[GRASS-user] single window gui crash with Ubuntu 22.04 LTS
Frank David
frank.david at geophom.fr
Mon Jan 2 06:53:35 PST 2023
Hello,
I've installed GRASS 8.2.0 in a fresh KDE UBUNTU 22.04 and the GUI
crash if the single window gui is enabled. As soon as I turn off this
choice in .grass8/wx.json file the GUI works.
console error message :
/usr/lib/grass82/scripts/g.extension:167: DeprecationWarning: The
distutils package is deprecated and slated for removal in Python 3.12.
Use setuptools or check PEP 632 for potential alternatives
from distutils.dir_util import copy_tree
File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
lambda event: event.callable(*event.args, **event.kw) )
File "/usr/lib/grass82/gui/wxpython/wxgui.py", line 95, in show_main_gui
mainframe = GMFrame(parent=None, id=wx.ID_ANY, workspace=self.workspaceFile)
File "/usr/lib/grass82/gui/wxpython/main_window/frame.py", line 164, in
__init__
self.BuildPanes()
File "/usr/lib/grass82/gui/wxpython/main_window/frame.py", line 645, in
BuildPanes
self._auimgr.AddPane(
File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/framemanager.py",
line 4711, in AddPane
return self.AddPane4(window, arg1, target)
line 4879, in AddPane4
self.UpdateNotebook()
line 6653, in UpdateNotebook
notebook.AddPage(pane.window, title, True, pane.icon)
File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/auibook.py", line
3575, in AddPage
return self.InsertPage(self.GetPageCount(), page, caption, select,
bitmap, disabled_bitmap, control, tooltip)
3653, in InsertPage
self.SetSelectionToWindow(page)
4410, in SetSelectionToWindow
self.SetSelection(idx)
4357, in SetSelection
ctrl.MakeTabVisible(ctrl_idx, ctrl)
1843, in MakeTabVisible
if not self.IsTabVisible(tabPage, self.GetTabOffset(), dc, win):
1732, in IsTabVisible
self.Render(dc, wnd)
1687, in Render
page.rect, tab_button.rect, x_extent = self._art.DrawTab(dc, wnd, page,
rect, tab_button.cur_state)
File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/tabart.py", line
475, in DrawTab
r.SetHeight(r.GetHeight()/2)
TypeError: Rect.SetHeight(): argument 1 has unexpected type 'float'
Is there a way to solve this ?
Thank you for the trick.
Regards,
Frank
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230102/c36972a5/attachment-0001.htm>
