[GRASS-user] v.in.ascii data error
Anna Petrášová kratochanna at gmail.com
Tue May 23 06:40:58 PDT 2023
On Mon, May 22, 2023 at 5:26 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Mon, 22 May 2023, Anna Petrášová wrote:
> > That's not what I meant. Point format is for points, nothing else. If you
> > need areas, you need standard format. See the first example in the man
> > page for importing areas.
> Anna,
> That's what I thought, and what I had defined in the data file and command.
> but with a none-rectangular boundary I don't have the coordinates for a
> centroid; although I could just pick a point, I suppose.
> Do all standard format boundary data files require me to include a
> centroid?
Then yes, just include the boundary and run v.centroids. It was unclear
from your first question what it is you actually need.
> Regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Anna Petrasova
Getting benefits from GRASS GIS? Check new ways to contribute back:
https://opencollective.com/grass/contribute
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230523/0b2ce248/attachment.htm>
