[GRASS-user] help r.forestfrag
    María Celeste Galizzi
    celegalizzi at gmail.com
    Fri Mar 24 07:02:27 PDT 2023
Thank you very much!
El mié, 22 mar 2023 a las 18:42, Markus Neteler (<neteler at osgeo.org>)
escribió:
> Hi Celeste,
> On Thu, Mar 16, 2023 at 2:06 PM María Celeste Galizzi
> <celegalizzi at gmail.com> wrote:
> > Hi Markus!
> > Yes,  I installed the plugin with g.extension.
> > I had already calculated those indices for that or other rasters.
> Mhh - you wrote that you use GRASS GIS 7.8 (please consider to
> update!) but the error shows GRASS8 in the path:
> File "C:\Users\Cele\AppData\Roaming\GRASS8\addons\scripts\r.forestfrag.py
> line 452, in <module>
> When using g.extension in GRASS GIS 7.8 it should fetch r.forestfrag
> from the grass7 branch in the addon repository.
> Best,
> Markus
> > Best,
> > Celeste
> > El mié, 15 mar 2023 a las 18:26, Markus Neteler (<neteler at osgeo.org>)
> escribió:
> >> Hi María Celeste,
> >> On Wed, Mar 15, 2023 at 3:24 PM María Celeste Galizzi
> >> > Mi nombre es Ma. Celeste Galizzi.
> >> > Estoy trabajando con imágenes Landsat 5 y 8.
> >> > Hice las correcciones, apilado de bandas, kmeans y reclasificación.
> >> > Sobre la imagen reclasificada es con la que estoy tratando de
> calcular los índices de fragmentación en Grass gis 7.8
> >> You are using GRASS GIS 7.8, but ...
> >> > Para ello importo la imagen raster, con la calculadora clasifico en
> bosque-no bosque y uso r.forestfrag para calcular los indices (tamaño de la
> ventana 15).
> >> > En ese momento me aparece este mensaje
> >> > WARNING: The window option is deprecated, use the option size instead
> >> > Traceback (most recent call last):
> >> ... seem to use the addon version for GRASS GIS 8 which may not be
> compatible.
> >> Did you install the addon with g.extension?
> >> Best,
> >> Markus
> >> > r.forestfrag.py", line 452, in <module>
> >> > sys.exit(main(*gs.parser()))
> >> > r.forestfrag.py", line 239, in main
> >> > _(
> >> > TypeError: %d format: a number is required, not NoneType
> >> > Ya había trabajo con la imagen con otros tamaños de ventana.
> >> > Por favor, podrían ayudarme a solucionar el problema?
> >> > Desde ya muchas gracias!!!
> >> > Saludos cordiales
> >> > Ma. Celeste Galizzi
> >> > ResponderReenviar
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org
> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
> >> Markus Neteler, PhD
> >> https://www.mundialis.de - free data with free software
> >> https://grass.osgeo.org
> >> https://courses.neteler.org/blog
> Markus Neteler, PhD
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230324/ca6626ef/attachment.htm>
