[GRASS-user] Integer division with r.mapcalc
Maris Nartiss maris.gis at gmail.com
Fri Apr 12 00:06:25 PDT 2024
And that WIKI is wrong. gis.h defines CELL as int thus only thing
guaranteed is that CELL will be able to store values in range from
-32767 to +32767. But by magic of C standard on my system CELL can
store values in range from -2147483647 to +2147483647 (as long as my
compiler uses /usr/include/limits.h). One running GRASS on an ARM CPU
system most likely will see different numbers.
I do agree that it is a good idea to note integer overflow in
r.mapcalc, but I would be careful with "largest number" as it has to
be tied-up to arch/compiler combo.
Māris.
ceturtd., 2024. g. 11. apr., plkst. 12:16 — lietotājs Luí­s Moreira de
Sousa via grass-user (<grass-user at lists.osgeo.org>) rakstīja:
> Thanks Ondrej, that makes sense.
> I just found the details in the Wiki [0], perhaps those should be in the manual.
> Regards.
> [0] https://grasswiki.osgeo.org/wiki/GRASS_raster_semantics
> Luís
> Sent with Proton Mail secure email.
> On Thursday, April 11th, 2024 at 9:49 AM, Ondřej Pešek <pesej.ondrek at gmail.com> wrote:
> > Hi Luís,
> > čt 11. 4. 2024 v 8:26 odesílatel Luí­s Moreira de Sousa via grass-user
> > grass-user at lists.osgeo.org napsal:
> > > I am working with a raster with very large integers. That are stored as 64 bit floats (imported from a GTiff). I wish to extract part of these values with an integer division. The first approach was:
> > > r.mapcalc 'short_ints = int(long_ints)/1000000'
> > > However, this results in something that is not an integer division. In fact I have no idea what the result is. Eventually, I succeeded with the following formulation:
> > > r.mapcalc 'psu_ids = int(ssu_ids/1000000)'
> > > I have been going through the manual back and forth and can't understand why these two expressions produce different results. Any insights?
> > This is probably due to the 32-bit size of `int()`. If your values are
> > higher than `2 ** 31 -1` (i.e. 214783467; `31` because half of the
> > numbers go to the negatives; `-1` because there is also NULL), the
> > counter starts to rotate. It means that `2 ** 31` will be NULL and `2 ** 31 + 1` will be `- (2 ** 31 - 1)`. You can encounter this behaviour
> > also in other software, such as in `numpy`.
> > Indeed, there is no mention of that in the docs. I will update it
> > today to include this information. It is true that it's easy to break
> > your teeth on this.
> > Cheers,
> > Ondra
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
