[GRASS-user] Trying to use GRASS with Jupyter note books in Windows
Vishal Mehta
vishalm1975 at gmail.com
Fri Sep 29 15:33:41 PDT 2023
Thanks Markus,
I installed bash kernel; and it seems that it is there (#lsmagic lists bash
as one of the cell magics)
but I get the error below:
##bash
g.list type=rast
---------------------------------------------------------------------------CalledProcessError
Traceback (most recent call last)
Cell In[20], line 1----> 1 get_ipython().run_cell_magic('bash', '',
'g.list rast\n')
File C:\GRASS GIS
8.3\Python39\lib\site-packages\IPython\core\interactiveshell.py:2493,
in InteractiveShell.run_cell_magic(self, magic_name, line, cell)
2491 with self.builtin_trap: 2492 args = (magic_arg_s, cell)->
2493 result = fn(*args, **kwargs) 2495 # The code below prevents
the output from being displayed 2496 # when using magics with
decorator @output_can_be_silenced 2497 # when the last Python token
in the expression is a ';'. 2498 if getattr(fn,
magic.MAGIC_OUTPUT_CAN_BE_SILENCED, False):
File C:\GRASS GIS
8.3\Python39\lib\site-packages\IPython\core\magics\script.py:154, in
ScriptMagics._make_script_magic.<locals>.named_script_magic(line,
cell) 152 else: 153 line = script--> 154 return
self.shebang(line, cell)
File C:\GRASS GIS
8.3\Python39\lib\site-packages\IPython\core\magics\script.py:314, in
ScriptMagics.shebang(self, line, cell) 309 if args.raise_error and
p.returncode != 0: 310 # If we get here and p.returncode is
still None, we must have 311 # killed it but not yet seen its
return code. We don't wait for it, 312 # in case it's stuck in
uninterruptible sleep. -9 = SIGKILL 313 rc = p.returncode or
-9--> 314 raise CalledProcessError(rc, cell)
CalledProcessError: Command 'b'g.list rast\n'' returned non-zero exit
status 127.
Also I am unable to install extensions r.stream.distance:
!g.extension r.stream.distance
as well as through the GUI
both give me a "cannot find executable git" error
Best,
Vishal
On Fri, Sep 29, 2023 at 11:53 AM Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Sep 28, 2023 at 10:09 PM Vishal Mehta <vishalm1975 at gmail.com>
> wrote:
> > Thanks Markus and Vaclav,
> > This is what worked for me on Windows:
> > # Ask GRASS GIS where its Python packages are.
> > sys.path.append(
> > subprocess.check_output(["C:\GRASS GIS 8.3/grass83.bat", "--config",
> "python_path"], text=True).strip()
> Perfect, added to the Wiki page, too.
> > Also, can I use bash within the jupyter notebook?
> Seems yes, after:
> pip install bash_kernel
> Markus
Vishal K. Mehta, PhD
Sr. Scientist
Stockholm Environment Institute - US
501 D St
Davis CA 95616
https://www.sei.org/people/vishal-mehta/ <http://www.sei-us.org>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230929/4aa53a33/attachment.htm>
