[GRASS-user] Specify window size when grass invoked
    Rich Shepard
    rshepard at appl-ecosys.com
    Fri Apr 28 13:52:30 PDT 2023
On Fri, 28 Apr 2023, Micha Silver wrote:
> On my system it's ~/.grass8/wx.json, a json formatted config file.
Micha,
Same here. I didn't use more characers, only .grass.
> I think you should try to resize with the "handles" on the window corners.
>Then using the menu "Settings->Preferences" check the option "Save current
> window layout as default", and click "Save".  That should keep the window
> size for next time.
Will do. Thanks again,
Rich
