[GRASS-user] Re-projection fails
Rich Shepard rshepard at appl-ecosys.com
Mon May 1 10:22:12 PDT 2023
On Mon, 1 May 2023, Micha Silver wrote:
> First comment: I think you should not have GRASS map names starting with a digit.
Micha,
I should know better. Darn!
> Can you change the above to
> output=topo_2010
Done.
> The first run of r.proj (with the -g flag) only gives you the target
> region settings. You now need to set the region with those settings, and
> then run r.proj again (without -g) do actually do the work.
> g.region -ap $NSR
> r.proj loc=Dixie_Mountain_2010_LiDAR map=PERMANENT in=2010_topo method=lanczos mem=2000 output=topo_2010 --o
I wondered about that. I've certainly forgotten a lot of grass since I last
used it.
All fixed now.
Many thanks for your patience, Micha.
Regards,
Rich
