[GRASS-user] Importing LiDAR data
    Maris Nartiss
    maris.gis at gmail.com
    Thu Apr 27 10:12:01 PDT 2023
Peaking at the file list you provided, you are dealing with already
processed LiDAR data in raster (and shapefile) format. Thus r.in.gdal
is the way to go.
r.in.las (obsolete) and r.in.pdal (the new way to go) deal with raw
point clouds in LAS format. They perform point binning according to
chosen criteria to generate a raster.
Māris.
ceturtd., 2023. g. 27. apr., plkst. 19:46 — lietotājs Rich Shepard
(<rshepard at appl-ecosys.com>) rakstīja:
> On Thu, 27 Apr 2023, Rich Shepard wrote:
> > There are raster LiDAR modules (r.in.gdal, r.in.lidar, r.in.pdal) and the
> > latter two work with .las files, so I assume that my data use r.in.gdal.
> > It's been a long time since I've build LiDAR maps and I ask for the proper
> > command lines to 1) set the location for import and 2) import the data. An
> > example file tree is 10,008 lines long and downloadable (for 5 days) from:
> > <https://tinyurl.com/mmkf8pcd>.
> For now, I'm interested in only the bare earth data; learning which files to
> use for the other data is still valuable.
> Regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
