[GRASS-user] v.to.rast questions
    Anna Petrášová
    kratochanna at gmail.com
    Wed May 10 19:36:51 PDT 2023
On Wed, May 10, 2023 at 12:34 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Wed, 10 May 2023, Anna Petrášová wrote:
> > Sounds like the vector geometry was already 3D, that's the case when you
> > use use=z. If the vector would be 2D (see v.info) you would have to use
> the
> > attribute table.
> Anna,
> When I used the 2D file, regardless of which parameter I used or both,
> v.to.rast told me the file was not 3D. That's why I converted it. When
> 'use=z' failed I tried 'attribute_column=ContourEle' with the same result.
> Now I have the rasterized contour map (image attached) and need to learn
> how
> to use it to create flowlines, flow accumulations, and more. It does not
> have the 1'x1' cells each with a color representing the elevation.
> Is there an r.* module to interpolate elevations between the contour lines
> so I have cells?
There is r.surf.contour, so that sounds like the tool you need.
> This is all new to me so I appreciate all the help I get.
> Regards,
> Rich_______________________________________________
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230510/5d0b5ab5/attachment.htm>
