[GRASS-user] Surfaces with faults
bonushenricus bonushenricus76 at gmail.com
Mon Jul 24 07:44:58 PDT 2023
Hello
I would like to use the procedure described in "Open Source GIS: A
GRASS GIS Approach" second edition page 191 "7.3.5 Surfaces with
faults".
I have a survey of points. Some points are two ditches. I have run a
v.surf.rst with the survey points without the ditch.
Attached is the ascii file of the ditch points (EPSG:32632)
I have therefore operated as follows:
> v.in.lines -z --overwrite input=fosso.dat output=fosso_linea /
> separator=comma
> g.region vector=fosso_linea res=0.2
> v.to.rast -d --overwrite input=fosso_linea type=line output=fosso /
> use=z
> v.surf.rst --overwrite segmax=60 npmin=100 dmin=1 dmax=6 /
> input=fosso_linea elevation=fosso_dem mask=fosso
the result is with no_data
Some suggestions?
Perito agrario Enrico Gabrielli
progetto F.A.R.M. www.farm-agroecologia.it
Tessera n. 633 Collegio Periti agrari prov. Di Modena
Biblioteca agricoltura: https://www.zotero.org/groups/aplomb/
https://www.inaturalist.org/observations/bonushenricus
687244.011,4910560.273,482.096
687240.364,4910558.058,482.109
687236.976,4910556.868,482.224
687233.285,4910555.428,482.328
687229.403,4910553.534,482.447
687224.965,4910551.415,482.629
687220.509,4910549.32,482.71
687216.282,4910546.997,482.89
687211.919,4910544.472,483.09
687208.558,4910542.642,483.261
687204.914,4910540.584,483.411
687204.912,4910540.58,483.32
687204.91,4910540.585,483.318
687200.661,4910538.442,483.673
687196.32,4910536.328,483.925
687191.518,4910534.29,484.293
687186.415,4910532.11,484.606
687181.112,4910530.163,484.737
687175.282,4910528.125,484.931
687169.458,4910526.233,485.236
687165.078,4910524.769,485.454
687160.04,4910522.885,485.697
687155.365,4910521.006,485.94
687151.164,4910519.457,486.282
687146.398,4910517.688,486.647
687141.874,4910515.805,487
687136.644,4910513.793,487.386
687132.068,4910512.125,487.659
687127.667,4910510.478,487.808
687122.314,4910508.022,487.879
687118.571,4910505.605,488.063
687114.031,4910501.636,488.301
687110.273,4910498.216,488.499
687108.325,4910496.676,488.602
687104.514,4910493.377,488.952
687101.82,4910491.029,489.219
687098.956,4910488.78,489.501
687096.126,4910486.848,489.734
687093.251,4910484.774,489.993
687088.748,4910482.092,490.242
687084.967,4910480.104,490.434
687080.853,4910478.109,490.631
687079.416,4910477.4,490.858
NaN,NaN,NaN
687034.891,4910501.481,486.212
687036.539,4910499.803,486.445
687038.564,4910497.364,486.72
687041.869,4910494.061,487.317
687046.279,4910490.702,487.837
687051.119,4910486.971,488.42
687056.483,4910483.767,488.936
687062.8,4910480.263,489.641
687068.777,4910477.408,490.42
687075.301,4910474.554,491.299
687082.093,4910471.638,492.264
