[GRASS-user] single window gui crash with Ubuntu 22.04 LTS
    Maurício Vancine
    mauricio.vancine at gmail.com
    Mon Jan  2 09:52:15 PST 2023
Dear Frank,
I had the same problem and I solved it following this:
https://github.com/OSGeo/grass/issues/2690
Best,
Em seg., 2 de jan. de 2023 às 14:32, Micha Silver <tsvibar at gmail.com>
escreveu:
> I checked on my Debian 11 with KDE desktop. Recompiled 8.2 from git. No
> problem here.
> On 02/01/2023 16:53, Frank David wrote:
> Hello,
> I've installed GRASS 8.2.0 in a fresh KDE UBUNTU 22.04  and the GUI crash
> if the single window gui is enabled. As soon as I turn off this choice in
> .grass8/wx.json file the GUI works.
> console error message :
> /usr/lib/grass82/scripts/g.extension:167: DeprecationWarning: The
> distutils package is deprecated and slated for removal in Python 3.12. Use
> setuptools or check PEP 632 for potential alternatives
> from distutils.dir_util import copy_tree
> Traceback (most recent call last):
> File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
> lambda event: event.callable(*event.args, **event.kw) )
> File "/usr/lib/grass82/gui/wxpython/wxgui.py", line 95, in show_main_gui
> mainframe = GMFrame(parent=None, id=wx.ID_ANY,
> workspace=self.workspaceFile)
> File "/usr/lib/grass82/gui/wxpython/main_window/frame.py", line 164, in
> __init__
> self.BuildPanes()
> File "/usr/lib/grass82/gui/wxpython/main_window/frame.py", line 645, in
> BuildPanes
> self._auimgr.AddPane(
> File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/framemanager.py", line
> 4711, in AddPane
> return self.AddPane4(window, arg1, target)
> 4879, in AddPane4
> self.UpdateNotebook()
> 6653, in UpdateNotebook
> notebook.AddPage(pane.window, title, True, pane.icon)
> File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/auibook.py", line
> 3575, in AddPage
> return self.InsertPage(self.GetPageCount(), page, caption, select, bitmap,
> disabled_bitmap, control, tooltip)
> 3653, in InsertPage
> self.SetSelectionToWindow(page)
> 4410, in SetSelectionToWindow
> self.SetSelection(idx)
> 4357, in SetSelection
> ctrl.MakeTabVisible(ctrl_idx, ctrl)
> 1843, in MakeTabVisible
> if not self.IsTabVisible(tabPage, self.GetTabOffset(), dc, win):
> 1732, in IsTabVisible
> self.Render(dc, wnd)
> 1687, in Render
> page.rect, tab_button.rect, x_extent = self._art.DrawTab(dc, wnd, page,
> rect, tab_button.cur_state)
> File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/tabart.py", line 475,
> in DrawTab
> r.SetHeight(r.GetHeight()/2)
> TypeError: Rect.SetHeight(): argument 1 has unexpected type 'float'
> Is there a way to solve this ?
> Thank you for the trick.
> Regards,
> Frank
> grass-user mailing listgrass-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
*Maurício Vancine*
Doutorando em Ecologia, Evolução e Biodiversidade
Mestre em Zoologia
Ecólogo (ABE n. 2018007)
Universidade Estadual Paulista (UNESP), Rio Claro/SP, Brasil
Site <https://mauriciovancine.github.io/> | Lattes
<http://lattes.cnpq.br/9761288418931193> | Google Scholar
<https://scholar.google.com/citations?user=i-2xZBQAAAAJ> | ORCID
<https://orcid.org/0000-0001-9650-7575> | Publons
<https://publons.com/researcher/1391845/mauricio-vancine/> | GitHub
<https://github.com/mauriciovancine>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230102/fb17c9cc/attachment-0001.htm>
