[GRASS-user] single window gui crash with Ubuntu 22.04 LTS
Frank David
frank.david at geophom.fr
Tue Jan 3 01:26:07 PST 2023
Hello Micha,
Thank you for your message. I never succeed to compile grass 8.2 on
debian11... so I moved to Ubuntu.
I think there is a lack of documentation about grass 8.2 compilation on
debian11 for intermediate users like me !
Regards,
Frank
Le 02/01/2023 à 18:32, Micha Silver a écrit :
> I checked on my Debian 11 with KDE desktop. Recompiled 8.2 from git.
> No problem here.
> On 02/01/2023 16:53, Frank David wrote:
>> Hello,
>> I've installed GRASS 8.2.0 in a fresh KDE UBUNTU 22.04 and the GUI
>> crash if the single window gui is enabled. As soon as I turn off this
>> choice in .grass8/wx.json file the GUI works.
>> console error message :
>> /usr/lib/grass82/scripts/g.extension:167: DeprecationWarning: The
>> distutils package is deprecated and slated for removal in Python
>> 3.12. Use setuptools or check PEP 632 for potential alternatives
>> from distutils.dir_util import copy_tree
>> Traceback (most recent call last):
>> File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
>> lambda event: event.callable(*event.args, **event.kw) )
>> File "/usr/lib/grass82/gui/wxpython/wxgui.py", line 95, in show_main_gui
>> mainframe = GMFrame(parent=None, id=wx.ID_ANY,
>> workspace=self.workspaceFile)
>> File "/usr/lib/grass82/gui/wxpython/main_window/frame.py", line 164,
>> in __init__
>> self.BuildPanes()
>> File "/usr/lib/grass82/gui/wxpython/main_window/frame.py", line 645,
>> in BuildPanes
>> self._auimgr.AddPane(
>> File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/framemanager.py",
>> line 4711, in AddPane
>> return self.AddPane4(window, arg1, target)
>> line 4879, in AddPane4
>> self.UpdateNotebook()
>> line 6653, in UpdateNotebook
>> notebook.AddPage(pane.window, title, True, pane.icon)
>> File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/auibook.py", line
>> 3575, in AddPage
>> return self.InsertPage(self.GetPageCount(), page, caption, select,
>> bitmap, disabled_bitmap, control, tooltip)
>> 3653, in InsertPage
>> self.SetSelectionToWindow(page)
>> 4410, in SetSelectionToWindow
>> self.SetSelection(idx)
>> 4357, in SetSelection
>> ctrl.MakeTabVisible(ctrl_idx, ctrl)
>> 1843, in MakeTabVisible
>> if not self.IsTabVisible(tabPage, self.GetTabOffset(), dc, win):
>> 1732, in IsTabVisible
>> self.Render(dc, wnd)
>> 1687, in Render
>> page.rect, tab_button.rect, x_extent = self._art.DrawTab(dc, wnd,
>> page, rect, tab_button.cur_state)
>> File "/usr/lib/python3/dist-packages/wx/lib/agw/aui/tabart.py", line
>> 475, in DrawTab
>> r.SetHeight(r.GetHeight()/2)
>> TypeError: Rect.SetHeight(): argument 1 has unexpected type 'float'
>> Is there a way to solve this ?
>> Thank you for the trick.
>> Regards,
>> Frank
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230103/943d7d34/attachment-0001.htm>
