[GRASS-user] v.to.rast: advice needed
Rich Shepard rshepard at appl-ecosys.com
Wed May 10 12:08:28 PDT 2023
On Wed, 10 May 2023, Maris Nartiss wrote:
> I think you need to interpolate and not simply convert vector lines to
> raster lines. Make sure lines have an attribute with elevation (or z
> coordinate) and use e.g. v.surf.rst module.
Māris.
Interpolating the vector contour file before rasterizing makes sense to me,
too. Never before having to convert a vector elevation contour file to a
raster file I'd no idea which v.surf.* module to apply.
The vector file has a ContourEle attribute with the elevation values.
I'm taking your advice and will use v.surf.rast.
This project has more topography data issues than any I've encountered since
I started using grass with version 4.0 (all integer, all CLI.)
Very much appreciated,
Rich
