[GRASS-user] How to use g.extension in GRASS7.8
Bernardo Santos
bernardo_brandaum at yahoo.com.br
Tue Jan 10 01:58:53 PST 2023
Hi Stefan,
this worked perfectly for now! Thanks!BestBernardo
Em terça-feira, 10 de janeiro de 2023 07:37:15 GMT+1, Stefan Blumentrath <stefan.blumentrath at gmx.de> escreveu:
Hei Bernardo,
The problem is likely that the layout of the addon repo changed after 7.8.5, thus the path is not constructed correctly by g.extension in that version.
A workaround could be to fetch the add on repo with git (git clone https://github.com/osgeo/grass-addons)
And then point g.extension to your local copy:
g.extension extension=r.area url=./grass-addons/src/raster/r.area
You may need a zip file, but you can try the above first...
Good luck..
Cheers,
Stefan
> Gesendet: Montag, den 09.01.2023 um 21:14 Uhr
> Von: "Bernardo Santos via grass-user" <grass-user at lists.osgeo.org>
> An: "Markus Neteler" <neteler at osgeo.org>
> Cc: "GRASS User List" <grass-user at lists.osgeo.org>
> Betreff: Re: [GRASS-user] How to use g.extension in GRASS7.8
> Hi Markus and Vero,
> Thanks. Indeed, my GRASS version is old:GRASS 7.8.5Ubuntu 18.04.6 LTS
> I unfortunately do not have a way to upgrade it myself since this is a company server shared with other people (and we have been fighting with IT to change to GRASS 8).But maybe it is easier to at lease update GRASS to version 7.8.7 (or 7.8.8).
> I just talked to a colleague (@mauricio.vancince) who mentioned he had the same problem but could overcome it opening the terminal as a superuser and using g.extension r.area -sUnfortunately I do not have admin rights, but I will see what is possible to be done.
> Thanks!BestBernardo
> Em segunda-feira, 9 de janeiro de 2023 15:19:07 GMT+1, Markus Neteler <neteler at osgeo.org> escreveu:
> Hi Bernardo,
> On Mon, Jan 9, 2023 at 2:58 PM Bernardo Santos
> <bernardo_brandaum at yahoo.com.br> wrote:
> > Hi Markus,
> > That was my first try, and then I get the error below:
> > Fetching <r.area> from GRASS GIS Addons repository (be patient)...
> > svn: E170000: URL 'https://github.com/OSGeo/grass-addons/trunk/grass7/raster/r.area' doesn't exist
> > ERROR: GRASS Addons <r.area> not found
> Ah right. Then your GRASS GIS 7.8 version may be too old. G 7.8.7
> should be ok (G 7.8.8 is on the way these days) but in any case, as
> Vero pointed out, we highly recommend to upgrade to GRASS GIS 8.2.x.
> Best,
> Markus
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230110/9a1d4f22/attachment-0001.htm>
