[GRASS-user] v.in.ascii standard format CRS sequence
Rich Shepard rshepard at appl-ecosys.com
Wed May 24 12:13:53 PDT 2023
In v.in.ascii the point format specifies which data represents easting and
which represents northing by specifying which column is x and which is y,
respectively.
The standard format does not use column specifications. Is the standard
format assuming the sequence is easting/northing?
TIA,
Rich
