| #define HAVE_TERMIOS_H 1
| #define HAVE_VALUES_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| #  include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <f2c.h>
configure:5901: result: no
configure:5901: checking f2c.h presence
conftest.c:25:10: fatal error: f2c.h: No such file or directory
   25 | #include <f2c.h>
| /* confdefs.h */
| #include <f2c.h>
configure:5901: checking for f2c.h
configure:5901: checking g2c.h usability
conftest.c:58:10: fatal error: g2c.h: No such file or directory
   58 | #include <g2c.h>
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <g2c.h>
configure:5901: checking g2c.h presence
conftest.c:25:10: fatal error: g2c.h: No such file or directory
   25 | #include <g2c.h>
| /* confdefs.h */
| #include <g2c.h>
configure:5901: checking for g2c.h
configure:5914: checking sys/ioctl.h usability
configure:5914: gcc -c -g -O2   conftest.c >&5
configure:5914: $? = 0
configure:5914: result: yes
configure:5914: checking sys/ioctl.h presence
configure:5914: gcc -E  conftest.c
configure:5914: checking for sys/ioctl.h
configure:5914: checking sys/mtio.h usability
configure:5914: checking sys/mtio.h presence
configure:5914: checking for sys/mtio.h
configure:5914: checking sys/resource.h usability
configure:5914: checking sys/resource.h presence
configure:5914: checking for sys/resource.h
configure:5914: checking sys/time.h usability
configure:5914: checking sys/time.h presence
configure:5914: checking for sys/time.h
configure:5927: checking sys/timeb.h usability
configure:5927: gcc -c -g -O2   conftest.c >&5
configure:5927: $? = 0
configure:5927: result: yes
configure:5927: checking sys/timeb.h presence
configure:5927: gcc -E  conftest.c
configure:5927: checking for sys/timeb.h
configure:5927: checking for sys/types.h
configure:5927: checking sys/utsname.h usability
configure:5927: checking sys/utsname.h presence
configure:5927: checking for sys/utsname.h
configure:5940: checking libintl.h usability
configure:5940: gcc -c -g -O2   conftest.c >&5
configure:5940: $? = 0
configure:5940: result: yes
configure:5940: checking libintl.h presence
configure:5940: gcc -E  conftest.c
configure:5940: checking for libintl.h
configure:5940: checking iconv.h usability
configure:5940: checking iconv.h presence
configure:5940: checking for iconv.h
configure:5952: checking langinfo.h usability
configure:5952: gcc -c -g -O2   conftest.c >&5
configure:5952: $? = 0
configure:5952: result: yes
configure:5952: checking langinfo.h presence
configure:5952: gcc -E  conftest.c
configure:5952: checking for langinfo.h
configure:5962: checking whether time.h and sys/time.h may both be included
configure:5980: gcc -c -g -O2   conftest.c >&5
configure:5980: $? = 0
configure:5986: result: yes
configure:5994: checking for off_t
configure:5994: gcc -c -g -O2   conftest.c >&5
configure:5994: $? = 0
conftest.c: In function 'main':
conftest.c:72:20: error: expected expression before ')' token
   72 | if (sizeof ((off_t)))
configure:5994: $? = 1
| /* confdefs.h */
| #define HAVE_SYS_IOCTL_H 1
| #define HAVE_SYS_MTIO_H 1
| #define HAVE_SYS_RESOURCE_H 1
| #define HAVE_SYS_TIME_H 1
| #define HAVE_SYS_TIMEB_H 1
| #define HAVE_SYS_UTSNAME_H 1
| #define HAVE_LIBINTL_H 1
| #define HAVE_ICONV_H 1
| #define HAVE_LANGINFO_H 1
| #define TIME_WITH_SYS_TIME 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| 	    return 0;
|   return 0;
configure:5994: result: yes
configure:6005: checking for uid_t in sys/types.h
configure:6021: result: yes
configure:6042: checking for ftime
configure:6042: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6042: $? = 0
configure:6042: result: yes
configure:6042: checking for gethostname
configure:6042: checking for gettimeofday
configure:6042: checking for lseek
configure:6042: checking for nice
configure:6042: checking for time
configure:6042: checking for uname
configure:6054: checking for seteuid
configure:6054: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6054: $? = 0
configure:6054: result: yes
configure:6054: checking for setpriority
configure:6054: checking for setreuid
configure:6054: checking for setruid
/usr/bin/ld: /tmp/cca31rAg.o: in function `main':
/home/rshepard/gis/grass/grass-8.2.1/conftest.c:80: undefined reference to `setruid'
configure:6054: $? = 1
| /* confdefs.h */
| #define HAVE_FTIME 1
| #define HAVE_GETHOSTNAME 1
| #define HAVE_GETTIMEOFDAY 1
| #define HAVE_LSEEK 1
| #define HAVE_NICE 1
| #define HAVE_TIME 1
| #define HAVE_UNAME 1
| #define HAVE_SETEUID 1
| #define HAVE_SETPRIORITY 1
| #define HAVE_SETREUID 1
| /* Define setruid to an innocuous variant, in case <limits.h> declares setruid.
|    For example, HP-UX 11i <limits.h> declares gettimeofday.  */
| #define setruid innocuous_setruid
| /* System header to define __stub macros and hopefully few prototypes,
|     which can conflict with char setruid (); below.
|     Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
|     <limits.h> exists even on freestanding compilers.  */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef setruid
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| char setruid ();
| /* The GNU C library defines this for functions which it implements
|     to always fail with ENOSYS.  Some functions are actually named
|     something starting with __ and the normal name is an alias.  */
| #if defined __stub_setruid || defined __stub___setruid
| choke me
| #endif
| int
| main ()
| return setruid ();
|   return 0;
configure:6054: result: no
configure:6065: checking for drand48
configure:6065: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6065: $? = 0
configure:6065: result: yes
configure:6077: checking for putenv
configure:6077: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6077: $? = 0
configure:6077: result: yes
configure:6077: checking for setenv
configure:6088: checking for nanosleep
configure:6088: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6088: $? = 0
configure:6088: result: yes
configure:6098: checking whether setpgrp takes no argument
configure:6118: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
conftest.c:89:10: error: too many arguments to function 'setpgrp'
   89 |   return setpgrp (1,1) != -1;
In file included from conftest.c:81:
/usr/include/unistd.h:672:12: note: declared here
  672 | extern int setpgrp (void) __THROW;
configure:6118: $? = 1
configure: program exited with status 1
| /* confdefs.h */
| #define HAVE_NICE 1
| #define HAVE_TIME 1
| #define HAVE_DRAND48 1
| #define HAVE_PUTENV 1
| #define HAVE_SETENV 1
| #define HAVE_NANOSLEEP 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| /* If this system has a BSD-style setpgrp which takes arguments,
|   setpgrp(1, 1) will fail with ESRCH and return -1, in that case
|   exit successfully. */
|   return 0;
configure:6127: result: yes
configure:6140: checking for long long int
configure:6153: gcc -c -g -O2   conftest.c >&5
configure:6153: $? = 0
configure:6155: result: yes
configure:6169: checking for int64_t
configure:6182: gcc -c -g -O2   conftest.c >&5
configure:6182: $? = 0
configure:6184: result: yes
configure:6198: checking for W11
configure:6201: result: "no"
configure:6223: checking for X
configure:6360: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lX11  >&5
configure:6360: $? = 0
configure:6409: result: libraries , headers
configure:6508: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c   -lX11 >&5
configure:6508: $? = 0
configure:6600: checking for gethostbyname
configure:6600: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6600: $? = 0
configure:6600: result: yes
configure:6691: checking for connect
configure:6691: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6691: $? = 0
configure:6691: result: yes
configure:6737: checking for remove
configure:6737: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6737: $? = 0
configure:6737: result: yes
configure:6783: checking for shmat
configure:6783: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6783: $? = 0
configure:6783: result: yes
configure:6838: checking for IceConnectionNumber in -lICE
configure:6861: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lICE   >&5
configure:6861: $? = 0
configure:6869: result: yes
configure:6894: checking for library containing cuserid
configure:6923: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6923: $? = 0
configure:6939: result: none required
configure:6953: checking for asprintf
configure:6953: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:6953: $? = 0
configure:6953: result: yes
configure:6965: checking for atan
configure:6965: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
conftest.c:77:6: warning: conflicting types for built-in function 'atan'; expected 'double(double)' [-Wbuiltin-declaration-mismatch]
   77 | char atan ();
conftest.c:65:1: note: 'atan' is declared in header '<math.h>'
   64 | # include <limits.h>
   65 | #else
/usr/bin/ld: /tmp/ccFZFJBU.o: in function `main':
/home/rshepard/gis/grass/grass-8.2.1/conftest.c:88: undefined reference to `atan'
configure:6965: $? = 1
| /* confdefs.h */
| #define HAVE_NICE 1
| #define HAVE_TIME 1
| #define SETPGRP_VOID 1
| #define HAVE_LONG_LONG_INT 1
| #define HAVE_INT64_T 1
| #define HAVE_ASPRINTF 1
| /* Define atan to an innocuous variant, in case <limits.h> declares atan.
| #define atan innocuous_atan
|     which can conflict with char atan (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef atan
| #ifdef __cplusplus
| extern "C"
| #endif
| char atan ();
| #if defined __stub_atan || defined __stub___atan
| choke me
| #endif
| int
| main ()
| return atan ();
|   return 0;
configure:6965: result: no
configure:6970: checking for atan in -lm
configure:6993: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lm   >&5
conftest.c:61:6: warning: conflicting types for built-in function 'atan'; expected 'double(double)' [-Wbuiltin-declaration-mismatch]
   61 | char atan ();
conftest.c:1:1: note: 'atan' is declared in header '<math.h>'
    1 | /* confdefs.h */
configure:6993: $? = 0
configure:7001: result: yes
configure:7015: checking for dlsym
configure:7015: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
/usr/bin/ld: /tmp/ccRDVaux.o: in function `main':
/home/rshepard/gis/grass/grass-8.2.1/conftest.c:88: undefined reference to `dlsym'
configure:7015: $? = 1
| /* confdefs.h */
| #define HAVE_NICE 1
| #define HAVE_TIME 1
| /* Define dlsym to an innocuous variant, in case <limits.h> declares dlsym.
| #define dlsym innocuous_dlsym
|     which can conflict with char dlsym (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef dlsym
| #ifdef __cplusplus
| extern "C"
| #endif
| char dlsym ();
| #if defined __stub_dlsym || defined __stub___dlsym
| choke me
| #endif
| int
| main ()
| return dlsym ();
|   return 0;
configure:7015: result: no
configure:7020: checking for dlsym in -ldl
configure:7043: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c -ldl   >&5
configure:7043: $? = 0
configure:7051: result: yes
configure:7065: checking for iconv
configure:7065: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:7065: $? = 0
configure:7065: result: yes
configure:7242: checking for socket
configure:7242: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:7242: $? = 0
configure:7242: result: yes
configure:7313: checking for location of zlib includes
configure:7320: result:
configure:7339: checking zlib.h usability
configure:7339: gcc -c -g -O2    conftest.c >&5
configure:7339: $? = 0
configure:7339: result: yes
configure:7339: checking zlib.h presence
configure:7339: gcc -E   conftest.c
configure:7339: checking for zlib.h
configure:7359: checking for location of zlib library
configure:7366: result:
configure:7385: checking for deflate in -lz
configure:7408: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lz   >&5
configure:7408: $? = 0
configure:7416: result: yes
configure:7449: checking whether to use bzlib
configure:7451: result: "no"
configure:7604: checking whether to use zstd
configure:7606: result: "yes"
configure:7621: checking for location of zstd includes
configure:7628: result:
configure:7646: checking zstd.h usability
configure:7646: gcc -c -g -O2    conftest.c >&5
configure:7646: $? = 0
configure:7646: result: yes
configure:7646: checking zstd.h presence
configure:7646: gcc -E   conftest.c
configure:7646: checking for zstd.h
configure:7666: checking for location of zstd library
configure:7673: result:
configure:7692: checking for ZSTD_compress in -lzstd
configure:7715: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lzstd   >&5
configure:7715: $? = 0
configure:7723: result: yes
configure:7762: checking for location of External PROJ includes
configure:7769: result:
configure:7789: checking proj.h usability
configure:7789: gcc -c -g -O2    conftest.c >&5
configure:7789: $? = 0
configure:7789: result: yes
configure:7789: checking proj.h presence
configure:7789: gcc -E   conftest.c
configure:7789: checking for proj.h
configure:7806: checking External PROJ major version
configure:7827: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:7827: $? = 0
configure:7827: ./conftest
configure:7829: result: 9
configure:7841: checking External PROJ minor version
configure:7862: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:7862: $? = 0
configure:7862: ./conftest
configure:7864: result: 1
configure:7876: checking External PROJ patch version
configure:7897: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c  >&5
configure:7897: $? = 0
configure:7897: ./conftest
configure:7899: result: 1
configure:7910: result: found PROJ version "9.1.1"
configure:7967: result: using new PROJ version 5+ API
configure:7973: checking for location of External PROJ library
configure:7980: result:
configure:7998: checking for proj_pj_info in -lproj
configure:8021: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lproj   >&5
configure:8021: $? = 0
configure:8029: result: yes
configure:8202: checking for location of External PROJ data files
configure:8209: result: /usr/share/proj
configure:8271: checking whether to use regex
configure:8273: result: "yes"
configure:8292: checking for location of regex includes
configure:8299: result:
configure:8318: checking regex.h usability
configure:8318: gcc -c -g -O2    conftest.c >&5
configure:8318: $? = 0
configure:8318: result: yes
configure:8318: checking regex.h presence
configure:8318: gcc -E   conftest.c
configure:8318: checking for regex.h
configure:8338: checking for location of regex library
configure:8345: result:
configure:8364: checking for regcomp
configure:8364: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c    >&5
configure:8364: $? = 0
configure:8364: result: yes
configure:8446: checking whether to use Readline
configure:8448: result: "no"
configure:8674: checking whether to use GDAL
configure:8690: result: yes
configure:8694: checking for gdal-config
configure:8710: found /usr/bin/gdal-config
configure:8722: result: /usr/bin/gdal-config
configure:8764: gcc -o conftest -g -O2  -I/usr/include   -Wl,--export-dynamic  -L/usr/lib64 conftest.c  -L/usr/lib64 -lgdal >&5
conftest.c:64:1: warning: ignoring return value of 'GDALOpen' declared with attribute 'warn_unused_result' [-Wunused-result]
   64 | GDALOpen("foo", GA_ReadOnly);
configure:8764: $? = 0
configure:8808: checking whether to use libLAS
configure:8820: result: no
configure:8949: checking whether to use PDAL
configure:8971: result: yes
configure:8975: checking for pdal-config
configure:8991: found /usr/bin/pdal-config
configure:9003: result: /usr/bin/pdal-config
configure:9082: checking for g++
configure:9096: found /usr/bin/g++
configure:9106: result: g++
configure:9133: checking for C++ compiler version
configure:9142: g++ --version >&5
g++ (GCC) 11.2.0
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:9153: $? = 0
configure:9142: g++ -v >&5
Reading specs from /usr/lib64/gcc/x86_64-slackware-linux/11.2.0/specs
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-slackware-linux/11.2.0/lto-wrapper
Target: x86_64-slackware-linux
Configured with: ../configure --prefix=/usr --libdir=/usr/lib64 --mandir=/usr/man --infodir=/usr/info --enable-shared --enable-bootstrap --enable-languages=ada,brig,c,c++,d,fortran,go,lto,objc,obj-c++ --enable-threads=posix --enable-checking=release --enable-objc-gc --with-system-zlib --enable-libstdcxx-dual-abi --with-default-libstdcxx-abi=new --disable-libstdcxx-pch --disable-libunwind-exceptions --enable-__cxa_atexit --disable-libssp --enable-gnu-unique-object --enable-plugin --enable-lto --disable-install-libiberty --disable-werror --with-gnu-ld --with-isl --verbose --with-arch-directory=amd64 --disable-gtktest --enable-clocale=gnu --disable-multilib --target=x86_64-slackware-linux --build=x86_64-slackware-linux --host=x86_64-slackware-linux
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.2.0 (GCC)
configure:9142: g++ -V >&5
g++: error: unrecognized command-line option '-V'
g++: fatal error: no input files
compilation terminated.
configure:9153: $? = 1
configure:9142: g++ -qversion >&5
g++: error: unrecognized command-line option '-qversion'; did you mean '--version'?
configure:9157: checking whether we are using the GNU C++ compiler
configure:9174: g++ -c   conftest.cpp >&5
configure:9174: $? = 0
configure:9182: result: yes
configure:9191: checking whether g++ accepts -g
configure:9209: g++ -c -g  conftest.cpp >&5
configure:9209: $? = 0
configure:9249: result: yes
configure:9286: g++ -o conftest -g -O2   -Wl,--export-dynamic  -L/usr/lib64 conftest.cpp  -L/usr/lib -lpdalcpp >&5
configure:9286: $? = 0
configure:9338: checking whether to use NetCDF
configure:9350: result: no
configure:9462: checking whether to use GEOS
configure:9478: result: yes
configure:9482: checking for geos-config
configure:9498: found /usr/bin/geos-config
configure:9510: result: /usr/bin/geos-config
configure:9534: checking geos_c.h usability
configure:9534: gcc -c -g -O2  -I/usr/include  conftest.c >&5
configure:9534: $? = 0
configure:9534: result: yes
configure:9534: checking geos_c.h presence
configure:9534: gcc -E -I/usr/include  conftest.c
configure:9534: checking for geos_c.h
configure:9559: checking for initGEOS in -lgeos_c
configure:9582: gcc -o conftest -g -O2   -L/usr/lib64 -lgeos_c  -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lgeos_c   >&5
configure:9582: $? = 0
configure:9590: result: yes
configure:9620: checking whether to use TIFF
configure:9622: result: "yes"
configure:9641: checking for location of TIFF includes
configure:9648: result:
configure:9667: checking tiffio.h usability
configure:9667: gcc -c -g -O2    conftest.c >&5
configure:9667: $? = 0
configure:9667: result: yes
configure:9667: checking tiffio.h presence
configure:9667: gcc -E   conftest.c
configure:9667: checking for tiffio.h
configure:9687: checking for location of TIFF library
configure:9694: result:
configure:9719: checking for TIFFOpen in -ltiff
configure:9742: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -ltiff   >&5
configure:9742: $? = 0
configure:9750: result: yes
configure:10094: checking whether to use PNG
configure:10096: result: "yes"
configure:10114: checking for location of PNG includes
configure:10121: result:
configure:10140: checking png.h usability
configure:10140: gcc -c -g -O2    conftest.c >&5
configure:10140: $? = 0
configure:10140: result: yes
configure:10140: checking png.h presence
configure:10140: gcc -E   conftest.c
configure:10140: checking for png.h
configure:10160: checking for location of PNG library
configure:10167: result:
configure:10186: checking for png_read_image in -lpng
configure:10209: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lpng  -lz  -lm  >&5
configure:10209: $? = 0
configure:10217: result: yes
configure:10246: checking whether to use PostgreSQL
configure:10248: result: "yes"
configure:10273: checking for location of PostgreSQL includes
configure:10280: result: /usr/include/postgresql/server/
configure:10299: checking libpq-fe.h usability
configure:10299: gcc -c -g -O2   -I/usr/include/postgresql/server/  conftest.c >&5
configure:10299: $? = 0
configure:10299: result: yes
configure:10299: checking libpq-fe.h presence
configure:10299: gcc -E  -I/usr/include/postgresql/server/  conftest.c
configure:10299: checking for libpq-fe.h
configure:10323: checking for location of PostgreSQL library
configure:10330: result: /usr/lib64/postgresql/14/lib/
configure:10353: checking for PQsetdbLogin in -lpq
configure:10376: gcc -o conftest -g -O2    -L/usr/lib64/postgresql/14/lib/  -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lpq   >&5
configure:10376: $? = 0
configure:10384: result: yes
configure:10539: checking for PQcmdTuples in -lpq
configure:10562: gcc -o conftest -g -O2    -Wl,--export-dynamic  -L/usr/lib64  -L/usr/lib64/postgresql/14/lib/ conftest.c -lpq   >&5
configure:10562: $? = 0
configure:10570: result: yes
configure:10635: checking whether to use MySQL
configure:10637: result: "no"
configure:11188: checking whether to use SQLite
configure:11190: result: "yes"
configure:11209: checking for location of SQLite includes
configure:11216: result: /usr/include/
configure:11235: checking sqlite3.h usability
configure:11235: gcc -c -g -O2   -I/usr/include/  conftest.c >&5
configure:11235: $? = 0
configure:11235: result: yes
configure:11235: checking sqlite3.h presence
configure:11235: gcc -E  -I/usr/include/  conftest.c
configure:11235: checking for sqlite3.h
configure:11263: checking for location of SQLite library
configure:11270: result: /usr/lib/
configure:11293: checking for sqlite3_open in -lsqlite3
configure:11316: gcc -o conftest -g -O2    -L/usr/lib/  -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lsqlite3   >&5
configure:11316: $? = 0
configure:11324: result: yes
configure:11497: checking whether to use OpenGL
configure:11499: result: "yes"
configure:11532: checking for location of OpenGL includes
configure:11539: result:
configure:11559: checking GL/gl.h usability
configure:11559: gcc -c -g -O2     conftest.c >&5
configure:11559: $? = 0
configure:11559: result: yes
configure:11559: checking GL/gl.h presence
configure:11559: gcc -E    conftest.c
configure:11559: checking for GL/gl.h
configure:11559: checking GL/glu.h usability
configure:11559: checking GL/glu.h presence
configure:11559: checking for GL/glu.h
configure:11579: checking for location of OpenGL library
configure:11586: result:
configure:11609: checking for glBegin in -lGL
configure:11632: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lGL   -lSM -lICE -lX11  -lm   >&5
configure:11632: $? = 0
configure:11640: result: yes
configure:11800: checking for gluBeginCurve in -lGLU
configure:11823: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lGLU  -lGL    -lSM -lICE -lX11  -lm   >&5
configure:11823: $? = 0
configure:11831: result: yes
configure:11902: checking for glXCreatePbuffer
configure:11902: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c    -lGL   >&5
configure:11902: $? = 0
configure:11902: result: yes
configure:11925: checking for glXCreateGLXPixmap
configure:11925: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c    -lGL   >&5
configure:11925: $? = 0
configure:11925: result: yes
configure:12227: checking whether to use ODBC
configure:12229: result: "no"
configure:12472: checking whether to use FFTW
configure:12474: result: "yes"
configure:12492: checking for location of FFTW includes
configure:12499: result:
configure:12518: checking fftw3.h usability
configure:12518: gcc -c -g -O2    conftest.c >&5
configure:12518: $? = 0
configure:12518: result: yes
configure:12518: checking fftw3.h presence
configure:12518: gcc -E   conftest.c
configure:12518: checking for fftw3.h
configure:12576: checking for location of FFTW library
configure:12583: result:
configure:12602: checking for fftw_execute in -lfftw3
configure:12625: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lfftw3 -lm  >&5
configure:12625: $? = 0
configure:12633: result: yes
configure:12763: checking whether to use BLAS
configure:12765: result: "yes"
configure:12785: checking for location of BLAS includes
configure:12792: result:
configure:12806: checking for location of BLAS library
configure:12813: result:
configure:12832: checking cblas.h usability
configure:12832: gcc -c -g -O2    conftest.c >&5
configure:12832: $? = 0
configure:12832: result: yes
configure:12832: checking cblas.h presence
configure:12832: gcc -E   conftest.c
configure:12832: checking for cblas.h
configure:12851: checking for dnrm2_ in -lblas
configure:12874: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lblas -lm   >&5
/usr/bin/ld: cannot find -lblas
collect2: error: ld returned 1 exit status
configure:12874: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| #define HAVE_NICE 1
| #define HAVE_TIME 1
| #define HAVE_SOCKET 1
| #define HAVE_ZLIB_H 1
| #define HAVE_ZSTD_H 1
| #define HAVE_PROJ_H 1
| #define HAVE_REGEX_H 1
| #define HAVE_OGR 1
| #define HAVE_GDAL 1
| #define HAVE_PDAL 1
| #define HAVE_GEOS_C_H 1
| #define HAVE_GEOS 1
| #define HAVE_TIFFIO_H 1
| #define HAVE_PNG_H 1
| #define HAVE_POSTGRES 1
| #define HAVE_LIBPQ_FE_H 1
| #define HAVE_PQCMDTUPLES 1
| #define HAVE_SQLITE3_H 1
| #define HAVE_SQLITE 1
| #define HAVE_GL_GL_H 1
| #define HAVE_GL_GLU_H 1
| #define HAVE_PBUFFERS 1
| #define HAVE_PIXMAPS 1
| #define OPENGL_X11 1
| #define HAVE_FFTW3_H 1
| #define HAVE_CBLAS_H 1
| /* end confdefs.h.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| char dnrm2_ ();
| int
| main ()
| return dnrm2_ ();
|   return 0;
configure:12882: result: no
configure:12888: checking for dnrm2_ in -lblas
configure:12911: gcc -o conftest -g -O2     -Wl,--export-dynamic  -L/usr/lib64 conftest.c -lblas -lm -lg2c  >&5
configure:12911: $? = 1
| /* confdefs.h */
| #define HAVE_NICE 1
| #define HAVE_TIME 1
| #define HAVE_OGR 1
| #define HAVE_GDAL 1
| #define HAVE_PDAL 1
| #define HAVE_GEOS 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char dnrm2_ ();
| int
| main ()
| return dnrm2_ ();
|   return 0;
configure:12919: result: no
configure:12927: error: *** Unable to locate BLAS library.
## Cache variables. ##
ac_cv_build=x86_64-pc-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_YACC_set=
ac_cv_env_YACC_value=
ac_cv_env_YFLAGS_set=
ac_cv_env_YFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_exeext=no
ac_cv_func_asprintf=yes
ac_cv_func_atan=no
ac_cv_func_connect=yes
ac_cv_func_dlsym=no
ac_cv_func_drand48=yes
ac_cv_func_ftime=yes
ac_cv_func_gethostbyname=yes
ac_cv_func_gethostname=yes
ac_cv_func_gettimeofday=yes
ac_cv_func_glXCreateGLXPixmap=yes
ac_cv_func_glXCreatePbuffer=yes
ac_cv_func_iconv=yes
ac_cv_func_lseek=yes
ac_cv_func_nanosleep=yes
ac_cv_func_nice=yes
ac_cv_func_putenv=yes
ac_cv_func_regcomp=yes
ac_cv_func_remove=yes
ac_cv_func_setenv=yes
ac_cv_func_seteuid=yes
ac_cv_func_setpgrp_void=yes
ac_cv_func_setpriority=yes
ac_cv_func_setreuid=yes
ac_cv_func_setruid=no
ac_cv_func_shmat=yes
ac_cv_func_socket=yes
ac_cv_func_time=yes
ac_cv_func_uname=yes
ac_cv_have_x='have_x=yes	ac_x_includes='\'''\''	ac_x_libraries='\'''\'''
ac_cv_header_GL_gl_h=yes
ac_cv_header_GL_glu_h=yes
ac_cv_header_cblas_h=yes
ac_cv_header_f2c_h=no
ac_cv_header_fftw3_h=yes
ac_cv_header_g2c_h=no
ac_cv_header_geos_c_h=yes
ac_cv_header_iconv_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_langinfo_h=yes
ac_cv_header_libintl_h=yes
ac_cv_header_libpq_fe_h=yes
ac_cv_header_limits_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_png_h=yes
ac_cv_header_proj_h=yes
ac_cv_header_regex_h=yes
ac_cv_header_sqlite3_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_ioctl_h=yes
ac_cv_header_sys_mtio_h=yes
ac_cv_header_sys_resource_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_time_h=yes
ac_cv_header_sys_timeb_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_sys_utsname_h=yes
ac_cv_header_termio_h=yes
ac_cv_header_termios_h=yes
ac_cv_header_tiffio_h=yes
ac_cv_header_time=yes
ac_cv_header_unistd_h=yes
ac_cv_header_values_h=yes
ac_cv_header_zlib_h=yes
ac_cv_header_zstd_h=yes
ac_cv_host=x86_64-pc-linux-gnu
ac_cv_lib_GLU_gluBeginCurve=yes
ac_cv_lib_GL_glBegin=yes
ac_cv_lib_ICE_IceConnectionNumber=yes
ac_cv_lib_blas_dnrm2_=no
ac_cv_lib_dl_dlsym=yes
ac_cv_lib_fftw3_fftw_execute=yes
ac_cv_lib_geos_c_initGEOS=yes
ac_cv_lib_lex=-lfl
ac_cv_lib_m_atan=yes
ac_cv_lib_png_png_read_image=yes
ac_cv_lib_pq_PQcmdTuples=yes
ac_cv_lib_pq_PQsetdbLogin=yes
ac_cv_lib_proj_proj_pj_info=yes
ac_cv_lib_sqlite3_sqlite3_open=yes
ac_cv_lib_tiff_TIFFOpen=yes
ac_cv_lib_z_deflate=yes
ac_cv_lib_zstd_ZSTD_compress=yes
ac_cv_objext=o
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_GDAL_CONFIG=/usr/bin/gdal-config
ac_cv_path_GEOS_CONFIG=/usr/bin/geos-config
ac_cv_path_GIT=/usr/bin/git
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_PDAL_CONFIG=/usr/bin/pdal-config
ac_cv_path_PERL=/usr/bin/perl
ac_cv_path_install='/usr/bin/ginstall -c'
ac_cv_path_pwd=/usr/bin/pwd
ac_cv_prog_AR=ar
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_ENV=env
ac_cv_prog_LEX=flex
ac_cv_prog_YACC='bison -y'
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_lex_root=lex.yy
ac_cv_prog_lex_yytext_pointer=yes
ac_cv_search_cuserid='none required'
ac_cv_type_off_t=yes
ac_cv_type_uid_t=yes
## Output variables. ##
AR='ar'
ARCH='x86_64-pc-linux-gnu'
BINDIR='${exec_prefix}/bin'
BLASINC=''
BLASLIB=''
BZIP2INCPATH=''
BZIP2LIB=''
BZIP2LIBPATH=''
CAIROINC=''
CAIROLIB=''
CAIRO_HAS_XRENDER=''
CAIRO_HAS_XRENDER_SURFACE=''
CC='gcc'
CFLAGS='-g -O2 '
CPP='gcc -E'
CPPFLAGS=''
CROSS_COMPILING=''
CXX='g++'
CXXFLAGS='-g -O2'
DBMIEXTRALIB=''
DEFS=''
DLLIB='-ldl'
DSTDIR='/home/rshepard/gis/grass/grass-8.2.1'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
ENV='env'
EXEEXT=''
FFTWINC=''
FFTWLIB=' -lfftw3 -lm'
FTINC=''
FTLIB=''
GDAL_CFLAGS='-I/usr/include'
GDAL_CONFIG='/usr/bin/gdal-config'
GDAL_LIBS='-L/usr/lib64 -lgdal'
GEOS_CFLAGS='-I/usr/include'
GEOS_CONFIG='/usr/bin/geos-config'
GEOS_LIBS='-L/usr/lib64 -lgeos_c -lgeos_c '
GISBASE='/home/rshepard/gis/grass/grass-8.2.1/dist.x86_64-pc-linux-gnu'
GIT='/usr/bin/git'
GRASS_BIN='/home/rshepard/gis/grass/grass-8.2.1/bin.x86_64-pc-linux-gnu'
GRASS_HEADERS_GIT_DATE='2023-04-25T01:00:00-07:00'
GRASS_HEADERS_GIT_HASH='8.2.1'
GRASS_HOME=''
GRASS_LIBRARY_TYPE='shlib'
GRASS_VERSION_DATE='2023'
GRASS_VERSION_FILE='include/VERSION'
GRASS_VERSION_GIT='exported'
GRASS_VERSION_MAJOR='8'
GRASS_VERSION_MINOR='2'
GRASS_VERSION_NUMBER='8.2.1'
GRASS_VERSION_RELEASE='1'
GREP='/usr/bin/grep'
HAVE_ASPRINTF=''
HAVE_NLS=''
HAVE_SOCKET='1'
HISTORYLIB=''
ICONVLIB=''
INCLUDE_DIRS=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTDIR='${prefix}/grass82'
INTLLIB=''
LAPACKINC=''
LAPACKLIB=''
LDFLAGS=' -Wl,--export-dynamic  -L/usr/lib64'
LD_LIBRARY_PATH_VAR='LD_LIBRARY_PATH'
LD_SEARCH_FLAGS='-Wl,-rpath-link,${LIB_RUNTIME_DIR} -Wl,-rpath,${INST_DIR}/lib'
LEX='flex'
LEXLIB='-lfl'
LEXPATH=''
LEX_OUTPUT_ROOT='lex.yy'
LFS_CFLAGS=''
LIBLAS_CFLAGS=''
LIBLAS_CONFIG=''
LIBLAS_INC=''
LIBLAS_LIBS=''
LIBOBJS=''
LIBRARY_DIRS=' -L/usr/lib64'
LIBS=''
LIB_VER='8.2.1'
LTLIBOBJS=''
MACOSX_APP=''
MACOSX_ARCHS=''
MACOSX_SDK=''
MATHLIB='-lm'
MINGW32=''
MYSQLDLIB=''
MYSQLD_CONFIG=''
MYSQLINCPATH=''
MYSQLLIB=''
MYSQLLIBPATH=''
NAME_VER='8'
NETCDF_CFLAGS=''
NETCDF_CONFIG=''
NETCDF_LIBS=''
OBJEXT='o'
OCLINCPATH=''
OCLLIB=''
OCLLIBPATH=''
ODBCINC=''
ODBCLIB=''
OMPCFLAGS=''
OMPINCPATH=''
OMPLIB=''
OMPLIBPATH=''
OPENDWGINCPATH=''
OPENDWGLIB=''
OPENDWGLIBPATH=''
OPENGLINC=''
OPENGLLIB='  -lGL '
OPENGLULIB='  -lGLU '
OPENGL_AQUA=''
OPENGL_WINDOWS=''
OPENGL_X11='1'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_URL=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PDAL_CONFIG='/usr/bin/pdal-config'
PDAL_CPPFLAGS=''
PDAL_INC='-I/usr/include -I/usr/include -I/usr/include/libxml2'
PDAL_LIBS='-L/usr/lib -lpdalcpp'
PERL='/usr/bin/perl'
PNGINC=''
PNGLIB=' -lpng  -lz  -lm'
PQINCPATH=' -I/usr/include/postgresql/server/'
PQLIB=' -lpq '
PQLIBPATH=' -L/usr/lib64/postgresql/14/lib/'
PROJINC=''
PROJLIB=' -lproj '
PROJSHARE='/usr/share/proj'
PTHREADINCPATH=''
PTHREADLIB=''
PTHREADLIBPATH=''
RANLIB='ranlib'
READLINEINCPATH=''
READLINELIB=''
READLINELIBPATH=''
REGEXINCPATH=''
REGEXLIB=' '
REGEXLIBPATH=''
SHELL='/bin/sh'
SHLIB_CFLAGS='-fPIC'
SHLIB_LD='gcc -shared'
SHLIB_LD_FLAGS='-Wl,-soname,$(notdir $@)'
SHLIB_SUFFIX='.so'
SOCKLIB=''
SQLITEINCPATH=' -I/usr/include/'
SQLITELIB=' -lsqlite3 '
SQLITELIBPATH=' -L/usr/lib/'
SRCDIR='/home/rshepard/gis/grass/grass-8.2.1'
STLIB_LD='${AR} cr'
STLIB_SUFFIX='.a'
STRIPFLAG=''
TIFFLIB=' -ltiff '
TIFF_INCLUDE_DIRS=''
TIFF_LIBRARY_DIRS=''
USE_CAIRO=''
USE_GDAL='1'
USE_GEOS='1'
USE_LARGEFILES=''
USE_LIBLAS=''
USE_MYSQL=''
USE_NETCDF=''
USE_OGR='1'
USE_OPENCL=''
USE_OPENDWG=''
USE_OPENGL='1'
USE_OPENMP=''
USE_PDAL='1'
USE_PNG='1'
USE_POSTGRES='1'
USE_PTHREAD=''
USE_REGEX='1'
USE_SQLITE='1'
USE_TERMIO=''
USE_X11='1'
WINDRES=''
XLIB='-lX11'
XMKMF=''
XTLIB='-lXt'
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=' -lSM -lICE'
YACC='bison -y'
YACCPATH=''
YFLAGS=''
ZLIB=' -lz '
ZLIBINCPATH=''
ZLIBLIBPATH=''
ZSTDINCPATH=''
ZSTDLIB=' -lzstd '
ZSTDLIBPATH=''
ac_ct_CC='gcc'
ac_ct_CXX='g++'
bindir='${exec_prefix}/bin'
build='x86_64-pc-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='pc'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='NONE'
host='x86_64-pc-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='pc'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
pwd='/usr/bin/pwd'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
/* confdefs.h */
#define HAVE_NICE 1
#define HAVE_TIME 1
#define HAVE_OGR 1
#define HAVE_GDAL 1
#define HAVE_PDAL 1
#define HAVE_GEOS 1
configure: exit 1
