[GRASS-user] Development build not finding PDAL version installed
Markus Neteler
neteler at osgeo.org
Sat Feb 11 14:06:28 PST 2023
On Sat, Feb 11, 2023 at 9:22 PM Rich Shepard <rshepard at appl-ecosys.com> wrote:
> Trying to build source pulled from the repo failed here:
> checking whether to use GDAL... yes
> checking for gdal-config... /usr/bin/gdal-config
> checking whether to use libLAS... no
> checking whether to use PDAL... yes
> checking for pdal-config... /usr/bin/pdal-config
> configure: error: *** Unable to locate suitable (>=1.7.1) PDAL library.
> Yet, installed here is pdal-2.0.1-x86_64-1_SBo, which is certainly newer
> than 1.7.1.
> Please suggest how I make the installed pdal visible to the build process.
Did you install pdal-dev(el)? (the name depends on your Linux distro)
Markus
